Author Topic: Step by Step for a n00b  (Read 1200 times)
medavid16
  • Newbie
  • Last login:April 14, 2007, 11:13:56 am
« on: April 14, 2007, 11:13:56 am »
Can someone point to some threads or locations of a step by step how to build a Dreamcast Joystick? Starting from supplies needed, to wood-working a small frame, to cutting, solder points, etc. I'm comfortable with just about anything, I just need some guidance as to where and how.
Crowquill
  • Last login:November 21, 2024, 09:42:17 am
Re: Step by Step for a n00b
« Reply #1 on: April 14, 2007, 07:08:16 pm »
Trying to find something going step-by-step that's specific to Dreamcast might be tough but you should be able to find info on both hacking controllers and then building a desktop/stand-alone joystick base. Most desktop/stand-alone joysticks I've seen built are for Playstation, but with the exception of the pad you're hacking it's the same.
Good general info:
http://arcadecontrols.com/arcade_dreamcast.shtml
Good pad hacking info (lots of pics):
http://pmc.pixelhosting.net/mamecab/dreamcast.html
Thread where hacked pads were sold:
http://forum.arcadecontrols.com/index.php?topic=28955.0
Thread with pretty much the standard box construction:
http://forum.arcadecontrols.com/index.php?topic=53328.0
Thread with some good pics of building a slightly unusual joystick:
http://forum.arcadecontrols.com/index.php?topic=3811.0
I've never hacked a DC pad myself. I usually use a Pelican RealArcade PS2 joystick run through a DC Innovation PS->DC converter. The RealArcade has been modded to use a Happ Super joystick and standard Happ buttons. Works great. I also have adapters to use it on GC/Xbox and USB for PC. I'm guessing the GC adapter will also let me use it on the Wii I want to get later this year. It's definitely the most flexible solution. I also have the official Agetec Stick but hardly ever use it.
  • Last login:February 11, 2026, 09:22:22 pm
« Reply #2 on: April 14, 2007, 07:21:22 pm »
Good general info:
