Author Topic: WOW New LightGUN Info !!! Woot!!! :)  (Read 605504 times)
MacroX
  • Last login:October 09, 2007, 11:27:30 pm
Re: WOW New LightGUN Info !!! Woot!!! :)
« Reply #1600 on: May 02, 2006, 10:30:22 pm »
There have few lines connected between the cam(cmos) and the board, it is very easy to see which one be broken, modify it by yourself.
Have someone post the image of cam here before!
Or you can solder the Cam(cmos) by yourself if you know how to do it.
The Cam?  I do not know what is broken. Could not be hurt another thing?  ???
I think I will go to see a friend who works repairing TV
aljupy
  • Last login:October 23, 2011, 07:30:06 pm
« Reply #1601 on: May 03, 2006, 12:16:56 am »
I know, but I do not know what is really broken, I do not know if it is really the cam what is broke.
the image was from RANDY-T around page 19-22
If I have to pay only for the Sending to Asia.... then I will ask to change it.  THANKS FOR THE INFO RYOLAZAROVICH.
The thing that it could be Very expensive is to pay Sending+Receiving.
THANKS ALL FOR YOUR HELP!!!!!!!!
812MANY
  • Last login:June 14, 2006, 08:54:25 pm
« Reply #1603 on: May 18, 2006, 12:20:33 am »
Is my new gun broken?? :-[
I finally got my 2nd gun and It won't track or register button presses.  I am using smog's latest drivers (tried previous one too), windows xp sp1.  My old gun works great, it tracks the cursor, all the buttons register in the guncon2 control panel and it works in mame.  When I plugged my new gun in, it was recognized and the drivers installed just fine.  The switch is set to "P".  Hardware calibration went fine.  However, in windows it wont track the cursor and the button presses won't register.  Won't work in mame either obviously.
I tried switching the guns on my usb hub and the old gun works under the new gun's settings but the new gun won't work under the old  gun settings.  I uninstalled and reinstalled the driver and still no luck.  I even tried the previous version of smog's driver.  Should I try the EMS drivers that came with the gun or does it sound like I should return this gun?  It seems to me that I have installed it correctly and switching them on the usb hub with no luck indicates that it is not functioning correctly.  I also tried uninstalling both guns and the driver and starting fresh and only installing the new gun but it didnt help.  Any suggestions?  Should I return it?
Smog
  • Last login:April 30, 2007, 06:50:51 am
  • .357
    • How to make a cheap GunCon2 work on your PC
« Reply #1604 on: May 18, 2006, 07:58:48 am »
I guess the best you can do is try it in a ps2 or xbox before returning it.
GunCon2PC Driver on http://guncon2pc.no-ip.org/
mhermann
  • Last login:October 04, 2019, 07:10:08 pm
  • We ain't found.........
« Reply #1605 on: May 18, 2006, 04:22:29 pm »
Try not using the USB hub. People have had problems with them in other things besides light guns. I know my trackball does not work with a hub even though at one time it did.
Hubs are sketchy. That is what I would suggest though.
812MANY
« Reply #1606 on: May 18, 2006, 05:27:50 pm »
tried it on my xbox and damnit it works.   :banghead:
I don't know what i'm doing wrong.  Is there some vital setup step that I am missing? I already have one gun setup properly.  All I had to do for the new gun was to plug it in, let the drivers install for it when it is recognized as a guncon2 device,  hardware calibrate, then set it up in guncon2 control panel right?
I'll try it plugged straight into the pc and also into another usb hub.
812MANY
« Reply #1607 on: May 18, 2006, 08:21:50 pm »
I got both guns working YAY! ;D
I uninstalled and deleted all traces of the guncon2 driver, found some wingun leftovers from a previous uninstall and deleted those as well  and then I reinstalled the latest guncon2 drivers (thanks smog)  and installed both guns from scratch and all is well.  Thanks to those who responded.
812MANY
« Reply #1608 on: May 19, 2006, 10:29:13 am »
With 2 lcd topguns in use am I allowed 4 inputs for each gun or 4 inputs shared between both guns?  Just because in the guncon2 control panel it assigns button1 and button2 for the first gun and button3 and button4 for the second gun and its something I cannot change.
Cananas
  • Last login:August 27, 2017, 07:39:03 am
  • and the seventh day... PacMan was created
« Reply #1609 on: May 19, 2006, 12:33:24 pm »
Check the ActLabs Compatibility button. If it pressed, you can't change the configuration of the first and second button of your gun.
BTW, the buttons of the guns are independent. The first gun is a mouse and the second gun is another mouse. So 4 buttons for each one.
812MANY
« Reply #1610 on: May 19, 2006, 01:27:57 pm »
I'll check it out as soon as I get home from work today.  I was wondering why it wouldnt let me change the inputs for the first 2 buttons of each gun.  Thanks for the help!
812MANY
« Reply #1611 on: May 19, 2006, 08:43:07 pm »
Thanks Cananas, I did have the Actlab Compatibility button on.
