Author Topic: Problem mounting TurboTwist spinner  (Read 1348 times)
lettuce
  • Make It So!
« on: May 29, 2006, 06:21:26 am »
Im having a slight problem mouinting my TurboTwist spinner. Im using 1/2" MDF for my CP, and the shaft on the spinner doesnt seem to be long enough to go through the MDF and attach the plastic top of the spinner over the MDF. How is the spinner top surpposed to sit on top of the CP, right flat to the CP or so you can see narrow bottom part of the spiner top aswell??
Fozzy The Bear
  • Handbags at dawn in here!!!
  • Last login:September 18, 2011, 11:29:59 am
  • It's Been One Of Those Days... Don't Ask!
Re: Problem mounting TurboTwist spinner
« Reply #1 on: May 29, 2006, 07:18:10 am »
It's designed for metal CP's ...... But you can rout the top surface of the panel to the depth of a mounting plate and mount the spinner on that, to get it to sit flush.
Best Regards,
Julian (Fozzy The Bear)
Most bottles and jars contain at least twenty-five percent recycled Pacman.
And research indicates that Space Invaders are strongly attracted to people who have recently eaten meat pies.
lettuce
  • Make It So!
« Reply #2 on: May 29, 2006, 08:50:51 am »
Is there a mounting plate for the turbotwist??
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #3 on: May 29, 2006, 09:45:05 am »
There are two(2) set screws on the weight of the turbo twist.  You will need an allen wrench to loosen them.
Loosen them and slide the shaft up to the height you need then re tighten them.
RandyT
    • GroovyGameGear.com
« Reply #4 on: May 29, 2006, 11:00:00 am »
CAUTION:  Only loosen the set screw nearest the knob.
You can then adjust the length of the shaft to accomodate both metal and wood control panels.
RandyT
