Author Topic: Static/dust buildup inside of plexiglass...  (Read 4586 times)
JLR2000
  • Last login:December 28, 2025, 10:50:05 pm
  • There is NO Sanctuary...
    • WWW
« on: March 22, 2002, 11:09:39 am »
Not sure if anyone else has had to deal with this....I need to remove the plexiglass from my homebuilt cab due to the buildup of dust "spots" on the inside, between where the plexiglass and TV screen are.  My cab is coming up on 1 year old this summer and I've noticed that the dust spots on the inside are getting so bad that I need to open it up and clean it (not easy to do).  Anyway, I was wondering if anyone has had this happen and if there are any products I can use to help prevent it. Thanks for your input...
ArcadeFX
  • Last login:November 10, 2004, 11:16:56 pm
  • All the Dude ever wanted was his rug back!
    • ArcadeFX
Re: Static/dust buildup inside of plexiglass...
« Reply #1 on: March 22, 2002, 11:35:49 am »
Mine does the same thing.  My plexi is pretty easy to remove so I did not think it was a big deal.  I don't think there is much you can do about it since the static is always gonig to be generated by the monitor.  Is there any way you can modify your cabinet to allow easy access for cleaning?
Dave_K.
  • Last login:July 06, 2022, 03:27:30 pm
    • Arcade Fever
« Reply #2 on: March 22, 2002, 12:13:22 pm »
You should be cleaning your monitor and plexiglass with anti-static cleaner (made especially for monitors).  Otherwise you may build up a small charge on the plexi which can cause problems with your monitor.  By using the anti-static cleaner, I noticed it still collects dust, but not as quickly.
-Dave
darkmanx
  • Last login:May 29, 2003, 04:46:57 am
« Reply #3 on: March 22, 2002, 12:18:15 pm »
what if you actually sealed up that gap pretty good so no dust could get in there?
WHELP! As if you knew what an eternity was. Grovel before your true master!
drabbit
  • Last login:November 26, 2002, 01:33:27 pm
  • Keeps playing, and playing.....
« Reply #4 on: March 22, 2002, 12:20:29 pm »
Try using a wood cleaner spray like Pledge found in the US and Canada (maybe elswhere also). It's a spray cleaner and wax made for wood but when buffed is completly transparent.
Many people that have glasses use this stuff to clean them, it works better than antistatic/antifog glass cleaners.
Thenasty
  • Trade Count: (+17)
  • Last login:Yesterday at 08:40:02 pm
« Reply #5 on: March 22, 2002, 02:00:59 pm »
Hehe, then you might burn out the monitor cause there won't be any ventillation...
Free VGA Breakout Cable
1UP
  • Token Junkie
    • 1UPArcade
« Reply #6 on: March 22, 2002, 03:09:01 pm »
I think you could just put some weather stripping inbetween the monitor glass and your bezel, so nothing gets between them.  The monitor should still have plenty of ventilation in back though.
My other job...
JustMichael
  • Mmmmm!! Cheesecake!!
« Reply #7 on: March 22, 2002, 03:16:27 pm »
Forgive me for stating the obvious but if you are using a fan to blow air into the cab, why not stick a filter before or right after it so that all the dust gets filtered out before the air runs around in your cab.
darkmanx
« Reply #8 on: March 22, 2002, 05:03:11 pm »
i meant just seal the part around the front where the plexi is.....not encase the whole thing air tight lol.
JLR2000
    • WWW
« Reply #9 on: March 22, 2002, 08:39:06 pm »
It's actually a 27" tv in a homebuilt cab, there's no way to really "seal off" to keep the dust out.  Thanks for all the ideas though.  I will just clean it with an anti-static spray and continue to do so.... My next cab will account for an easier method of removing/cleaning.  Thanks again.
1UP
  • Token Junkie
    • 1UPArcade
« Reply #10 on: March 24, 2002, 12:20:46 am »
Somebody here put some kind of rubber weatherstripping around the front edge of the monitor (or TV) and pushed it all the way forward against the glass, to keep light from leaking in from the marquee.  Should work for dust as well.
My other job...
