Author Topic: 2/3 Scale Ms.Pac style Cab for Kids - OH! SNAP!!  (Read 15108 times)
JoyMonkey
  • Voodoo Wiki Master . . .
  • Last login:June 16, 2025, 09:16:27 pm
  • Candy is Dandy but Liquor is Quicker
    • JoyMonkey.com
« on: July 17, 2006, 07:46:18 am »
I was going to post this in AtomSmashers thread ( 3/4 Scale Pac-Man style Cab for Kids ) but figured I'd better make my own thread. I hadn't seen Atom's thread so it's pure coincidence that we both happened to do pretty much the same thing at the same time.
I went to work on Saturday and for whatever reasons, ended up having to be in the workshop with about 5 hours with nothing to do. So I clocked out and did the first thing that popped into my head, which was a full Ms.Pac/Galaga cab using one sheet of ultralight 3/4" MDF. I did do a little work on an old project that I really should finish, but I'm easily distracted and must have a little ADD.
I used 3/4" material because that's what I had at hand and so I could use regular t-molding. I redrew Jakobud's plans making them cnc friendly and scaled everything down 2/3 of the original size; this way the cab is about 44" tall and most of the parts will fit on a 4x8 sheet. To make assembly a little easier, I routed 1/8" deep grooves out of the interior surface of the cabinet sides that the various parts could slide easily into. After cutting I did a quick dry assembly to make sure everything fit okay, and it seems to hold together pretty solid, although I'll be adding some support braces to hold everything together anyway. I had to take it apart to cut the t-molding slots and this is where I stand right now.
I'm not sure who this cab is for, since I don't have any kids. My wife does love Galaga and we are short on space, so maybe I'll just keep it and mount it on a little pedestal so it'll be tall enough for us to play. Or I might give it to my cousins kids. Or it might just sit unfinished in the workshop for years to come like everything else I do, who knows?
Re: 2/3 Scale Ms.Pac style Cab for Kids - OH! SNAP!!
« Reply #1 on: July 17, 2006, 07:57:53 am »
Hey, if you want to sell one of those kits, I'd buy one.  Maybe more than one.
SirPeale
  • Green Mountain Man
« Reply #2 on: July 17, 2006, 08:07:43 am »
Yeah, hey, that's cool...and close enough to pick up.  How much would you want?
JoyMonkey
    • JoyMonkey.com
« Reply #3 on: July 17, 2006, 08:23:10 am »
If it works out well I'll definetly consider doing more. I might use melamine instead of mdf though, so the surfaces would need less finishing work (or wouldn't need finishing at all if you like black). But I've so much shite going on, I'd really like to get something finished before I start making more of anything else (remember my 99% complete Midway cocktail, my 75% complete original cocktail and the Centipede?).
I have no idea what a kit like this should sell for. Maybe $180 with the aluminum control panel (drilled to order), acrylic for the marquee and monitor bezel and some wood braces.
If I do make more of these, it's going to take a while. My workshop is about to pack up and move to another city, so everythings in chaos and I don't want to add more crap to it all.
The cab might look kind of naked without a coin door though. Any suggestions?
And what do you think is a good width for the front of this thing? Right now the pieces are 16" wide and 1/4" of that is recessed into the cabinet sides, so the control panel will be 15 3/4" wide and that's the space I'll need to squeeze a monitor of some kind into. Probably should have thought about that a little first, huh?
« Last Edit: July 17, 2006, 08:26:00 am by JoyMonkey »
« Reply #4 on: July 17, 2006, 09:27:01 am »
Yeah, definitely the monitor is the big consideration there.  If you want to to 19" you need to design it around that.  I wouldn't want to go any smaller than 15" for a monitor.  Of course, who says you have to design for a CRT?  These days it may be easier to stick an LCD in there, especially given how light you're trying to make the cab itself.  No point in making the cab light and then putting a heavy ass CRT in there.
My recommendation for the whole package would be to include all of the CNC based parts.  Let the buyer supply the rest.  And since it's a Pac, maybe eventually a small mylar stencil for it, since that's a CNC part too.
