can anyone tell me if ems are planning a 2 player option .
Forget that this driver exist, and use the Smog drivers.
are there people out there using smogs driver on windows xp to play pc house of the dead 2 i cant get it working. i want to talk to 812 many to tell me what you did when you erased the other drivers to get your guns working using smogs.can anyone help me .
With your system, you can install de lastest Smog drivers (v9b6). There are many bug fixed (also there are others not).
I installed the drivers and then plug the gun. Windows detected like guncon2 and installed the Smog drivers.
It could be that windows recognizes the gun like guncon2 but don't install the smog drivers. If this is your case, you must go into de control panel->system, locate the guncon2 device and update the drivers, pathing the smog drivers directory.
To use PC hod2 with two guns, you need the troubleshooter. Read the program instructions for more details.
Don't discourage.
![Wink ;)](http://newforum.arcadecontrols.com/Smileys/default/wink.gif)
