Author Topic: Speech Plug-In (V1.5) In Development  (Read 25188 times)
Space Fractal
  • Space Fractal
    • Space Fractal
Re: Speech Plugin for MaLa 1(RC8)or above *FINISHED*
« Reply #40 on: March 30, 2007, 05:30:19 am »
Thanks for the PM.
I was know it was a joke about the * (since I say that it was funny to hear that).
He He.
Should been very simple to fix that bug.
loadman
  • Moderator
    • MaLa
« Reply #41 on: April 20, 2007, 01:19:13 am »
Ok this Plug-in needs a much needed update: ;D
* Speech to ignore special characters like * in Q*bert  ::)
* Enable 'Light & Speak' for Led-Wiz mod/ MaLa hardware users (like the led-wiz plug-in does)  :D  Eg Say Buttons use and light it at the same time  :applaud:
* Option to pause/resume music
* Shortcut button to speech on windows control panel
* Ability to test set-up before running MaLa
« Last Edit: August 12, 2007, 02:52:08 am by loadman »
squirrellydw
  • Last login:April 12, 2021, 11:30:22 am
Re: Speech Plug-In (V1.5) In Development
« Reply #42 on: April 20, 2007, 08:41:27 pm »
any benefit of using this if I use the ledwiz plugin?
I b**ch. People listen!!
loadman
  • Moderator
    • MaLa
« Reply #43 on: April 20, 2007, 09:13:06 pm »
Nah..  Its for the rest of us  :-)
(eg Cabs with No Led Controller or Mala Hardware/Led-Wiz Mod)
FYI
The Led-wiz plug-in will eventually have the option to also have speech on Start-up and Shutdown I think
« Last Edit: April 20, 2007, 09:53:35 pm by loadman »
loadman
  • Moderator
    • MaLa
« Reply #44 on: August 11, 2007, 10:12:07 pm »
One thing I would add to your plugin would be a button to open the Speech Properties window from Control Panel. The command line to launch it is:
Code: [Select]
rundll32.exe shell32.dll,Control_RunDLL "C:\Program Files\Common Files\Microsoft Shared\Speech\sapi.cpl",Speech
I am finally updating this plug-in but I am having trouble implimenting this idea without the use of a batch file.
I need a way of launching sapi.cpl from a delphi command.
I can launch other .cpls from delphi using the following but it does not seem to work with sapi
Code: [Select]
procedure Control_RunDLL(
      hwnd: THandle;
      hInst: THandle;
      CmdLine: PChar;
      CmdShow: integer
      ); stdcall; external 'Shell32.dll';
// Here are some examples:
//call the "Game Controllers" Applet
Control_RunDLL(Application.Handle, 0, PChar('joy.cpl'), SW_SHOW)
//call the "Keyboard Properties" Applet (contained inside the Main.cpl file)
Control_RunDLL(Application.Handle, 0, PChar('Main.cpl,Keyboard'), SW_SHOW)
//call the "Mouse Properties" Applet (contained inside the Main.cpl file)
Control_RunDLL(Application.Handle, 0, PChar('Main.cpl,Mouse'), SW_SHOW)
//call the Screen Saver tab of the "Display Properties" Applet
Control_RunDLL(Application.Handle, 0, PChar('Desk.cpl,,1'), SW_SHOW)
So I thought I would just use a command line but that does not work for sapi either
Code: [Select]
ShellExecute(Handle, 'open', 'C:\Program Files\Common Files\Microsoft Shared\Speech\sapi.cpl',nil,nil,SW_SHOWNORMAL) ;
So I have it working by Shell executing a batch file...But's it's ugly have the dos box pop up
Delphi Command:
Code: [Select]
ShellExecute(Handle, 'open', 'C:\sapi.bat) ;Batch File:
Code: [Select]
cd C:\Program Files\Common Files\Microsoft Shared\Speech\
sapi.cpl
Anyone fould a better way to lauche sapi.cpl from Delphi?  :banghead:
SGT
  • Last login:May 31, 2025, 10:10:32 pm
« Reply #45 on: August 11, 2007, 10:35:35 pm »
You can load other CPL files by using Windows' control.exe.  For example:
Start>Run>control main.cpl
So how about:
Code: [Select]
ShellExecute(Handle, 'open', 'control C:\Program Files\Common Files\Microsoft Shared\Speech\sapi.cpl',nil,nil,SW_SHOWNORMAL) ;
Edit:
Nope, control.exe doesn't like that path apparently as the string has spaces being parsed as parameters.