I wouldn't worry too much about a coin door.  Let the buyer track down a bartop coin door or something like that.  If you get that far into detail the cost is going to go far enough to limit sales.
JoyMonkey
    • JoyMonkey.com
« Reply #5 on: July 17, 2006, 09:35:40 am »
Now that I look at how all the dimensions scaled down, anything bigger than a 14" monitor will be too big. I measured an old 14" (at least I think it's a 14", maybe it's a 15") and it just about fits in perfectly. A 17" might fit in with the casing removed, but it's difficult to tell. I thought the front measurement would be the contraining factor on this, but it looks like it's the side profile that's going to make fitting a monitor a little tricky.
I think I'll confiscate this 14" monitor from the office since it hasn't been used in about 10 years  :D
Edit: Looks like a Ms.Pac/Galaga Reunion joystick will just about fit on the CP too. This is going to be tight, but it should work.
« Last Edit: July 17, 2006, 09:52:30 am by JoyMonkey »
« Reply #6 on: July 17, 2006, 10:10:55 am »
Would a CRT make that thing really top heavy?  You don't want kids playing a cab they can pull down on top of themselves.  They'll do it.
Knievel
    • Knievel Kustoms
« Reply #7 on: July 17, 2006, 10:14:04 am »
Must be nice to have access to that equipment.  :)
I think an LCD monitor would work well in there, maybe mounted so it's almost vertical. The 19" I just bought is only 16" wide so a 17" LCD would probably fit your cabinet.
It's another option to suggest anyway, if you do start selling kits to people.
JoyMonkey
    • JoyMonkey.com
« Reply #8 on: July 17, 2006, 10:24:26 am »
I'm not sure. The monitor is just above the center of gravity and there'll be a PC in the very bottom to add to the lower weight. I could always use full weight MDF for the base panel and a lighter material (maybe 1/4" plywood) for the top and upper section of the back. The cabinet itself is ultralight mdf, but it's still not feather light - the ultralight mdf parts weigh about 60lbs.
JoyMonkey
    • JoyMonkey.com
« Reply #9 on: July 17, 2006, 10:36:34 am »
Yeah, the machinery is nice to have, if only I had more time to play with it.
Looks like this 15" LCD would just about fit, but if the monitor is mounted vertically (I would think that's the way most people would want it) the viewing angle would be only 110
« Last Edit: July 17, 2006, 10:40:00 am by JoyMonkey »
JoyMonkey
    • JoyMonkey.com
« Reply #10 on: July 17, 2006, 11:02:02 am »
Here's the CP layout I'll probably be doing for this. Simple 1 button layout (for left or right handers), reunion 4-way stick and some Happ miniature momentary contact buttons for the player start buttons.
I'll be running DOS and GameLauncher and the following vertical games (using Paige's List of 4-Way Vertical games as a reference);
Amidar
Anteater
Burger Time
Dig Dug
Donkey Kong, DK Jr & DK3
Frogger
Galaga & Galaxian
Mr.Do! & Mr.Do's Castle
Ms.Pac-Man
Pac-Man
Pengo
Qix
Space Invaders
Super Bagman
« Last Edit: July 17, 2006, 11:31:51 am by JoyMonkey »
Knievel
    • Knievel Kustoms
« Reply #11 on: July 17, 2006, 11:18:18 am »
AtomSmasher
    • Atomic-Train
« Reply #12 on: July 17, 2006, 11:23:48 am »
I guess mini pacman cabs really are the current fad.  The problems you noticed with the lack of monitor and control panel space confirmed a few of my concerns.  I was considering changing my design to a mini Lusid cab, and now I think I'm definately going to switch.  Looks like you'll still be able to make it work, but I really want to have a trackball on there for the kids.
Should be a good looking cab when your done.
  • Last login:Yesterday at 02:56:06 pm
« Reply #13 on: July 17, 2006, 11:57:47 am »
Wow - all that in 5 hours?  You have some serious skills.  Mini-Pac-man cabs really are all the rage.  I'm going to be starting one soon too but I'm going to be painting it pink to match my daughter's room and putting flowers and crap on the marquee to make it as girly as possible.  She's almost two and I've been dying to get her started...
