Author Topic: how to escape or pause mame without a keyboard  (Read 1684 times)
IceWish
  • Last login:November 23, 2007, 11:09:02 am
« on: September 15, 2007, 02:59:42 pm »
hey guyz i searched all over trying to find a complete control layout for the shift functions in mame and i cant find it anywhere. I know that using a jamma cabinet you can press certain key combinations to simulate "insert coin" and pause and escape and so on ...i cant find this info anywhere can anyone please help
ideft
  • Last login:February 11, 2012, 04:06:09 pm
  • "Mister, I suspect you to be a dope fiend"
Re: how to escape or pause mame without a keyboard
« Reply #1 on: September 16, 2007, 12:59:36 am »
The shift functions are handled by keyboard encoders and are not a part of mame.  What kind of keyboard encoder are you using, is it a jamma cabinet??  You can get a "shift" effect in mame however.  Just go into the setup menu(tab) and pick a control you want to customize.  Take "pause or  p" for example.   Edit the pause input to the keys that you want to use.  For example press "1 & Ctrl" at the same time.  The pause command now will only work when player 1 start and p1 button1 are pressed at the same time.  I hope this answers your question.
loadman
    • MaLa
« Reply #2 on: September 16, 2007, 01:03:13 am »
What he said...
If you are using j-pac for a jamma cab:
http://www.ultimarc.com/jpac2.html
Thenasty
  • Trade Count: (+17)
  • Last login:Yesterday at 11:40:37 am
« Reply #3 on: September 16, 2007, 10:53:33 am »
if you're not using an encoder, you can set up MAME for a COMBO KEYS (2 keys)  to do whatever you want.
Free VGA Breakout Cable
