Author Topic: MAME  (Read 5083 times)
mrynit
  • Last login:May 13, 2006, 06:01:12 am
MAME
« on: December 19, 2005, 02:56:38 pm »
why does every one used mame? isnt there some other program to play roms?
MYX
    • MYX Digital Blog
Re: MAME
« Reply #1 on: December 19, 2005, 03:11:54 pm »
There is, but MAME goes to 11
M    Y    X
vader
  • Last login:January 19, 2025, 08:25:22 pm
  • I can't breathe in this thing !!
Re: MAME
« Reply #2 on: December 19, 2005, 03:15:10 pm »
there are other's.  MAME just happens to be the most popular and most supported.
Tim
mrynit
Re: MAME
« Reply #3 on: December 19, 2005, 07:14:01 pm »
my problem is the fasted computer i could get would be a 850Mhz p3 with 320MB ram and an 8Mb agp video card. would i be able to run snes roms with that type of computer? i need to use USB for the controls so i want to stay in windows. can windows 2000 support MAME in dos mode?
Thenasty
  • Trade Count: (+17)
  • Last login:December 01, 2025, 04:30:09 pm
Re: MAME
« Reply #4 on: December 19, 2005, 10:19:09 pm »
Just use the WINDOWS BUILD of MAME (official) not the DOS one, or in your case why not just use MAME32.
« Last Edit: December 19, 2005, 10:21:01 pm by Thenasty »
Free VGA Breakout Cable
mrynit
Re: MAME
« Reply #5 on: December 19, 2005, 10:39:37 pm »
Ok i would if i could understand all this MAME stuff. i dowloaded mame32 source from here http://www.classicgaming.com/mame32qa/. i go this file Mame32v.102_Source. Am i  doing every thing ok so far?? so i unzip it and it's a bunch of C/C++ files!!! wtf?! yeah i know i'm being noobish(you think they would have a ui for installing all the stuff...). I have MS Visual Stuido 6.0 but i dont know how to complire the mame32 code. so what do i do?!
thanks for the help
SirPeale
  • Green Mountain Man
Re: MAME
« Reply #6 on: December 19, 2005, 10:48:59 pm »
Well, yeah...you download SOURCE CODE, you're going to get a bunch of C files.
Download the binary
mrynit
Re: MAME
« Reply #7 on: December 20, 2005, 12:26:53 am »
ok thank you.
this is the MAME verion i got from the MAME website
Windows command line version of MAME 0.102.
is that ok with what i need?
pointdablame
Re: MAME
« Reply #8 on: December 20, 2005, 12:39:20 am »
ok thank you.
For the computer you are using, you want a much older version of mame.  Try something like Mame .55
first off your and idiot
mrynit
Re: MAME
« Reply #9 on: December 20, 2005, 12:50:48 am »
does .55 support USB controllers?
pointdablame
Re: MAME
« Reply #10 on: December 20, 2005, 12:56:09 am »
I'm pretty sure that depends on your Operationg System and not the Mame version.  If I'm right about that, any OS that can use USB controllers will be able to use them in Mame.
Hopefully someone can pop in here and confirm or deny my guess though.
AtomSmasher
    • Atomic-Train
Re: MAME
« Reply #11 on: December 20, 2005, 01:13:58 am »
Just thought I'd throw this out there just in case...mame doesn't run snes roms, you'd need a snes emulator to do that.
mrynit
Re: MAME
« Reply #12 on: December 20, 2005, 01:46:35 am »
OK thanks for clearing that up. i get it now, MAME for only arcade roms. i need ZSNES for snes roms. now what frontend do i use to tie MAME with ZSNES, that is have one frontend from where i can select games from eith MAME or ZSNES?
Thank you all so much for the help! :laugh:
thesmit
  • Last login:November 29, 2006, 12:46:28 am
Re: MAME
« Reply #13 on: December 20, 2005, 02:10:27 am »
I use one called MameWah..... very customizable, perfect for use in cabinets and supports any command line emulators.... but it is not the most user friendly to setup though....
I have all the .ini configuration files that I use if ya need them...
PS: I am running (among other emus) MAME and ZSNES from MameWah on a Windows 98 PC.... I just got a USB gamepad for it and am about to try it out tonite!!!
mrynit
Re: MAME
« Reply #14 on: December 20, 2005, 05:09:52 am »
dude tell me how that works. I'm intrested in running both those emulators. Are you running any NES emulators?
petrosky
  • Last login:May 18, 2006, 01:12:33 am
Re: MAME
« Reply #15 on: December 20, 2005, 08:19:33 am »
Wow, I thought MAME was the only thing you could use. The bad part is, I don't even know how to use it  :'(
AtomSmasher
    • Atomic-Train
Re: MAME
« Reply #16 on: December 20, 2005, 11:13:50 am »
Mamewah is very easy to set up if you use the mamewah config program - http://www.bluecamel.org/2005/02/26/mamewah-config-161/
Tiger-Heli
    • Tiger-Heli
Re: MAME
« Reply #17 on: December 20, 2005, 11:29:56 am »
MAME Setup - www.mameworld.net/easyemu
SNES - I like ZSNES
NES - I like FCE Ultra
Frontends - MAMEwah is good once you learn how to configure it.  I also like Atomic, but not sure if it does multiple emulators.
subcriminal
  • Last login:November 20, 2019, 12:58:00 pm
Re: MAME
« Reply #18 on: December 20, 2005, 02:40:34 pm »
Hope you get setup with some of the old classics running. MameWah is the best choice for firing up MAME but I reckon if you downladed and installed MAME32, ran a few games and played with the settings it'd help you when you come to install MameWah and have to configure things manually.
