Author Topic: i nedd repair this pcb  (Read 3260 times)
shinobi2
  • Last login:September 02, 2006, 09:10:51 pm
« on: August 29, 2006, 08:48:21 am »
 buys has punt jamma, and when the corner cam was broken, the doll of the average protagonist see gold and touching to the broken corner could worse gold better.    It takes it to to repair, they changed the 2 now to him integrated and not see nothing in movement, neither the personage, NOR the bad ones, NOR nothing.    So it takes it site to another, they changed the 2 again to him Chips and all equal one, does not see anything that moves.    I amndt desperate to fix it badly, and not that component this.
 I leave has Link you of the images of the punt and the screen.    I cuts made has test to the punt, roms ok, and all the test gives ok perfect and not that it edge happen to him.
  To see yew somebody orients to me gold knows that chip I must changes, yew necesitais goal photographs gold drank information please to Write to me to shinobi_dos@yahoo.es thank you very much.
  Link to relocates the text.  http://www.ea1uro.com/traductor.html, have it has French page yew anybody does not understand what I Write edge relocates it in this Web.
  please I need aid.    I leave has Link with photographs of my problem, this finished using spray cleaned of contact, for that reason some integrated are bad, goal perfect one is seen all.
[img=http://img233.imageshack.us/img233/74/01zx2.jpg]http://
  greeting and thanks has.
grantspain
Re: i nedd repair this pcb
« Reply #1 on: August 29, 2006, 01:05:13 pm »
hola amigo,
la placa tienes es no original,siempre estas placas(copier) problemas-lo siento mi espanyol es poco pero es possible no reparar esta placa,tienes otros?una cosa la volta de 5v necessario mas que 5.10 v d/c entrada la placa connector-por mas ayuda email LORD.HIRYU@GMAIL.COM ,el es espanyol,adios
« Last Edit: August 29, 2006, 01:14:59 pm by grantspain »
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #2 on: August 29, 2006, 02:59:26 pm »
The lesson here folks is... don't use automated translation tool. They just DON'T WORK!
NO MORE!!
grantspain
« Reply #3 on: August 29, 2006, 03:05:34 pm »
my reply is not automated,but i did just understand what he was saying thats why i have directed him to the spanish mame/arcade forum
Q*Bert_OP
  • Oh yes, we did!
« Reply #4 on: August 29, 2006, 05:03:25 pm »
shinobi2
« Reply #5 on: September 02, 2006, 09:10:51 pm »
In spain there isnt any place to help me to repair pcb. can you help me ?
grantspain
« Reply #6 on: September 03, 2006, 12:26:09 pm »
hora,tu ingles es perfecto!
where in spain are you?
have you tried mga in barcelona?
i know people in the u.k that repair game boards,but i think the biggest problem is the board is a copy and they are well known for these type of faults
Kevin Mullins
    • Me on Myspace
« Reply #7 on: September 03, 2006, 04:32:52 pm »
Yeah, I thought that also when i was reading this one last night. i have an original Sega Shinobi and I knew that one was a boot. (Beta, Beya, or whatever is says on screen)
The board layout is a bit different too.
I see that he has an adapter of some sort attached to the main connector. I know the Sega pcb is defineately not JAMMA. I was wondering if he had a problem there along with the broken corner bits. Not sure what that bootleg setup would be. From what I was gathering is that he can't control anything, like joystick and button functions and such.
Is that correct?
grantspain
« Reply #8 on: September 03, 2006, 07:03:05 pm »
he is missing all the foreground graphics,this is a common fault with these rip off boards and absolutely no point in trying to repair as they are crap(world cup 90 springs to mind,oh and spellunker)
Kevin Mullins
    • Me on Myspace
« Reply #9 on: September 04, 2006, 01:11:39 am »
Oh damn, if that's the case then those two little IC's he's concerned about probably have nothing to do with any kind of serious graphics issue like what you're describing.
grantspain
« Reply #10 on: September 04, 2006, 04:20:39 am »
be funny though if it was the ribbon connectors missing causing the fault,look at the pics-2 layers of board,no ribbon connectors ;D
Kevin Mullins
    • Me on Myspace
« Reply #11 on: September 04, 2006, 08:26:45 pm »
Now that would be funny...but seriously, it would probably be totally dead if that were the case.
Sounds like a graphics ROM is just not booting at all, bad, no power, etc.
Hmmm..... I wonder if those bootlegs have the suicide battery issues like the Sega boards do? I don't recall if they die completely or if they just develope issues.
(guess I should go look before mine does  :-\)
