Author Topic: Timoe's Mini Sticks  (Read 79107 times)
Kaytrim
  • I'm too nice a guy
Re: Timoe's Mini Sticks
« Reply #200 on: August 25, 2008, 04:02:51 pm »
The chemical composition is different.  Stains muddy the grain and figure of wood.  Dye will keep the grain and figure sharp and defined as you can see here.  If you are interested in purchasing wood dye look at rockler.com or woodcraft.com and search for TransTints.  The little bottles don't look like much but they are concentrated so you mix them with water or denatured alcohol to the desired strength.  I have used these myself with nice results.
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #201 on: August 26, 2008, 08:18:48 am »
Thank you Kaytrim ^, yes Transtint is what I used.
We used walnut for the Vewlix case just to be Extra Premium, for the weight and to be really solid.  The stick will be for wireless PS3, I believe.
massive88
« Reply #202 on: August 26, 2008, 10:08:30 am »
When making your boxes from MDF, what kind of treatment do you do for the paint?
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #203 on: August 26, 2008, 10:58:04 pm »
I don't use MDF anymore but when I did my treatment schedule was as follows:
Sand - 220grit
Mineral Spirits wipedown
Primer - Oil based Kilz spray
Sand - 220
Primer -
Sand - 220
Spray paint - 2 light coats
Clear coat spray - 2 light coats
Kaytrim
« Reply #204 on: August 27, 2008, 09:36:32 am »
Just wondering why you don't use MDF anymore.  I am considering the same choice.
TTFN  :cheers:
massive88
« Reply #205 on: August 27, 2008, 09:39:59 am »
Sand - 220grit
Sand - 220
Primer -
Sand - 220
Great!  Thanks for the info.
My first two sticks I have built from Oak, but on the second one (for a friend) we painted it.  If Im not going to stain or dye, I figure it might as well be MDF.  I dont care for any woodgrain to show on a painted box.
Thanks again for the information!
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #206 on: September 09, 2008, 08:34:47 am »
Specifications:
• Case is built from Morado hardwood with a hand-rubbed polyurethane mirror finish
• Sony PS2 Dual Shock 2 PCB
• Sanwa JLF joystick with under mounted dust cover
• Seimitsu PS-14-K snap in buttons
• Bull nosed and flame polished plexiglass top panel with plexiglass screws
• Includes TMO Signature plexiglass bottom panel
• Wired to a terminal strip and quick disconnects
• Case Dimensions 9” x 12” x 2.0" (at front) & 2.75" (at back)
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #207 on: September 09, 2008, 08:42:15 am »
Stunning :o
Wouldn't this look better without plexi on top though? I assume the PU coat would be tough enough.
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #208 on: September 09, 2008, 09:11:58 am »
But then I wouldn't have had an excuse to use the plexiglass screws  ;D
The whole style is sort of a blend.  Exotic hardwood, polished clear plexi (top, bottom, buttons, joystick) and japanese style.  Plus the customer has the option of art or decoration on the inside of the plexi.  :dunno
  • Last login:December 19, 2025, 12:57:19 pm
« Reply #209 on: September 09, 2008, 09:15:12 am »
Ehh... I wouldn't put art on that, not with that woodgrain pattern on top.  8)
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #210 on: September 09, 2008, 12:24:37 pm »
Yeah, putting art on it would be blasphemy  :P
fjl
  • Pixels Rule!
« Reply #211 on: November 15, 2008, 06:23:25 am »
Can I get a closer shot of those plexiglass screws?
Kaytrim
« Reply #212 on: November 15, 2008, 07:33:57 am »
Just an fyi.  Tim and Brie have opened a website to sell thier joystick cases.  They can be found at http://www.norrisarcadesticks.com/
Tim made the announcement over on shoryuken.com, but forgot to post here.   http://forums.shoryuken.com/showthread.php?t=165825
Good Luck guys :cheers:
Kaytrim
Gatsu
« Reply #213 on: November 16, 2008, 11:57:34 pm »
very cool. will have to check it out.