I'll definitely be following your progress...
JoyMonkey
    • JoyMonkey.com
« Reply #14 on: July 17, 2006, 12:04:53 pm »
Here's one from a few years back that's pretty much exactly the same size as mine;
http://forum.arcadecontrols.com/index.php?topic=29278.0
I notice Keith angled the monitor up a little though. I'll have to see what the best way of looking at the monitor is from a sitting position; I'd imagine with the way his monitor is angled it might be difficult to see the top of the screen if your head is slightly above the marquee. His viewing angle allows a larger (17") monitor to fit easier though.
Hmmmm...
Stingray
« Reply #15 on: July 17, 2006, 01:40:23 pm »
Nice work, JM!
-S
« Reply #16 on: July 17, 2006, 01:58:53 pm »
I love this one - it's actually what inspired me to build a mini-ms. pac-man someday.
Jabba
  • D-Hutt
  • Last login:November 16, 2020, 02:17:20 pm
  • I find your lack of faith...disturbing...
« Reply #17 on: July 17, 2006, 02:31:40 pm »
Lookin good there JoyMonkey. I'll definately keep track of this thread.
Vids:  Home built MAME machine, Crystal Castles. Arkanoid
Pins:   Williams Aztec (working). Stern Nugent (not working...yet), Williams Phoenix (major not working, missing parts.... )
Always on the lookout for buying 90's game with Ramps that need work...
MameMaster!
  • Engage number one!
    • Mame Invaders!
« Reply #18 on: July 17, 2006, 04:08:01 pm »
Nice!.....now the hard part kicks in!....details details.
Have fun with your project!  :cheers:
SirPeale
« Reply #19 on: July 17, 2006, 09:11:18 pm »
How much just for a piece of $15 MDF strapped into the machine, you hit the button, it cuts the parts while you walk away?  I'm handy.  I can make the rest.
Either a 1/2 height door or heck...a full size Midway door.
JoyMonkey
    • JoyMonkey.com
« Reply #20 on: July 17, 2006, 10:36:12 pm »
A lot of people think cnc routing is this easy, I wish it were. Setting up path strategies is a complicated process, though if I'm duplicating the same thing I only have to do it once and its something I like to think I'm good at. That said, there's no hitting a button and walking away from a machine that costs almost as much as my house; I have to stay there and sweat it out with the machine as it cuts; make sure it keeps sucking material to the bed where its supposed to, keeping depths uniform, making sure it doesn't arc too quickly through too much material, clear the machines path for tool changes, blah blah blah.
I've walked away to take a phone call and come back to find it mashing a 2" block of aluminum into its own bed and I'm glad I didn't have to touch the bill for that myself. The machine has also thrown large pieces of aluminum at me as they lift from the vacuum; as if it's trying to kill me  :-\
SirPeale
« Reply #21 on: July 17, 2006, 10:55:22 pm »
Okay, you already got the one, I can see the pieces.  How much, how much, how much!  How much casssssssssssssssh.
Ah no, I've been drinking again...
BlinKY1337
  • Last login:October 25, 2013, 11:06:36 am
« Reply #22 on: July 18, 2006, 01:14:59 am »
lucky kids, this is way better then hungry hungry hippos  ;D
zorg
« Reply #23 on: July 18, 2006, 04:13:02 am »
you can check http://www.minimame.com
it's the home of mini-pacman (70% scaled)
I'm on the planning stage
JoyMonkey
    • JoyMonkey.com
« Reply #24 on: July 18, 2006, 08:28:08 am »
Not sure how this happened, but I've never really worked on MDF by hand before. Never. Life just goes by with me being completely oblivious to the stuff.
Yesterday after work I went to cut the t-molding slot on both sides of the cabinet and my whole body ended up with a nice even coat of mdf dust. I knew well enough to wear a face mask, but take a look at this photo- my arm hair isn't usually that crusty looking.
 :P I also took a very noticeable chunk out of the front of one of the panels (see below). Do I just use something like Elmers Wood Filler to fill this up?
