Author Topic: What am I looking at here? Vertical Visual Pinball  (Read 13434 times)
  • Last login:September 09, 2025, 11:57:41 pm
« on: February 10, 2008, 11:29:39 am »
[youtube]http://www.youtube.com/watch?v=hcLQOBwxvSE[/youtube]
I was wanting to know if building a visual pinball machine would be worth it. Can you use a monitor setup vertically? Does it make sense to?
shardian
Re: What am I looking at here? Vertical Visual Pinball
« Reply #1 on: February 10, 2008, 11:43:37 am »
Can it be done? Yes. Is it difficult? Yes. Results may vary? Yes.
That guys setup looked very good. I believe there was alot of custom work done there. The backglass pretty much has to be custom.
I've seen a few discussions over at vpforums about it. go to vpforums.com and read up in the forums.
fixedpigs
  • Last login:August 19, 2025, 01:29:35 pm
  • warning: drew can't handle my avatar...
« Reply #2 on: February 10, 2008, 11:46:41 am »
that kid sucks...
nice to hear axl's sweet swooning on a sunday morning though... ;)
surf
  • Last login:December 15, 2011, 11:43:38 am
  • I've built my own arcade!
« Reply #3 on: February 10, 2008, 05:14:10 pm »
"backglass" is just a monitor...
looks like a cool project, just be a bit pricey for a good size "table"
Surf
http://www.freewebs.com/homepubarcade
(Just a homemade arcade)
DaveMMR
« Reply #4 on: February 10, 2008, 05:42:54 pm »
It may be cool to make a "bartop" pinball machine though for a reasonable price.   I was never big on putting VP on my cab, but I wouldn't mind making a dedicated video pinball table like that.  Looks cool!
  • Last login:July 11, 2025, 09:17:44 am
« Reply #5 on: February 10, 2008, 06:48:11 pm »
Yes, I believe it's not hard at all.  Normally, Visual Pinball allows you to display the Pinball board and the back (where the score is kept) on the same monitor.  Visual pinball moves it over to the left or right depending on the game.
However, it does give you the option to have the scoreboard on another monitor so as to not obstruct the main pinball area.  I suppose you could make the pinball main area on a widescreen vertical monitor and the scoreboard on a normal 4:3 monitor.  Looks like this is what he did.
~ D
Neverending Project
    • Arcade Fixer
« Reply #6 on: February 11, 2008, 12:23:13 am »
There is always the commercial route. $ ;) $
shardian
« Reply #7 on: February 11, 2008, 08:10:53 am »
Duh. I meant custom layout. :P
unclet
« Reply #8 on: February 11, 2008, 08:57:48 am »
Can most Visual Pinball tables be played on a 900Mhz computer?
shardian
« Reply #9 on: February 11, 2008, 09:08:58 am »
The older ones yeah. DMD's are hit and miss. My former home desktop was an AMD Duron 1.2ghz with a ton of memory and a decent vid card. Medieval Madness was bogged down something fierce.
« Reply #10 on: February 11, 2008, 09:19:53 am »
How is that any different than a MAME cab?  Seems to me a VP cab would be a whole lot easier - you don't have to worry about controls or monitor orientation, you have a far smaller amount of software to deal with, there is no 15khz debate, etc.
shardian
« Reply #11 on: February 11, 2008, 09:21:46 am »
Because there are software limitations in pinmame that MAME does not have.
« Reply #12 on: February 11, 2008, 09:29:23 am »
Pinmame is a tiny emulator.  It doesn't even do anything useful without Visual Pinball.  I've never seen anything with Pinmame that makes me think it is a problem and we use Visual Pinball a lot in my house.
What issues are you talking about?
EDIT:  now that I think more on it, the fact that Pinmame expires every 6 months is a pain in the ass.
« Last Edit: February 11, 2008, 09:35:29 am by ChadTower »
shardian
« Reply #13 on: February 11, 2008, 09:38:05 am »
When I say pinmame, I mean Visual Pinmame - the combination of visual pinball and pinmame.
« Reply #14 on: February 11, 2008, 09:47:53 am »
Okay then - what are the issues you're talking about?  We run it on two difference machines regularly and don't have much trouble beyond the Pinmame expirations.
shardian
« Reply #15 on: February 11, 2008, 09:58:55 am »
Jeez, nitpicker. :P
In order to create what this guy did, you have to change the angle of the playfield. The software supports it, but it is wonky and combine that with the fact that many tables weren't designed with a zero angle in mind, they look like crap. You can't just plug in two monitors and be up and running after resetting the angle. Also, flipping the playfield to run vertical has its own set of compatibility and resolution issues.
It's been a year since I even tried messing with it, and vpforums is down so I can't refresh my memory on the details right now.
