Author Topic: t-molding question  (Read 3111 times)
Silverwind
  • Last login:September 26, 2022, 12:49:09 am
t-molding question
« on: February 06, 2003, 01:34:52 pm »
I have 5/8 plywood.. will be putting 1/8 lexan on top of that..
should I get 3/4" t-molding to cover the side of the wood and also the side of the lexan? or just get 5/8 t-molding to cover just the wood?
Thanks :D
eightbit
  • My cab is never done...
Re:t-molding question
« Reply #1 on: February 06, 2003, 01:43:47 pm »
Its personal preference, they also make a offset t-molding so that you can still center the slot on your board but have it overlap the plexi.
Silverwind
« Reply #2 on: February 06, 2003, 01:51:54 pm »
you use laminate and not lexan on your CP correct eightbit?
I was going to ask you which method you used.. but it probably does not apply to your setup :)
They have a wider variety of t-moulding available in the 3/4" size.. which is half the reason I'm curious..
I suppose it would look smoother if the edge of the lexan was covered... the control panel would have more of a "one piece" appearance..
eightbit
« Reply #3 on: February 06, 2003, 01:56:44 pm »
The control panel that came on my first cab was 3/4" wood with plexi. The t-molding only covered the wood. I replaced that control panel and covered the replacement with vinyl with no over lay and I am very happy with it.
My other cab I covered in vinyl and then covered with plexi but the plexi was more for a way to hold the monitor glass down, then it was to cover the CP. It did make it possible to add labels to a couple of the buttons.
Elkor
  • Last login:February 12, 2007, 12:42:50 pm
  • What did I just say?
    • Full Circuit
« Reply #4 on: February 06, 2003, 03:17:31 pm »
IMO  ....
you should go with the 3/4.  That's what I did and I am VERY happy with the results.
it looks like a single sheet, and nobody is the wiser
(and mine is actually a laminate of MDF, sheet steel, and lexan!)
if you go with the offset 3/4 that eightbit suggested the slot will be somewhat easier to cut..
my 2c
The sudden sight of me causes panic in the streets. They have yet to learn
-- only the savage fears what he does not understand.
                -- The Silver Surfer
Jakobud
  • Last login:December 23, 2025, 02:48:26 am
« Reply #5 on: February 06, 2003, 03:32:05 pm »
I have 5/8" mdf with plexiglass and my 5/8" t-molding looks and feels great.
Jakobud
Silverwind
« Reply #6 on: February 06, 2003, 03:54:50 pm »
Jakobud
Do you have any pictures of that jakobud? :)
Silverwind
« Reply #7 on: February 06, 2003, 03:56:08 pm »
IMO  ....
my 2c
If I want to remove the lexan (say to change artwork) will the 3/4 t-molding get in the way if it covers the lexan edge?
also.. since it is covering lexan as well as the wood.. is there an increased probability that the t-moulding will be bent/pull off at the top?
eightbit
« Reply #8 on: February 06, 2003, 04:05:44 pm »
Nope, it shouldn't get in the way and it shouldn't bend at the top any more than if you weren't using lexan.
