Author Topic: setting up joystics without seeing bolts from CP top  (Read 1506 times)
BORIStheBLADE
  • Last login:February 03, 2012, 10:53:59 pm
« on: September 20, 2007, 09:29:53 pm »
So how does one setup their joysticks without seeing the bolts through the top of the CP ?
johnmax
  • Last login:January 04, 2009, 03:13:49 pm
Re: setting up joystics without seeing bolts from CP top
« Reply #1 on: September 20, 2007, 09:35:55 pm »
I countersunk the holes on the top so the bolt heads were recessed. Then with my panel overlay and plexi on top you don't see anything. Did the same with the trackball mounting plate too. Looks clean.
TOK
  • The Game Always Wins
« Reply #2 on: September 20, 2007, 09:36:36 pm »
Countersink t-nuts on top, and bolt the sticks from bottom.
  • Last login:November 07, 2025, 10:24:32 am
« Reply #3 on: September 20, 2007, 09:50:10 pm »
ok, I'm kidding. No one in their right mind would use Gorilla Glue.
Elmers is where it's at
  • Last login:September 20, 2025, 07:17:24 am
« Reply #4 on: September 21, 2007, 07:13:20 am »
I used 8/32 bolts, head on topside of panel, but countersunk into the wood, then covered with wood filler, sanded down smooth and painted. On the backside, I countersunk the nuts to hold the bolts in place, then more nuts to hold the joystick.
But I like the idea of the T-nuts, you can countersink them, on the front of the panel, wood filler over them.
These would require less work, and Im all for less work.
Here's a rough sketch of how I did mine: (I did this quickly with mspaint, so excuse the dimensions):
BORIStheBLADE
« Reply #5 on: September 21, 2007, 08:16:47 am »
Cool, The T-nuts looks like the way to go.
urbecrisch
  • Last login:March 30, 2025, 01:11:38 pm
  • I was the S**T back in '82
« Reply #6 on: September 21, 2007, 08:26:49 am »
I'm with Johnmax.  I too countersunk some bolts.  Super easy and looks clean.  Cheers!
MrMojoZ
  • Last login:June 25, 2009, 11:34:56 pm
« Reply #7 on: September 21, 2007, 04:19:28 pm »
What about a metal CP?  :o
ARTIFACT
« Reply #8 on: September 21, 2007, 05:17:49 pm »
same here.