« Reply #16 on: February 11, 2008, 10:04:49 am »
I can't see what that guy did (websense) - but if you just went with the default angle, which is pretty much fine IMO for what it is - it should run pretty well.  I hear all the time about VP that it's really hard to set up in a cab.  I just don't see that as the case.  It may be hard to get to do things that people want, sure, but you design a cabinet around software, not vice versa.  If you build a cabinet that plays to VP's strengths it will be pretty good.
I just don't see how a skilled MAME cab builder would have any difficulty at all making a decent VP cab unless they tried to do things VP isn't designed to do.  It's not a pinball machine and you can't reproduce a pinball machine perfectly in software no matter what you do.  It's all the same comments you get regarding Ultrapin sucking because it doesn't feel like a real pin.
My advice on VP is to not try to make a pinball machine.  Make a VP cab and it will play and feel like a good VP experience.  If you don't want a VP experience then, as you decided with your project, a VP cab isn't for you.
unclet
« Reply #17 on: February 11, 2008, 10:31:37 am »
Yeah, I cant stand how PinMame expires either ...... I wish someone would hack that out of there .....
shardian
« Reply #18 on: February 11, 2008, 10:32:36 am »
Ahh it makes sense now. You are arguing in a thread in which you don't even know what the debate is about. ;) :P
In the video, the guy has G&R pinball running, but with nothing but the playfield taking up and entire widescreen monitor laying on its back in a vertical orientation, and a 4:3 monitor behind it displaying the entire backglass with the DMD where it is supposed to be. I don't know what language they are speaking, but it definitely isn't american (it never is in the best projects ;D)
What he did is very difficult to do and make it look good. Basically he made an ultrapin.
Just putting visual pinmame in a cab and adding buttons, well DUH that is simple. However, that is not what is being discussed here.
« Reply #19 on: February 11, 2008, 10:33:53 am »
I responded to Lew's actual question.
He doesn't ask how can I do what this guy did.  He asks about VP in general.  Had he asked about that guy's cab I wouldn't have responded.
shardian
« Reply #20 on: February 11, 2008, 10:40:15 am »
Dude, you quoted me.
« Reply #21 on: February 11, 2008, 10:49:26 am »
True, that made it ambiguous.  Oh well.   :dunno
SavannahLion
« Reply #22 on: February 11, 2008, 10:50:50 am »
Not to steal the topic.
Why does pinmame expire?
The pinmame site is blocked at work, otherwise I'd look it up myself.
ahofle
    • Arcade Ambience Project
« Reply #23 on: February 11, 2008, 10:57:42 am »
I could be mistaken, but I believe it was in case one of the copyright owners complained about the inclusion of their game they could remove it from the following release and everyone would be forced to upgrade to remove the game.
shardian
« Reply #24 on: February 11, 2008, 10:58:48 am »
Okay, I did some quick research and found the thread that discusses setting up a DIY ultrapin.
VPForum thread is here
Also note that on the last page the guy who posted that youtube video posts about his accomplishment. I also noted that his youtube account was "Lordhiryu". I think several of you will recognize that name - he is a talented spanish cab builder. He used to post here, Here is his profile, but he is mostly active in his native forums.
shardian
« Reply #25 on: February 11, 2008, 10:59:08 am »
That is correct.
JackTucky
  • Last login:January 04, 2021, 12:00:58 pm
  • Soon I will post that I am a triathalete
« Reply #26 on: February 11, 2008, 10:59:25 am »
Is this the first time you've noticed that about people here?
=J
Well, that's where we go a-ridin' into town, a whampin' and whompin' every livin' thing that moves within an inch of its life. Except the women folks, of course.
SavannahLion
« Reply #27 on: February 11, 2008, 01:06:44 pm »
Oi  ::) In my book there is a huge difference between a virtual representation of a pinball and the actual physical hardware.
Have any of the copyright owners complained about that yet?
shardian
« Reply #28 on: February 11, 2008, 01:10:42 pm »
Pinmame relies on the actual roms from the actual game. That is a catcher right there. Most copyright owners don't care and the roms are freely available. Gottlieb is the main exception. They have authorized dealers to sell chips, manuals, etc.
« Reply #29 on: February 11, 2008, 01:11:03 pm »
Pinmame is the emulation of the physical hardware - the CPU to be exact.  It is not Visual Pinball, which is a simulation.  Pinmame is the engine that emulates the CPU board, running the game logic, and using the actual ROMs from the original machine.  It is no different than MAME for this purpose.  Without Pinmame VP wouldn't be emulating any game with a CPU.
sharidan - stern cares too, at least when it comes to the modern games.  That's why you don't find them available.  Not in the mainstream anyway.
shardian
« Reply #30 on: February 11, 2008, 01:15:33 pm »
Stern seems to have a "3 year rule". The roms are available after they finish making their money off the game.
« Reply #31 on: February 11, 2008, 01:23:54 pm »
I'll have to poke around and see if I can find some of the just over 3 year old Stern games, then.  When I'm looking for new tables I tend to look older games before I look newer.  Last I looked the stuff like Sharkey's Shootout and T3 weren't out there - just some vague references to them being available if you knew the right forum members.