I can shoot offscreen to reload in Area51 but it won't work in Lethal Enforcer 1 & 2
I have tried assigning the reload function to button2 and that works in Area51 also but again not in Lethal Enforcer 1 & 2
Am I the only one having this problem?
Chazz
  • Last login:January 29, 2020, 01:14:53 pm
« Reply #1612 on: May 23, 2006, 12:08:15 pm »
Dang, Dang, Dang....   :banghead:
Everything was working great, but now I'm having problems.
If I use the recoil the gun dies after one shot.  It fires, and recoils once, then nothing.  I bought a new powered USB hub, but it didn't help.  I even pulled it into my Xbox and I get the same thing.  The gun works fine if I don't use recoil.
Is this a problem with the gun?  Drivers?  USB problem?
Any suggestions would be great!
Hudson187
  • Last login:August 20, 2013, 10:05:28 pm
« Reply #1613 on: May 23, 2006, 01:34:32 pm »
I had the same problem after a few months. I am using mame32 .101 and the ems driver (latest). The recoil and gun have been working excellent up until the gun died. I realized it was the recoil that was killing it, so I disabled the recoil and super glued the top so it couldnt be pulled back during gameplay (because doing that will kill the gun too). I am going to investing in 2 more after I get my cab complete (still need coin door and tweaking of software).
MiKman
  • Last login:September 15, 2025, 07:58:44 pm
  • Blah
« Reply #1614 on: May 23, 2006, 02:17:56 pm »
Does anyone know if there is a Canadian distributor for these guns?
djll
  • Last login:September 28, 2009, 04:26:13 pm
« Reply #1615 on: May 23, 2006, 10:07:23 pm »
What;s the cheapest price that you guys have found for the guns?  I've found three sites and all are foreign and charge shipping that costs as much as the gun...
PhoneGuy
  • Last login:June 02, 2020, 01:34:56 pm
  • Crazy
« Reply #1616 on: May 23, 2006, 11:14:21 pm »
Just got one from cliffracer, $41.50 shipped.  I believe from Michigan. Shipped fast, packed well.
http://www.cliffracer.com/store/
Jandaman http://www.jandaman.com/ said he was ordering some but they have not showed up on his website yet. He has low shipping fees and good customer service if he does end up selling them.
« Last Edit: May 24, 2006, 05:48:20 pm by PhoneGuy »
horseboy
  • Only Saint has those powers.
  • Last login:March 07, 2021, 02:19:14 pm
  • With my last breath, I curse Zoidberg!
« Reply #1617 on: May 23, 2006, 11:49:00 pm »
Cliffracer is probably the way to go. I think you should probably do it quick if you are going to get these. I figure that he didn't order a ton. And the fact that the BYOAC community know someone in the states has some, I figure they will go fast. He will probably get more, but containers take at least 4 weeks to get over here.
Quote from: saint
saint is all powerful.
Apparently he is.
djll
« Reply #1618 on: May 24, 2006, 12:44:41 am »
Thanks guys!
joe35car
  • Last login:November 26, 2025, 03:59:45 am
« Reply #1619 on: May 24, 2006, 08:31:13 pm »
I just ordered 1 gun and was wondering what driver I should use.  the smog's gunconpc or acorns wingun.  I have a xp pt 3.4.  I also would like it to reload of screen.  thanks alot.  just want to know which one works best. Oh also how does everybody like the gun? I'm using windows command line mame .106 with mamewah as frontend if it matters.
« Last Edit: May 24, 2006, 08:40:15 pm by joe35car »
Cananas
« Reply #1620 on: May 25, 2006, 01:08:17 am »
I suggest you use the last version (9b6) of the Smog guncon2pc drivers.
rumpelstiltzkin
« Reply #1621 on: May 26, 2006, 02:18:14 pm »
hi i got 2 lcd topguns for my house of the dead 2 on my pc . i tried ems3.2 and it worked great but i want 2 player so i used winggun and trouble shooter but the lag was unplayable. so i downloaded smogs as i heard it was best for people in my position but it wouldnt register my guns so i went to hid devices but it didnt show my guns plus before i got smogs i removed ems and wingun . i use windows xp please help im new to pcs simple english no computer lingo i might not get you :cry:
dougman
  • Last login:February 10, 2007, 01:15:46 pm
« Reply #1622 on: May 26, 2006, 02:22:46 pm »
I don't think anyone got these things to work properly in mame.
Someone needs to make a setup instructions for mame for these guns.
I had these guns for over a month, and I still cannot get them working, I can usually get player 1 to work erratically, but not player2.  The lack of instructions is ridiculous.
The only time I got them both to work was on Xbox house of the dead.
ErikRuud
  • Last login:March 05, 2021, 10:20:27 am
« Reply #1623 on: May 26, 2006, 02:28:31 pm »
There are a number of people that have these working very well.
There are three different sites with setup help.
American Laser Games Wrapper
O2em Rom Utility
Smog
  • .357
« Reply #1624 on: May 26, 2006, 02:51:12 pm »
The most common problem people is having is the mess left from EMS/wingun drivers installation/disinstallation.
