Author Topic: Custom Windows XP Boot Screens  (Read 42543 times)
Ritalin
  • Last login:May 07, 2015, 12:25:39 am
« on: January 25, 2008, 06:33:20 pm »
I've created some custom Windows XP boot screens for my galaga bartop project, but it's somewhat buried in my project thread here: http://forum.arcadecontrols.com/index.php?topic=75495.0
I thought I'd create a thread devoted to custom Windows boot screens so people can upload/download unique boot screens for MAME that do not require third party add ons. (it's all about sharing!) :D
These are easily added to your Windows XP system by doing the following:
Go to My Computer >Properties >Advanced >Startup and Recovery >Settings. Select “Edit startup options file”. Add “ /bootlogo /noguiboot” to your default operating system path (there must be a space between each switch)
It will look something like this:
Then download the custom 16-color 640 x 480 pixel BMP files I created in a ZIP file to this post.
Change the name of the file you want to use to "boot.bmp” and add it to your WINDOWS directory.
(I can't upload bmp files directly here, and I included a horizontal and vertical option.
JPG files below are for PREVIEW only and are full color JPGs
The ZIP file contains the 16 color bmp files you will need.
Enjoy!
Ritalin
Re: Custom Windows XP Boot Screens
« Reply #1 on: January 25, 2008, 06:34:24 pm »
If anyone has a cabinet theme project that they need help with creating a custom Windows XP boot screen, just post your request here in the thread and I'll make the screen for you. Cheers.
WunderCade
« Reply #2 on: January 25, 2008, 10:42:43 pm »
I'd be interested in one just like you did for Galaga, but instead for a Ms. Pacman multi-pac theme like the marquee below. ;D
BTW this is an awesome concept.
Or
« Last Edit: January 25, 2008, 10:50:18 pm by WunderCade »
phishpac
  • Last login:October 15, 2009, 10:42:19 am
    • grateful arcade
« Reply #3 on: January 26, 2008, 12:35:18 am »
Wow Ritalin!  That's very nice of you.  I would love to have one based on the attached image!!! you rock!
Ritalin
« Reply #4 on: January 27, 2008, 05:03:41 am »
Or
Hi WunderCade,
Here are some 16 color files you can try out as Windows boot screens.
The only issue was that the source files you included needed to be enlarged a bit which resulted in a loss of quality, but then again these are replacing a startup screen which already looks pretty poor anyway at 16 colors, so it should still look cool when booting up.
I redrew the MAME logo in a Ms. Pacman color and style for you and included both vertical and horizontal layouts.
As always, the ZIP file contains the actual BMP boot files you need.
The GIFs are just 16 color previews but you need the BMP files from the ZIP.
Enjoy!
Ritalin
« Reply #5 on: January 27, 2008, 05:30:24 am »
Since you have such a great logo to work with I came up with some boot screen that emphasize your logo and not the text. Again, it's a boot screen so your lettering gradient won't translate very well into 16 colors total.
The first one is just your awesome logo. Looks too good to mess with.
The second option is the logo and I recreated the MAME logo with in your logo style.
Let me know if you like either of these.
Enjoy!
WunderCade
« Reply #6 on: January 28, 2008, 02:02:10 am »
Hi WunderCade,
Enjoy!
Wow...thanks...those a great!!!  :cheers:
Sorry for the low res. reference pics. I assumed you knew the vector AI files were in the Arcade Art Library...but hey, they are great and thanks again bro! Very kewl of you. Here are the vectors if you ever need them for anything...
Ritalin
« Reply #7 on: January 28, 2008, 04:13:58 am »
Like an idiot, I totally forgot about the vector art already available online.
Oops!
Ah well, the 16 color versions should still serve as nice Windows boot screens.
Enjoy!
bent98
  • Last login:February 02, 2019, 03:35:00 pm
  • Hyperspin Moderator
« Reply #8 on: January 28, 2008, 08:55:50 am »
I would love for you desgin a boot screen. I have enclosed images of what cab looks like. What do you think would look good for a intro screen?
Also are there any problems using this boot screen with XP SP2.
I remeber trying to do this and getting blue screens when booting. I used some 3rd party program to do it though.
« Last Edit: January 28, 2008, 02:04:43 pm by bent98 »
unclet
« Reply #9 on: January 28, 2008, 09:56:38 am »
Will you explain what the "/bootlogo" and "/noguiboot" do?
