Author Topic: So who's using Ms Pac Reunion Stick with a longer shaft?  (Read 1466 times)
Yoder
  • Last login:November 22, 2006, 04:35:24 pm
« on: January 05, 2006, 12:10:10 am »
OK, I've done a lot of research on these things and it appears that there are 4 options of mounting the Reunion stick to a wood panel.
1.
Yoder
Re: So who's using Ms Pac Reunion Stick with a longer shaft?
« Reply #1 on: January 05, 2006, 01:34:24 pm »
Forgot Option #5.  Top-mount with metal adaptor (Oscar's still around?).  Carry on...
Thenasty
  • Trade Count: (+17)
  • Last login:Today at 11:38:03 am
« Reply #2 on: January 05, 2006, 01:55:17 pm »
I think the 25th reuinion used a longer shaft just like the Qix/Invaders ones.
Free VGA Breakout Cable
markrvp
  • NFL Expert
« Reply #3 on: January 05, 2006, 02:26:40 pm »
I've got both the Tornado Terry long shaft version and the original version of the Reunion stick.  I like the throw of the shorter stick better, but the throw of the longer shaft is very similar to the Happ Super & Competition sticks.  It does require less effort with the longer stick due to the increased leverage, but it is okay.  I have no doubts that I could rack up Pacman scores just as high with that stick as I do with the shorter stick (I just have a dedicated Pacman cocktail so I don't play Pacman on the machine with the longer stick).
The 1/8" lexan on top is no problem.  Remember that these joysticks are made to go under 1/8" metal anyway.  I don't think the artwork resting on top of the joystick will be a problem, but you can always fill the top of the joystick base in with some type of filler if you need to.  You would have to put the dustwashers on top of the lexan if you did that.
