Poll
Is your arcade glass tinted or not tinted
Tinted
59 (83.1%)
Not Tinted
12 (16.9%)
Total Members Voted: 69
Author Topic: Arcade Cabinet Glass - Tint or No Tint?  (Read 27250 times)
ElKootcho
  • Last login:October 22, 2012, 07:58:43 pm
« on: October 06, 2007, 10:51:07 pm »
I'm at the point of adding glass to my scratch built machine. Should I tint or not?
deadkenndys1105
  • Last login:November 27, 2012, 03:55:05 pm
Re: Arcade Cabinet Glass - Tint or No Tint?
« Reply #1 on: October 06, 2007, 11:05:44 pm »
I would tint personally.
17 years old and totaly addicted.
somunny
  • Is it hot in here?
« Reply #2 on: October 06, 2007, 11:05:54 pm »
I have one of each and I would say I definitely prefer tinted.
  • Last login:March 04, 2026, 09:31:59 pm
« Reply #3 on: October 06, 2007, 11:19:40 pm »
How does one tint clear plexi?
spacies
« Reply #4 on: October 06, 2007, 11:45:50 pm »
Apply a car tint film to the back.
I prefer tinted by far.
ElKootcho
« Reply #5 on: October 07, 2007, 01:40:40 am »
[/quote]
I assume pep boys or similar is the place to get a cheap car tint kit?
spacies
« Reply #6 on: October 07, 2007, 02:10:51 am »
[/quote]
Not sure mate. I'm on the other side of the world so I have no idea who Pep Boys are.
You should be able to buy it from a glass shop, car parts retailer or a specialist car tinting company.
FrizzleFried
    • Idaho Garagecade
« Reply #7 on: October 07, 2007, 02:46:46 am »
...buy tinted plexi.  Glass shops stock it.
Level42
« Reply #8 on: October 07, 2007, 03:00:32 am »
That would be the worst option to choose.
You can get tinted glass in bronze and grey. If you want to go darker, plexi is your best bet. I just bought two pieces of Lucite Perspex, one for my Galaxian, on for my Star Wars.
Check it out here:
http://forum.arcadecontrols.com/index.php?topic=62784.msg740986#msg740986
Color number is 923, but a good dealer should have a sample chain.
« Last Edit: October 07, 2007, 03:03:34 am by Level42 »
spacies
« Reply #9 on: October 07, 2007, 03:37:08 am »
It probably is the worst option but I was just answering his question on how to tint plexi glass.
Glass is the best option but in some instances its not practical.
  • Last login:March 05, 2026, 12:10:15 pm
« Reply #10 on: October 07, 2007, 08:20:19 am »
Use tinted glass, not plexi.  I would definitely tint though - it looks WAY better, IMO.
NoOne=NBA=
« Reply #11 on: October 07, 2007, 08:50:41 am »
I'm partial to either tinted with art applied to the top, or a sandwich of clear/art/tint from the top down.
That protects the art better, but still gives you the tint on the screen area without darkening the art.
Knievel
    • Knievel Kustoms
« Reply #12 on: October 07, 2007, 11:04:10 am »
Arcade Monitor - Tint
PC Monitor - No Tint
In either case go for real glass.
tommy
« Reply #13 on: October 07, 2007, 11:28:54 am »
You don't tint it yourself, you buy it tinted, it's made in the glass, it's not something that was put on.
If you go pick it up yourself you should definitely get real Glass, if it's being shipped get it in plexi or lexan.
Real glass is going to break if you get it shipped, believe me, i know.
« Last Edit: October 07, 2007, 11:32:38 am by tommy »
somunny
« Reply #14 on: October 07, 2007, 12:19:25 pm »
Any particular reason why?  I have tinted glass over a crt pc monitor and it looks great, IMO.
Knievel
    • Knievel Kustoms
« Reply #15 on: October 07, 2007, 02:13:23 pm »
This has been my experience..
I had tinted glass over the PC monitor on my Neon machine initially but I ended up changing it. I found it took away too much color/vibrancy. With all the picture controls on a PC monitor the tint isn't really required. You can get the same effect by fine tuning the monitor.
On a real arcade monitor the controls for the picture are usually quite limited. To get the nice bright colors you want you need to start cranking the contrast/brightness, then everything starts getting fuzzy and harsh. That's where the tinted glass really shines, gets rid of all that.