And why is there no mention of MDF in the wiki yet? It seems like 90% of projects here use MDF, so I thought there'd be at least a mention of it in the wiki by now. I found some nice tips on priming and sanding the mdf to a nice smooth surface here. If all goes well with whatever method I choose, I'll put together a quick wiki page on working with and finishing MDF. I'll probably buy some shellac primer and see how well it does on some scrap MDF to start with. Or I might just go and ask my paint dept, but every time I ask them something I end up sounding like an idiot somehow *shrug*
« Last Edit: July 18, 2006, 08:32:10 am by JoyMonkey »
« Reply #25 on: July 18, 2006, 08:32:11 am »
You can't fill an edge like that.  You'll have to reform it using Bondo.  Luckily that's not a complicated thing, just takes a bit of practice to get a feel for Bondo.
JoyMonkey
    • JoyMonkey.com
« Reply #26 on: July 18, 2006, 08:35:22 am »
Another thing, I was at the local arcade last night and they've got two Ms.Pac cabs and a Galaga. I noticed that the tip of the front that I took the chunk out of isn't pointed like I've got it; it's got about a 1/2" corner radius.
So maybe I'll just round it off and be done with it.
Havok
  • Trade Count: (+17)
« Reply #27 on: July 18, 2006, 03:56:49 pm »
JoyMonkey
    • JoyMonkey.com
« Reply #28 on: August 04, 2006, 12:46:56 pm »
I'll be cutting and bending the control panel for this sucker tomorrow. Here's my initial layout with one fire button (for leftys or rightys) and a Namco Reunion joystick.
JoyMonkey
    • JoyMonkey.com
« Reply #29 on: August 05, 2006, 05:08:00 pm »
Here's a revised version cut from melamine. I wasn't 100% happy about some parts of the first one I did, so restarted the plans from scratch.
I threw the pieces together real quick to make sure everything fit like I hoped and it looks like I got everything right   :cheers:
Sorry about the poor photos, my camera phone isn't exactly the best.
psychotech
    • psychotech
« Reply #30 on: August 05, 2006, 08:48:20 pm »
That's Kool. :cheers:
« Reply #31 on: August 06, 2006, 11:07:47 am »
That plexi slot looks like it's going to work well.
JoyMonkey
    • JoyMonkey.com
« Reply #32 on: August 06, 2006, 12:45:55 pm »
Yeah, I tested it out with a piece of 3/16" plexi (not cut down to size) and it slides in really nicely. I'm thinking I could probably use a similar slide-in style for an aluminum monitor mounting plate, I'll have to de-case a couple of old monitors and see which one to use first though.
« Reply #33 on: August 07, 2006, 02:12:24 pm »
What size monitor do you think will fit?
JoyMonkey
    • JoyMonkey.com
« Reply #34 on: August 08, 2006, 10:21:17 am »
I have an old 15" monitor here with giant casing around it that I'm planning on mounting vertically in there (turning the monitor 90 degrees on its side for vertical games). I'm hoping a standard 17" monitor will also fit. According to Dell's measurements of their 773 series CRT's, one of those should fit fine horizontally, but I'm not sure about vertically without de-casing it.
« Reply #35 on: August 08, 2006, 12:01:42 pm »
It's not just the CRT measurement, though.  You also have to account for whatever mounting brackets will be used.  The CRT is just the glass tube.
JoyMonkey
    • JoyMonkey.com
« Reply #36 on: August 08, 2006, 12:58:32 pm »
I'm aware of that. When I say CRT, I mean a CRT based monitor, I'm not talking about just the CRT on its own.
Level42
« Reply #37 on: August 10, 2006, 11:32:45 am »
Any clue on how much T-molding will be neccesary for a cab like that ?
JoyMonkey
    • JoyMonkey.com
« Reply #38 on: August 10, 2006, 12:10:38 pm »
About 20ft; and T-Molding.com sells it in 20ft lengths, so I got lucky there.
simcomm
  • Last login:March 20, 2016, 07:21:16 pm
« Reply #39 on: August 10, 2006, 07:00:39 pm »
I built a 75% scale pacman about a year and a half ago, so i wouldn't mind building a ms. pac / galaga version.
Are you going to sell kits?
Any more progress pics?
