Author Topic: animated frontend... sorted mamewah help needed...  (Read 1829 times)
elecdojo
  • Last login:May 28, 2009, 03:10:39 pm
  • Are you ready...
    • electronicdojo
« on: May 22, 2006, 02:47:58 pm »
im after a front end which will allow you to use an image to select a game rather than line of txt.... i understand for loads of games this would be pointless but i only want to add around 10 games max to this front end....
ok i got a animation of the upcoming sf anthology i want this idea but without the arrows... the pictures can either move into view or just click over like page...
anyone seen this on a frontend?
« Last Edit: May 22, 2006, 04:56:01 pm by elecdojo »
-for all your street fighter arcade info... ask here-
2600
Re: animated frontend?!?!?
« Reply #1 on: May 22, 2006, 03:29:08 pm »
I would say a lot of FE's can do this.
Dragon King and 3darcade can do pretty much anything.   I think DK even has sample skins that do something close to this.
I don't see why MAMEWAH couldn't.
AtomicFE? probably.
With 3Darcade and DK you would have more control, but I think the others could handle this pretty easily as well.  Depends how much control you want.
elecdojo
  • Are you ready...
    • electronicdojo
« Reply #2 on: May 22, 2006, 03:48:27 pm »
theres doesnt need to be really any control... just a pure left/right control with start to begin... child easy...
Thenasty
  • Trade Count: (+17)
  • Last login:Today at 11:38:03 am
« Reply #3 on: May 22, 2006, 03:51:57 pm »
check my page. I use Advmenu. Here is a still shot of one of the game.
« Last Edit: May 22, 2006, 03:55:23 pm by Thenasty »
Free VGA Breakout Cable
elecdojo
  • Are you ready...
    • electronicdojo
« Reply #4 on: May 22, 2006, 03:53:54 pm »
im having a go with mamewah atm... i done that sort thing before just need to go REALLY basic now..
elecdojo
  • Are you ready...
    • electronicdojo
Re: animated frontend... sorted mamewah help needed...
« Reply #5 on: May 22, 2006, 04:57:13 pm »
ok sorted it... need some help with MAMEWAH though.... how do you get from A to Z by going up instead of all the way through the alphabet?
is there something in the ini files i can change?
youki
  • Last login:October 12, 2025, 12:33:39 pm
  • Atomic Front End Creator
    • Atomic Front End
« Reply #6 on: May 23, 2006, 04:05:01 am »
If you decide to use Atomic, i can do this kind of layout for you without problems.
I can even make "Arrow" dynamic. (the arrow can be show only if there are still some game in the direction)
Just ask me.
elecdojo
  • Are you ready...
    • electronicdojo
« Reply #7 on: May 23, 2006, 05:28:37 am »
yeah that would be great... could you have a go for me?
i would rather the games continusly cycle round the alphabet than stop on A is that possible?
youki
    • Atomic Front End
« Reply #8 on: May 23, 2006, 06:26:25 am »
I can not make cycle round easly  the list in the current version of Atomic. (that 's a feature on my to do list).
So if you want i start , i woud need few information.
What resolution you want for your layout?
Can you send me by mail , Arrows pictures?  and others Artworks you want.
May be you can desing your layout , create a simple static picture  of the visual result you want.  And then you send me the images , and i will make the layout script for you.
2600
« Reply #9 on: May 23, 2006, 08:10:03 am »
It's been a while, but...
**mamewah.ini**
wrap_list   1
elecdojo
  • Are you ready...
    • electronicdojo
« Reply #10 on: May 23, 2006, 08:43:54 am »
2600: thanks that worked a treat  :)
youki: sorted it in mamewah now... thanks for the offer though... until a animated menu system is developed then ill use this, if you ever add this feature to Atomic then let us know :)
youki
    • Atomic Front End
« Reply #11 on: May 23, 2006, 09:32:09 am »
You can already do Animated menu in Atomic.
For now, you have to use Scripting feature , but if you can describe me what kind of thing you would like , i can try to introduce that as component.
elecdojo
  • Are you ready...
    • electronicdojo
« Reply #12 on: May 23, 2006, 09:35:00 am »
as you can see from the ani.gif i did above, when you press right or left the picture in the background moves to the main artwork... make sense?
youki
    • Atomic Front End
« Reply #13 on: May 23, 2006, 11:02:53 am »
I can do exactly that with Atomic.