BORIStheBLADE
  • Last login:February 03, 2012, 10:53:59 pm
« Reply #16 on: October 07, 2007, 11:45:36 pm »
so do you guys turn up the brightness on the monitors alot or does it not take much to make bright enough with tinted glass?
rockin_rick
  • Last login:May 27, 2017, 09:20:20 am
« Reply #17 on: October 07, 2007, 11:49:12 pm »
Another benefit of tint, IMO is that it hides the non-image stuff behind the glass, like the bezel of the monitor.  Makes it seem as if the image is the only thing under there.
If I do not respond to your post in a timely manner, feel free to PM me.
superbigjay
  • Last login:October 22, 2023, 02:50:03 pm
  • I'll always be a kid...
    • superbigjay website
« Reply #18 on: October 08, 2007, 12:05:42 am »
real tinted glass too!
Also, like rockin_rick said, it will hide minor imperfections behind the glass.
Jay
TOK
  • The Game Always Wins
« Reply #19 on: October 08, 2007, 06:48:10 am »
Tinted, regardless of monitor type.
I also used the auto tint trick on an original non-tinted glass bezel that I wanted to save (due to the screened-on art). It's tricky to apply, but it has looked great for 2+ years.
Jimbo
    • Wood Finishes Direct
« Reply #20 on: October 08, 2007, 12:04:33 pm »
S'cuse my ignorance, but can you get different grades of tint?  If so, what's the recommendation for an arcade monitor? I'd kick myself if I went too dark...
Cheers
Wienerdog
  • Last login:December 08, 2020, 06:28:51 am
  • If it's worth doing, it's worth overdoing
« Reply #21 on: October 08, 2007, 01:53:52 pm »
How does tinted glass look on an LCD?  I can understand turning the brightness up on a CRT, but that's proably not good for and LCD.  I've always liked the idea of tinted glass because then you can't see the side bars when you run a vertical game on a horizontal screen.  However, now that I'm using an LCD, I'm thinking it would be crazy to use tinted glass.
This opinion was created from 100% post consumed information.
« Reply #22 on: October 08, 2007, 02:18:32 pm »
I'm using tinted glass with a 19" Dell LCD on my current project and it looks amazing.
fixedpigs
  • Last login:August 19, 2025, 01:29:35 pm
  • warning: drew can't handle my avatar...
« Reply #23 on: October 08, 2007, 02:39:31 pm »
what about a television for a monitor...?
Level42
« Reply #24 on: October 08, 2007, 03:03:59 pm »
Indeed, and plexi comes in more colors, and even more important more grades of tint. So there's no real need to do tinting yourself, I guess the results will always be less quality then pre-tinted.
I would have chosen glass to replace my bezel on my Star Wars, but when I went to the glass dealer they told me that it would be impossible to get glass that is that darkly tinted. And I wanted it to stay as original as possible.
I guess it's also what your local supplier is carrying of course....
superart
  • Permanent ban
  • Last login:April 29, 2008, 07:16:11 pm
  • Permanent ban
« Reply #25 on: October 08, 2007, 05:04:43 pm »
edit
« Last Edit: April 29, 2008, 12:27:34 am by Suits00 »
More Cowbell
  • That's just dumb!
« Reply #26 on: October 08, 2007, 05:31:06 pm »
I've used the plexi with after market tinting and it does the job but it doesn't look very good. Tinted glass has been the hardest thing for me to come by in this hobby. I did some calling around to glass shops in my area (Chicago suburbs) and found that a roughly 2'x2' piece of tinted glass runs about $40. I got lucky recently at the Milwaukee auction and won a huge pile (something like 60 pieces) of tinted glass and plexi for $15. Some of it was usable and some of it wasn't. I've been able to use 4 pieces so far in projects which would have been $160 had I bought through the glass place. I expect I'll be able to use another 7-8 pieces. You never know where that next deal will be.
I've got a fever...
NoOne=NBA=
« Reply #27 on: October 08, 2007, 06:41:56 pm »
I've never seen tinted glass/plexi that was too dark for use on an arcade cabinet.
Ask for the darkest stuff they have, and you should be fine.
That is assuming that their darkest is dark enough.
I've been to some places that didn't carry the dark tint, just medium and light.
Anybody else seen any glass that was too dark?
TOK
« Reply #28 on: October 08, 2007, 08:43:11 pm »
Tinted plexi w/19" LCD.
knave
  • Last login:October 15, 2025, 04:12:19 pm
« Reply #29 on: October 09, 2007, 12:39:44 pm »
If glass is hard to find in the correct tint would it be worth it to use clear glass with Tinted Plexi under it?  I'm just thinking this would keep your plexi from getting all scratched over time.