Start>Run>control "C:\Program Files\Common Files\Microsoft Shared\Speech\sapi.cpl"
Works
And
Start>Run>control C:\Progra~1\Common~1\Micros~1\Speech\sapi.cpl
Works
So what about:
Code: [Select]
ShellExecute(Handle, 'open', 'control C:\Progra~1\Common~1\Micros~1\Speech\sapi.cpl',nil,nil,SW_SHOWNORMAL) ;
« Last Edit: August 11, 2007, 11:03:37 pm by SGT »
loadman
  • Moderator
    • MaLa
« Reply #46 on: August 11, 2007, 11:40:39 pm »
So what about:
Code: [Select]
Thanks for trying. That should work but it doesn't
Nope ... Nuthin   :'(
SGT
« Reply #47 on: August 12, 2007, 12:16:38 am »
Seems like I'm batting -1000 lately.  Here's my last attempt.  According to this link:
http://delphi.about.com/od/windowsshellapi/a/executeprogram.htm
this works:
Code: [Select]
ShellExecute(Handle,'open', 'c:\windows\notepad.exe','c:\SomeText.txt', nil, SW_SHOWNORMAL) ;
therefore this should work:
Code: [Select]
ShellExecute(Handle,'open', 'c:\windows\system32\control.exe','c:\progra~1\common~1\micros~1\speech\sapi.cpl', nil, SW_SHOWNORMAL) ;
or this:
Code: [Select]
ShellExecute(Handle,'open', 'c:\windows\system32\control.exe','c:\Program Files\Common Files\Microsoft Shared\speech\sapi.cpl', nil, SW_SHOWNORMAL) ;
« Last Edit: August 12, 2007, 12:18:52 am by SGT »
loadman
  • Moderator
    • MaLa
« Reply #48 on: August 12, 2007, 01:30:45 am »
This one works!!!   :cheers:
Code: [Select]
The other version didn't, but who cares.  ;)
It's weird how you have to treat this .cpl differently  :dizzy:
Thanks SGT.  I owe you one   ;D
Here is screenshot of config maker (in progress)
« Last Edit: August 12, 2007, 03:43:12 am by loadman »
SGT
« Reply #49 on: August 12, 2007, 03:30:01 am »
Looks like Delphi would give you a way to add embedded quotes so that the string submitted to control.exe is enclosed in quotes.
Maybe this was what was needed (not that it matters now):
Code: [Select]
ShellExecute(Handle,'open', 'c:\windows\system32\control.exe','"c:\Program Files\Common Files\Microsoft Shared\speech\sapi.cpl"', nil, SW_SHOWNORMAL) ;
I guess its just because this cpl is not in a folder that is part of the current PATH?
No you don't.  I use the speech plug-in.
 :notworthy:
Looking good!  Great job!
« Last Edit: August 12, 2007, 03:45:32 am by SGT »
headkaze
  • 0x2b|~0x2b?
« Reply #50 on: August 12, 2007, 03:54:20 am »
I would say it was the double quotes too. That's why the DOS 6.3 way worked I guess. Glad you got it sorted :)
lettuce
  • Make It So!
« Reply #51 on: August 12, 2007, 05:27:30 am »
So when can we test this out  :applaud:
ARTIFACT
« Reply #52 on: August 13, 2007, 03:39:28 pm »
I'll have to try that!!
loadman
  • Moderator
    • MaLa
« Reply #53 on: August 13, 2007, 06:39:19 pm »
If the wife gives me some more code time  ::)
In a couple of weeks
youki
  • Last login:November 19, 2016, 01:07:33 pm
  • Atomic Front End Creator
    • Atomic Front End
« Reply #54 on: August 14, 2007, 03:09:36 am »
Do we have the same wife  ??? ???
 :laugh2:
loadman
  • Moderator
    • MaLa
« Reply #55 on: August 14, 2007, 04:57:00 am »
 :laugh2:
That would explain why we never have any 'special cuddles' anymore. You must be wearing her out  :laugh2:
headkaze
  • 0x2b|~0x2b?
« Reply #56 on: August 14, 2007, 07:26:22 am »
 :laugh2:
Comon guys don't get creepy on me!  :o
loadman
  • Moderator
    • MaLa
« Reply #57 on: August 30, 2007, 05:51:14 pm »
Beta version will be posted this weekend.   :)   Soon (but looking good  :) )
« Last Edit: September 02, 2007, 07:08:04 am by loadman »
SGT
« Reply #58 on: August 30, 2007, 05:56:12 pm »
You found some free time? Your wife must be out of town.   Where's Youki? ;D
« Last Edit: August 30, 2007, 05:58:56 pm by SGT »
loadman
  • Moderator
    • MaLa
« Reply #59 on: August 30, 2007, 11:07:43 pm »
She's having a 'Girls night out' so while the Kids sleep I will work on PC and have a beer  :cheers:
youki
    • Atomic Front End
« Reply #60 on: August 31, 2007, 07:45:50 am »
That's the problem. Honnestly, i prefer when she is with loadman... i have more time to work on Atomic!   ;D
But the good thing, is that she said me that she find Atomic more sexy!  ;)... She loves my "bling bling"!  :laugh2:
loadman
  • Moderator
    • MaLa
« Reply #61 on: August 31, 2007, 09:25:07 am »
Yeah...  I guess you are saying Atomic is for Girls   :laugh2:
SGT
« Reply #62 on: August 31, 2007, 09:27:51 am »
Oooh.......burn.   :laugh2:
youki
    • Atomic Front End
« Reply #63 on: August 31, 2007, 09:51:57 am »
 :laugh2: good one!
In fact, Atomic helps you to catch girls!   8)
Be sexy, Be Atomic!   ;)
loadman
  • Moderator
    • MaLa
« Reply #64 on: August 31, 2007, 06:38:14 pm »
:laugh2: good one!
Beta version release on this thread:
http://forum.arcadecontrols.com/index.php?topic=71503.0
« Last Edit: September 20, 2007, 07:50:57 am by loadman »
