Author Topic: t-molding question  (Read 3125 times)
Silverwind
  • Last login:September 26, 2022, 12:49:09 am
t-molding question
« on: February 06, 2003, 01:34:52 pm »
I have 5/8 plywood.. will be putting 1/8 lexan on top of that..
should I get 3/4" t-molding to cover the side of the wood and also the side of the lexan? or just get 5/8 t-molding to cover just the wood?
Thanks :D
eightbit
  • Last login:September 07, 2019, 07:38:11 pm
  • My cab is never done...
Re:t-molding question
« Reply #1 on: February 06, 2003, 01:43:47 pm »
Its personal preference, they also make a offset t-molding so that you can still center the slot on your board but have it overlap the plexi.
My statements are my own opinions. They have the value that the reader gives them. My opinion of my opinion varies between foolish and brilliant and these opinions often change with new information.
Silverwind
« Reply #2 on: February 06, 2003, 01:51:54 pm »
you use laminate and not lexan on your CP correct eightbit?
I was going to ask you which method you used.. but it probably does not apply to your setup :)
They have a wider variety of t-moulding available in the 3/4" size.. which is half the reason I'm curious..
I suppose it would look smoother if the edge of the lexan was covered... the control panel would have more of a "one piece" appearance..
eightbit
« Reply #3 on: February 06, 2003, 01:56:44 pm »
The control panel that came on my first cab was 3/4" wood with plexi. The t-molding only covered the wood. I replaced that control panel and covered the replacement with vinyl with no over lay and I am very happy with it.
My other cab I covered in vinyl and then covered with plexi but the plexi was more for a way to hold the monitor glass down, then it was to cover the CP. It did make it possible to add labels to a couple of the buttons.
Elkor
  • Last login:February 12, 2007, 12:42:50 pm
  • What did I just say?
    • Full Circuit
« Reply #4 on: February 06, 2003, 03:17:31 pm »
IMO  ....
you should go with the 3/4.  That's what I did and I am VERY happy with the results.
it looks like a single sheet, and nobody is the wiser
(and mine is actually a laminate of MDF, sheet steel, and lexan!)
if you go with the offset 3/4 that eightbit suggested the slot will be somewhat easier to cut..
my 2c
The sudden sight of me causes panic in the streets. They have yet to learn
-- only the savage fears what he does not understand.
                -- The Silver Surfer
Jakobud
  • Last login:March 10, 2026, 10:09:01 am
« Reply #5 on: February 06, 2003, 03:32:05 pm »
I have 5/8" mdf with plexiglass and my 5/8" t-molding looks and feels great.
Jakobud
Silverwind
« Reply #6 on: February 06, 2003, 03:54:50 pm »
Jakobud
Do you have any pictures of that jakobud? :)
Silverwind
« Reply #7 on: February 06, 2003, 03:56:08 pm »
IMO  ....
my 2c
If I want to remove the lexan (say to change artwork) will the 3/4 t-molding get in the way if it covers the lexan edge?
also.. since it is covering lexan as well as the wood.. is there an increased probability that the t-moulding will be bent/pull off at the top?
eightbit
« Reply #8 on: February 06, 2003, 04:05:44 pm »
Nope, it shouldn't get in the way and it shouldn't bend at the top any more than if you weren't using lexan.