I was assuming there would be a current "boot.bmp" bitmap file located in my C:\Windows" directory, but there is not one.   Do those switches (listed above) indicate to WinXP that it should look for the "boot.bmp" file now when booting up?
Also, will making this change affect how the computer does other things ..... go into safe mode, etc....     Just trying to make sure WinXP still functions properly after making this change (apart from just seeing a new BMP image on bootup of course)..
« Last Edit: January 28, 2008, 10:04:21 am by unclet »
bent98
« Reply #10 on: January 28, 2008, 10:14:04 am »
I know access to the boot.ini file changed after SP1 so that why I want to know if this method works with SP2 and hopefully SP3 when it comes out later this year
Ritalin
« Reply #11 on: January 29, 2008, 01:35:48 am »
First off, WOW, stunning looking cabinet and art you have there!
Excellent work.
How's this for a boot screen? (see below)
Please remember that you can only use 16 colors. They can be any 16 colors, but only 16 colors max nonetheless. Thus, it was virtually impossible to put too many multi-colored game characters without them looking horrible.
As for your technical question about the boot screen with XP SP2, I don't know. I'm using TinyXP without any issues at all. The beauty of this edit is that it doesn't use a third party utility and it's a text edit. You can always simply go back to the default settings if need be.
Let me know if this captures the look and feel of your cab.
Cheers.
Ritalin
« Reply #12 on: January 29, 2008, 01:43:57 am »
Honestly, I have no clue.
I just followed the instructions from the BYOACWiki Page. Here:
http://wiki.arcadecontrols.com/wiki/Hiding_Windows
It's very safe and in a total worst case scenario you can always restore your boot.ini file with your original XP install CD as per the microsoft instructions here:
http://support.microsoft.com/default.aspx?scid=kb;en-us;330184
bent98
« Reply #13 on: January 29, 2008, 08:20:16 am »
First off I just want to say it’s very generous of you to take time out and help people customize xp boots skins.
I love what you did with the pacman theme. I dont want to sound ungrateful but is their any chance you can possibly get donkey kong in with the pacman or maybe stick the marquee in the middle? If the 16 bit color limitation makes that impossible to do then maybe add some mspacman pink in the mix so it goes with the overall colors of the cab.
Let me know if that wouldn’t be too much trouble.
Also in regards to the bootskin question, can you please verify what service pack you are running with tiny XP. To find out just right click mouse button over the my computer icon and then left click on properties. It will tell you at the bottom of the properties screen next to the cpu information.
« Last Edit: January 29, 2008, 08:28:15 am by bent98 »
phishpac
    • grateful arcade
« Reply #14 on: January 29, 2008, 01:38:23 pm »
Ritalin,
I love them both!!!  :notworthy: :notworthy: :notworthy: :notworthy:
You do fantastic work.  The blue and red MAME lettering is SICK!!!
Thanks so much... this will really add that extra touch to the arcade!
Ritalin
« Reply #15 on: January 29, 2008, 03:22:55 pm »
Hey there, no problem.
I saw that your cab was mostly black with light blue trim so I went in that direction.
If you would like it to be more pink, then please see the options below.
Oh, I just checked and I'm running XP Service Pack 2 if that assists you.
Enjoy!
bent98
« Reply #16 on: January 29, 2008, 03:46:37 pm »
Thanks. It looks great.
I will try it out tonight
bent98
« Reply #17 on: January 29, 2008, 05:03:45 pm »
Would you mind using putting the ms  pacman mame loading graphic with the first background you did that has the blue boxes you did. This way it will give it a suttle pink without overpowering it.
Ritalin
« Reply #18 on: January 29, 2008, 06:33:57 pm »
Sure, no problem.
Enjoy.
bent98
« Reply #19 on: January 29, 2008, 09:21:29 pm »
I tried it works great. Can you make one last revision and change the MAME from blue to the pink and yellow mame outline from the multipac one you did.
dont want to drive you mad.
Ritalin
« Reply #20 on: January 30, 2008, 03:06:28 am »
No trouble at all.
Here's the new one. I really like it. It should look nice at bootup!
Enjoy!
bent98
« Reply #21 on: January 30, 2008, 07:25:43 am »
Yea this is it.
