Author Topic: Can I use 1/4" router bits in a 1/2" shank router?  (Read 1116 times)
  • Last login:October 17, 2025, 10:29:23 am
« on: July 17, 2006, 06:43:45 pm »
My router accepts 1/2" shank bits but most of the stores around here carry 1/4" bits. Is there an adapter of some sort? Or is there a better solution to this problem?
botman
  • Last login:May 06, 2009, 01:11:02 pm
  • There is no spoon.
Re: Can I use 1/4" router bits in a 1/2" shank router?
« Reply #1 on: July 17, 2006, 08:12:28 pm »
I think you are looking for a bit extension.  Something like this...
http://www.mlcswoodworking.com/orderstatus/html/smarthtml/pages/routcollet.html
MikeDeuce
  • Last login:September 15, 2013, 04:38:38 pm
  • It does a body good.
« Reply #2 on: July 17, 2006, 09:40:31 pm »
Depending on the router, you can sometimes find replacement collets in the other size.
So... whatcha got? :)
DrewKaree
  • HAH! Nice one!
    • A lifelong project
« Reply #3 on: July 17, 2006, 09:53:41 pm »
There's usually an adaptor that fits into your router's collet to change the size shank your router will accept.  It simply slides in and is gripped by the larger collet, which in turn tightens and grips the smaller-shanked bits.
Who makes your router and what model is it?