The system works in mame like a charm and, dougman, it was probably your fault not anyone's.
« Last Edit: May 26, 2006, 02:55:44 pm by Smog »
rumpelstiltzkin
« Reply #1625 on: May 26, 2006, 03:42:39 pm »
i dont no if you were responding to me smog above dougs quote but anyway how do completely get rid of ems winggun crap . i got rid of mine with add remove programs but if there are ways to totally get rid and start smog fresh please tell . im a total novice  :dizzy:
Smog
  • .357
« Reply #1626 on: May 26, 2006, 05:53:17 pm »
@rumpelstiltzkin
I was not answering you, sorry
If I knew how to get rid of them I would have told you believe me ... try to use the "system configuration backup" (I think this is the right translatio in english)  or try to delete the latest driver / . inf files installed ...
rumpelstiltzkin
« Reply #1627 on: May 27, 2006, 05:29:57 pm »
i done system restore and tried again but it said the file was invalid and corrupt.   please help anyone :banghead:
rumpelstiltzkin
« Reply #1628 on: May 28, 2006, 02:29:35 pm »
are there people out there using smogs driver on windows xp to play pc house of the dead 2 i cant get it working. i want to talk to 812 many to tell me what you did when you erased the other drivers to get your guns working using smogs.can anyone help me .
rumpelstiltzkin
« Reply #1629 on: May 28, 2006, 02:32:49 pm »
can anyone tell me if ems are planning a 2 player option .
DigDreams
  • Last login:March 07, 2007, 04:37:08 am
« Reply #1630 on: May 28, 2006, 11:10:37 pm »
I had the same problem when I first got mine.  I was about to return it when I figured I'd take it apart and see if I could fix it.  The slide removes pretty easily, onece it's off try and fire the gun.  Mine had a few plastic burs on the teeth inside the slide.  Once I cleaned it up a little it worked well again.  Now I have logged at least 20 hours of play time (while in rapid-fire mode) and it hasn't missed a beat since.
I hope this helps.
- DigDreams
Cananas
« Reply #1631 on: May 29, 2006, 03:33:29 am »
Forget that this driver exist, and use the Smog drivers.
With your system, you can install de lastest Smog drivers (v9b6). There are many bug fixed (also there are others not).
I installed the drivers and then plug the gun. Windows detected like guncon2 and installed the Smog drivers.
It could be that windows recognizes the gun like guncon2 but don't install the smog drivers. If this is your case, you must go into de control panel->system, locate the guncon2 device and update the drivers, pathing the smog drivers directory.
To use PC hod2 with two guns, you need the troubleshooter. Read the program instructions for more details.
Don't discourage. ;)
aljupy
« Reply #1632 on: May 29, 2006, 07:33:20 am »
Cananas Is RIGHT....Use Smog
aljupy
« Reply #1633 on: May 29, 2006, 07:48:16 am »
« Last Edit: May 29, 2006, 07:53:18 am by aljupy »
aljupy
« Reply #1634 on: May 29, 2006, 07:51:05 am »
After Reading some "replies" on this page (Page41) I have a little Question  :angry: Let
rumpelstiltzkin
« Reply #1635 on: May 29, 2006, 04:47:12 pm »
when you go into device manager in control panel and click on hid devices is it suppose to show your guns .   there not there for me
rumpelstiltzkin
« Reply #1636 on: May 29, 2006, 08:11:43 pm »
i cant believe i need smogs but cant get it working . i know that if one of you guys were in my room you could get it working no sweat. i think its my lack of computer knowledge. i need step by step intructions  that a 5 year old would understand. ive only had my pc a few months. im so used to console gaming put in a disk and thats you sorted. surly it should just work and show my 2 guns the other drivers worked no problem but were useless for 2 player   ::) :-[ :-X :'( :'( :'( :'( :'(
smithrhee
  • Last login:June 10, 2006, 01:49:34 pm
PS1 Emulator with this gun?
« Reply #1637 on: May 31, 2006, 09:27:23 pm »
Hello. I just registered and reading this post from the beginning...
I have this one question which I still couldn't figure out:
If I buy a PS1 game (say, Point Blank 3) and run it with PS1 emulator on Windows XP,
can I use this light gun?
Thanks in advance.
Edit. Let me add why I couldn't figure this out. According to the manufacturer, Point Blank 3 is a PS1 game. Since this LCD Topgun is Guncon2 compatible, if I play Point Blank 3 on an actual PS2 machine,  I cannot use this gun. So to use this gun for Point Blank 3, one needs PS1 emulator on PC.
« Last Edit: May 31, 2006, 09:34:18 pm by smithrhee »
MacroX
Re: PS1 Emulator with this gun?
« Reply #1638 on: May 31, 2006, 11:47:33 pm »
Yes, If  PS1 emulator can support mouse or keyboard.
Thanks in advance.
smithrhee
« Reply #1639 on: June 01, 2006, 09:38:52 am »
Thank you! I just ordered two sets of LCD topguns as well as an LED blazer from play-asia.com. Can't wait!