Kangum
  • Last login:February 25, 2018, 07:46:20 am
« Reply #32 on: February 11, 2008, 02:22:12 pm »
both T3 and sharkys shootout are available at AJs. T3 came out last year i think and sharkys shootout came out in like 2005.
attached is T3 rotated fulscreen on my latop. sorry for the quality i suck at photos.
« Last Edit: February 11, 2008, 02:36:37 pm by Kangum »
SavannahLion
« Reply #33 on: February 11, 2008, 03:25:16 pm »
Oh duh.  :banghead: I keep thinking of pins as electromechanicals and discrete logic.
SGT
  • Last login:May 31, 2025, 10:10:32 pm
« Reply #34 on: February 11, 2008, 09:34:15 pm »
In the video, the guy has G&R pinball running, but with nothing but the playfield taking up and entire widescreen monitor laying on its back in a vertical orientation...
What size screen for the playfield do you suppose that is?  Is that a 16:9 aspect ratio?  It seems super long (vertically).
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #35 on: February 11, 2008, 11:25:57 pm »
To properly display the playfield, you'd need to set it to have no perspective, but angle the camera view such that it's about 45' view. (You'd have to experiment to get the correct angle based on how you intend to play it). Also need and LCD monitor that doesn't wash out and look all cruddy from such an angle.
Here's another one... looks damn cool!
[youtube]http://www.youtube.com/watch?v=3a4MVu5wlng&feature=related[/youtube]
NO MORE!!
Loafmeister
  • Last login:June 03, 2025, 01:49:49 am
« Reply #36 on: February 12, 2008, 02:00:00 am »
Some additions/corrections:
Expiry date:  The legal reasons above are true but there is also more to it than that.  Vpinmame/Pinmame is a program that is constantly being developed.  The devs have publically stated if ever development stops, there will be a version released minus the expiry date. However, for now, along with the legal reasons, the expiry date also acts as a personal reminder to check and see what new version was released and therefore gives you the chance to explore the new features, bug fixes and new tables supported.  I always like to view things in a positive light. ;)
3 year rule:  This is not a Stern rule, it's a pinmame/vpinmame dev rule, as a sign of respect towards Stern.  Stern neither approves or disapproves. Stern cannot legally approve as they are not the sole copyright owner of many/most of their tables (ex: monopoly).  To do so could leave them liable for a nice lawsuit.  Since VPM is a non-commercial product, totally free of charge, they tolerate VPM; let's leave it at that.
MPTech
  • Last login:January 05, 2025, 03:58:54 pm
  • UltimateArcade completed!
« Reply #37 on: February 12, 2008, 02:02:14 am »
I've got VP & FP setup on my cab and really like them both, I know they are not quite like a real pinball, but then again I couldn't afford 300+ tables, or house them, so this is a cool compromise!
It is kind of a bummer playing on a horizontal monitor with the angle aspect and all. But it is still a LOT of FUN!  Hey, the price was right too, just add a couple flipper buttons to the side of the cab!
I think the UltraPin would be even neater, setup in a Pin Table (with the metal legs, a tilt, and a plunger!), with a Vertical monitor and a seperate backglass! OH YEAH!
I wish someone would figure out how to do it and publish a how-to!
Any takers?!?!?!  There are some REALLY talented guys here!  Evil? Psychtech? Leaping Lew?  C'mon guys, this would be a challenge!
MPTech
   Better living thru technology!   ;-)
Xiaou2
  • Last login:Today at 05:23:45 am
  • NOM NOM NOM
« Reply #38 on: February 12, 2008, 04:18:39 am »
 while I do play some visual pinmame occasionally..  its absolute crap compared to the
real deal.
 I also played the  Ultrapin at the Rochester gameroom show last time, and it stunk.
Poor display refresh rate = blurry, and frame-skippy.    No kicker coils for feedback.
Graphics were cartoony instead of photorealistic.   Flat looking.  Poor physics.
And much more.
 You may not be able to afford to buy a whole basement of Pins... but I tell you,
youd be more happy spending decent money on One REAL Pin instead of sinking
a grand into a phony POS that will never compare in looks, feel, and more
importantly ... Fun.
 Now, if we were to make a Really good pinball simulator..  it would use the latest
Headtracker techniques along with a Steroscopic Display.  (3D LCD Glasses, or
3d Head mounted display helmet system )
It would have multiple kicker coils that would give the player the feedback when
he pushes the flippers, or hits a bumper...etc.   The thing would have a separate
dedicated physics card(s)  specially designed by mathematical geniuses.
 It would sense all variations of tapping, bumping, sliding..etc.. and replicate the
results that occur on a real machine.
shardian
« Reply #39 on: February 12, 2008, 08:22:41 am »
22" WS monitor for playfield, 17" 4:3 for backglass.