TOK
« Reply #30 on: October 09, 2007, 01:05:35 pm »
I don't think scratching plexi is a huge issue for home use. I have tinted plexi over my vert cabinet and I'm just very careful about cleaning it with a damp rag to avoid swirls, etc. Not sure if all tinted plastic is the same, but I was surprised how dark the stuff I got actually is. Had to turn the brightness up on the monitor a bit to get it looking good.
ElKootcho
« Reply #31 on: October 10, 2007, 10:32:54 am »
I'll be tinting over a TV monitor. So is darker tint better?
Wade
  • Last login:December 01, 2025, 08:21:17 am
  • 80's Child
    • Wade's Gameroom
« Reply #32 on: October 10, 2007, 01:01:14 pm »
It is definitely possible to have too much tint, especially when using a newer monitors because they almost always have a dark colored tube to begin with (versus the old tubes found in classic games, which were much lighter colored).
I have some plexi that is too far on the dark side.  I used it on a Simpsons mini cabinet and I had to REALLY crank up the screen control to get the monitor bright enough to look decent through the tint.  It is darker than all the tinted tempered glass that came original on some of my arcade games.
I have a pretty good sized stack of used tinted plexi, probably 8-10 sheets large enough for most arcade games, someone make me an offer (it will be fairly heavy/expensive to ship though).
Personally, I think tinted monitor glass/plexi is generally cheap and cheesey looking.  Tint was mostly used on classics back when the tubes were not tinted.  Modern games have tinted tubes and RARELY have tinted glass.
Wade
Level42
« Reply #33 on: October 10, 2007, 01:19:50 pm »
The darkest stuff would be completely black, guess you don't want to put that in front of your monitor  :laugh2:
There are HEAPS of colors available. Most are NOT transparant. But for those that are, there are some color options and at least various shades. Check this out (and this is just one manufacturer:
http://www.lucitesolutions.com/remote/viewdocument.cfm?documentFile=000%5F%2D%5FColour%5FSelector%5Fcopy1%2Epdf
I used color 923 (page 4 has the transparent colors on the left) which seems the darkest available there. It looks very good on my Galaxian. The original even was a little bit darker, but this can also be because of aging of course).
Also, there are various thicknesses available: 3mm, 5mm and I thin 8 mm. I guess the thicker the darker.
I got 3mm for both my Galaxian and my Star Wars. The thinner the cheaper of course, but less sturdy. However, you're not going to bang the plexi on your precious cab are you ? Also, the plexi on the SW is almost vertical positioned so it won't bend or anything....
« Last Edit: October 10, 2007, 01:25:41 pm by Level42 »
btp2k2
  • Last login:March 16, 2011, 01:02:36 pm
« Reply #34 on: October 10, 2007, 02:38:45 pm »
I went with clear on my cabinet, and I am wishing I went smoked.....having seen the differences....next one will be smoked for sure.
metahacker
  • Last login:January 17, 2024, 03:09:39 am
« Reply #35 on: October 10, 2007, 07:54:31 pm »
definitely tint.
i tend to think my picture actually looks better with it but i think its just my imagination since the cab is so much cooler tinted ;)
it at least conceals the un-authenticly flat crt that's in there now.  the bezel is now optional which is nice since it no longer fits without trimming ;)
« Last Edit: October 10, 2007, 07:56:25 pm by alexdog69 »
Wienerdog
« Reply #36 on: October 10, 2007, 11:25:25 pm »
I heard that Bolingbrook Glass was a good source, but I haven't called them yet.
SlammedNiss
  • Last login:Yesterday at 07:11:09 pm
  • Mine Drags the Ground!
« Reply #37 on: October 11, 2007, 12:19:21 am »
Window films will not stick to plastic. The plastic out-gases, and the tint will end up bubbling. If you go with plexi, just get it smoked to begin with.
If you have clear glass, and decide to get it tinted, you'll have to use a 35%-20% smoked film. Make sure it is non-metallized, or it will have a semi-refective appearance.
Spyridon
« Reply #38 on: November 13, 2007, 11:27:06 am »
Didn't see a response to this question.  I'm putting mine over a TV as well.  How dark can you go with a TV?
tophatne1
  • Last login:January 09, 2016, 12:05:15 am
« Reply #39 on: November 14, 2007, 11:09:22 am »