MAME32 uses a Windows GUI to quickly change settings so you can see their effect then exit the game and change something else to learn what it does like screen sizes, audio settings, DirectX etc. The MAME binary has a config file that you edit by hand MAMEWah just launches MAME along with the ROM file and depending on what the config file contains depends on how your games look and how well they run.
Good luck!
Just to clarify a bit:
MAME32 - Installs, drop your rom files into rom folder and run mame32.exe play games that are listed in the program.
MAME (Windows Version)- runs from the command prompt you have to put roms into rom folder then issue a command in the command prompt like C:\MAME\mame dkong to play a game.
Frontend - creates a list for your roms for each emulator and when a game is selected from the list it runs the emulator with the selected rom without using the command prompt. Useful for hiding the Windows environment and creating game lists for multiple emulators. MameWah is found to be the easiest to configure by most.
mrynit
Re: MAME
« Reply #19 on: December 20, 2005, 04:52:19 pm »
Ok that does help my understanding.
once i install MameWah how do i install MAME, ZSNES and other emulators throught it? MameWah will hide widows so it will look like a "normal" arcade? can i navigate through the on screen game selection by using only the joystick and buttons(i will be rewiring a usb gamepad)?
petrosky
Re: MAME
« Reply #20 on: December 20, 2005, 05:07:31 pm »
Thanks Atom I'll def check that out  :)
thesmit
Re: MAME
« Reply #21 on: December 20, 2005, 09:31:01 pm »
Hi
MameWah is designed to run in a stand alone arcade cab, using the cab controls to navigate around the menus, select games, etc. The only time you need a keyboard is for initial configuration and on going admin. I have not actually used a hacke USB gamepad, but I can't see why it wont work... Anyone else tried?
It runs in full screen, therefore hiding the windows desktop. You can even get MAME Windows 98 Boot Loader screens, so the Windows logog is not even seen on boot!!! Email me if ya want info on this.
As far as configuration/ setup of the various emulators, it is best to use a tool such as MameWah config (see post by AtomSmasher above for link). If you go to http://www.screenshotarchive.com/downloads_emus.htm you can download emulators that are basically setup to be run in a cab (they exit by "esc" key, setup mame keys as default, etc.). Have a look around there and see what they have....
Anyways, hope that helped
cya
Smit
mrynit
Re: MAME
« Reply #22 on: December 21, 2005, 05:19:52 am »
i installed mameWah and it is tuff to configure. it will show my games but i cant select them using my usb gamepad. i set joystick to 1 in the ini file so can scroll the games but using the same gamepad to start a game does not work.
danny_galaga
  • Last login:December 01, 2025, 06:37:38 am
    • dans cocktail lounge
Re: MAME
« Reply #23 on: December 22, 2005, 02:43:14 am »
SNES - I like ZSNES
mrynit
Re: MAME
« Reply #24 on: December 22, 2005, 05:23:48 am »
hey if Atomic FE is easier to set up then MameWah i'll try it. i know all i have to do is read a bunch of readme's but that takes time.
Dexter
  • Patriotism, the last refuge of the scoundrel. -- Irish, darnit!
  • Last login:February 01, 2024, 04:36:19 pm
  • "MAKE POVERTY HISTORY......."
Re: MAME
« Reply #25 on: December 22, 2005, 06:06:48 am »
I've been using gamelauncher. It comes with a bunch of sample config files for vaious emulators. Not too bad to set up either.
Martoon
  • Last login:January 16, 2007, 03:32:14 pm
  • Boloney Beaver - he don't mess around!
Re: MAME
« Reply #26 on: December 22, 2005, 02:09:34 pm »
Time is that elusive quality of nature which keeps things from happening all at once.  Lately, it doesn't seem to be working.  -- Douglas Adams
quarterback
Re: MAME
« Reply #27 on: December 22, 2005, 02:12:25 pm »
I thought there was some kind of configuration util created for setting up MameWah.  Maybe checkout the Software forum.
-- Chad Tower
AtomSmasher
    • Atomic-Train
Re: MAME
« Reply #28 on: December 22, 2005, 02:39:01 pm »
pointdablame
Re: MAME
« Reply #29 on: December 22, 2005, 02:44:54 pm »
I don't understand why people need a config program to begin with.  It's just a few simple .ini files.
subcriminal
Re: MAME
« Reply #30 on: December 22, 2005, 03:34:57 pm »
No good will come of this thread  ;) Just download the programs people have sugested, read the README's, mess with the software, read the readme's again, repeat! Worth the agro though! ;D
quarterback
Re: MAME
« Reply #31 on: December 22, 2005, 06:01:56 pm »
And your [sic] not too good at spelling.
-- Chad Tower
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
Re: MAME
« Reply #32 on: December 22, 2005, 06:34:55 pm »
For an older computer like that you might want to look at older versions of mame (as already suggested I believe).  Also for neogeo and cps game look at kawaks, nebula, and neoragex.
Mame uses direct x for input, so if windows can see an input device, mame can.
AtomSmasher
    • Atomic-Train
Re: MAME
« Reply #33 on: December 22, 2005, 06:43:55 pm »
Thenasty
Re: MAME
« Reply #34 on: December 22, 2005, 06:54:29 pm »
there is only one that beats a Spelling Bee,
a Talking Horse    :o
MaximRecoil
Re: MAME
« Reply #35 on: December 22, 2005, 07:17:27 pm »
MAME is one louder?
That PC is plenty for ZSNES. It is plenty for most MAME games as well, up to, and possibly including, Mortal Kombat 3, provided you use an older version of MAME, like in the .5x to .6x range.
