Author Topic: gettin a bad case of alzheimers  (Read 2157 times)
soulblazer28
  • Last login:September 27, 2009, 09:12:17 pm
« on: May 02, 2007, 01:01:16 am »
Hello,
It has been nearly a year since I started on my cab and right now it is used as a fancy TV holder. Now that I am getting ready to finally finish the thing, I find myself at a loss of alot of knowledge.
What I really want to know is...
What are those things that hold the marquee and plexi in place?  Brackets?  Where can I find some cheap?  I had actually purchased some from E-bay last year but lost them.  I did a search and found nothing so I am obviously searching for the wrong thing.
Help!  :dizzy:
fjl
  • Pixels Rule!
DaveMMR
Re: gettin a bad case of alzheimers
« Reply #2 on: May 02, 2007, 06:03:13 pm »
I used white ceiling grid retainers that I painted (badly) black.   Cutting the fronts of them down so the marquee's top and bottom aren't hidden is next on the "TO DO" list.
EDIT: Bad picture due but the best I could do right now.
Oh yeah, I had to "stomp" on the top one to widen the inside angle.
« Last Edit: May 02, 2007, 06:12:31 pm by DaveMMR »
soulblazer28
« Reply #3 on: May 04, 2007, 07:50:21 pm »
Thanks for the replies.
Dave, thanks for the picture, I'll see if I can find some of these grid retainers locally.  I'd rather not order from Happ due to the minimum order and shipping costs.
Cheers!
fjl
  • Pixels Rule!
« Reply #4 on: May 04, 2007, 10:00:17 pm »
minimum order and shipping cost?
Crowquill
  • Last login:November 21, 2024, 09:42:17 am
« Reply #5 on: May 04, 2007, 10:09:27 pm »
I think they're generally referred to as "marquee retainer brackets". Pretty much every cab used different ones, but there are some generic ones out there. Out of my two cabinets, only one uses a bracket (the Atari one). The other uses a routed out edge to hold the plexi. Works quite well.
If you have the Happ part number, you might check with Ponyboy or Divemaster over in the B/S/T forum. They can probably get it for you and it usually costs less than ordering directly from Happ.
Using the drop ceiling rails is a good idea. I'll have to remember that for the future.
SGT
  • Last login:May 31, 2025, 10:10:32 pm
Ed_McCarron
« Reply #7 on: May 07, 2007, 11:00:18 am »
I got my retainers from divemaster127 here, for .15 an inch.  No promise if thats his current price, this was a year or so ago...
Glaine
  • Last login:April 24, 2013, 12:09:17 pm
« Reply #8 on: May 08, 2007, 11:24:39 am »