Thanks. Looks sweet.
Mega-Prime
  • Last login:February 13, 2008, 11:43:16 am
« Reply #22 on: February 07, 2008, 09:37:51 am »
OMG!,
Is this a home-made cab?
Do you have a link to the plans you used for it?
It looks awesome!   :woot
ErikRuud
  • Last login:March 05, 2021, 10:20:27 am
« Reply #23 on: February 08, 2008, 09:54:33 am »
Windows boot option switches: http://support.microsoft.com/kb/833721
American Laser Games Wrapper
O2em Rom Utility
  • Last login:Today at 03:29:42 pm
« Reply #24 on: February 08, 2008, 11:27:37 am »
If anyone wants to take a crack at it for me please go HERE to download the custom logo I want to use for the boot screen.  I want it to be VERTICAL and on a PINK background, if possible.
THANKS!!!   :cheers:
waveryder
  • Last login:July 14, 2011, 04:26:17 am
  • I Troop, therefore I am
    • BubbleGum Custom Art
« Reply #25 on: February 08, 2008, 11:32:24 am »
already done javeryh
When pixelated clipart just wont do, just call for Betty
« Reply #26 on: February 08, 2008, 11:41:04 am »
Holy crap!  You RULE.   :cheers:
waveryder
« Reply #27 on: February 08, 2008, 11:47:13 am »
Theres also a windows wallpaper, that way the whole cab will boot bella, load bella, then mala bella.
« Reply #28 on: February 08, 2008, 01:00:12 pm »
Wow that's slick.  So when I power on no one will be able to tell there is a computer in there!
Dazz
  • Last login:January 11, 2025, 07:43:39 am
  • HyperSpin Team
    • VPUniverse
« Reply #29 on: February 20, 2008, 05:49:11 pm »
Ugh.. I followed this to a T and now I cannot get into Windows.  This is on a fresh install of XP with SP2.  When I reboot the computer I see the boot screen, but the bootscreen never goes away.
I am trying to use Restore from my XP cd, but that isn't working either. :mad:
waveryder
« Reply #30 on: February 20, 2008, 05:57:36 pm »
Press F8 before windows begins booting and select safemode once in windows remove the changes you've made then restart. That'll get you back into a working windows. This bootscreen method works on SP2/SP3 beta no problem. Don't know why your having issues.
Trebeck
  • "The Arcade" - Build #4
« Reply #31 on: February 22, 2008, 12:23:47 pm »
Great idea!
I now have something to this weekend
Ritalin
« Reply #32 on: February 25, 2008, 03:57:14 am »
If anyone still need a custom 16 color Windows XP boot screen, post your request here and I'll make it for you.
Just post a pic of your cab or your cab's theme, etc.
Cheers.
Miguelsluma
  • Last login:June 11, 2010, 10:20:02 am
« Reply #33 on: February 25, 2008, 08:35:55 am »
if you happen to have some time anywhere in the future. perhaps you could make one of those beauties out of the art in my topic (not the first 2 pics. the finished ones)
http://forum.arcadecontrols.com/index.php?topic=75713.0
great contribution so far, my respect.
Ritalin
« Reply #34 on: February 25, 2008, 02:15:09 pm »
Hi Miguelsluma,
Where are your finished pics? I only see sample pics.
Just PM or post the final logo pic to use for your custom XP boot screen. Cheers.
Ian
  • Last login:September 26, 2021, 01:50:35 am
« Reply #35 on: February 25, 2008, 08:28:49 pm »
wave are you doing them too? Since you did my CPO I was wondering if you could whip up a quick boot screen based on the ninjarcade artwork?
waveryder
« Reply #36 on: February 26, 2008, 03:23:08 am »
Ian thats no problem, I'll do it and email it to you this afternoon.
Ian
« Reply #37 on: February 26, 2008, 07:22:13 am »
Thanks very much!
Miguelsluma
« Reply #38 on: February 26, 2008, 07:28:04 am »
Hi Miguelsluma,
done! thanks in advance and take your time
Ritalin
« Reply #39 on: February 26, 2008, 03:10:44 pm »
Here's a Rotterdam Nation boot screen for you.
Please remember that there's a max of 16 colors, so I had to simplify your image a bit to one that uses far less colors but still keeps your theme in mind.
Enjoy.
