Author Topic: Red Bat top on Happ Perfect 360  (Read 1985 times)
testicle187
  • Last login:January 24, 2026, 06:08:15 pm
« on: December 14, 2005, 02:21:13 am »
I was looking to get two new Happ Perfect 360 sticks for my Mortal Kombat arcade machine, but would really like to have Red bat top sticks.  What handles are compatible with the P360s?
Kremmit
  • - AHOTW -
  • Who the heck is that?
Re: Red Bat top on Happ Perfect 360
« Reply #1 on: December 14, 2005, 02:58:21 am »
Wico handles fit, and yes they did make some pear-tops back in the day.  Good luck finding new red Wico pear-tops, but if you don't mind used ones, I think I've got some.
SlikStik makes handles for the P-360, including red anodized aluminum pear-tops.  Beautiful, but not cheap.
jcoleman
  • Last login:March 15, 2025, 04:12:49 pm
  • RTFM
« Reply #2 on: December 14, 2005, 09:20:07 am »
Has anyone tried a competition handle in a p360?
lesserChance
  • Last login:October 08, 2010, 04:53:20 pm
  • I do my best work through the coin door
« Reply #3 on: December 14, 2005, 02:23:37 pm »
What i did... I know know a lot of people are going to hate me for this... is used competition bat tops.  They are a little smaller so I wrapped some masking tape around it real tight, until it was the size that the 360 sticks were supposed to be.  It works great, i haven't had any issues at all....
Kremmit
  • - AHOTW -
« Reply #4 on: December 14, 2005, 11:20:20 pm »
No reason to hate you for that.  In fact, I think I've read of other people doing more or less the same thing.  I suppose the masking tape might break down over time, but it's certainly easy enough to put more on if you notice them getting loose.
testicle187
« Reply #5 on: December 15, 2005, 02:50:34 am »
Do you just put the masking tape over the bottom of the shaft where the little plastic actuator goes?  I am not fully understanding the tap thing I guess, but it sounds interesting and ghetto enough for me to give a try.  ;D
lesserChance
« Reply #6 on: December 15, 2005, 12:32:06 pm »
Yeah, I just wrapped it around the metal part where the actuator is.  I initially put on too much then just kept cutting some off until it was a nice fit.
hypernova
  • Last login:November 25, 2016, 12:52:48 pm
« Reply #7 on: December 26, 2005, 11:54:52 am »
so...am i to understand that p360 and wico handles are interchangeable with slikstik replacements?
I'll exercise patience when you stop exercising stupidity.
My zazzle page.  I've created T-shirts!
Kremmit
  • - AHOTW -
« Reply #8 on: December 26, 2005, 04:57:29 pm »
Here's two threads where it's been discussed.  Bottom line is that SlikStik says they don't fit, but the general consensus is that they can probably be made to serve, and at least one guy claims to have done it already.  Still, nobody's posted any actual pics yet.
http://forum.arcadecontrols.com/index.php?topic=44594.0
http://forum.arcadecontrols.com/index.php?topic=39367.0
hypernova
« Reply #9 on: December 29, 2005, 07:24:51 pm »
ah.  perfect....ly confusing.  seems an answer was never really reached.  so...new question.
slikstik handles work in p360s?  any others guaranteed to work with no mods required?
ponyboy has replacements for wicos, so i know where i can get those replaced at.
if slikstik's the only one with p360 replacements, then i'll just buy from two separate vendors.
Luckydevil
  • Last login:August 02, 2007, 01:38:45 pm
  • mmmm.... kilowatts.
    • Garage Junkies
« Reply #10 on: December 30, 2005, 12:20:45 am »
Kremmit
  • - AHOTW -
« Reply #11 on: December 30, 2005, 12:34:30 am »
From the page you linked up:
The (Wico) handle shaft was the exact diameter as the P360 handle. However, the length of the shaft was about 1/16" too short, which prevented me from attaching the E ring. Still, all you have to do is compress the internal spring and the E ring will fit.
So if a Wico handle's 1/16" shorter than a P360 handle, then it seems to me that SlikStik's P360 handles must be 1/16" longer than a Wico handle, yes?  Which means that to use SlikStik's P360 handles in a Wico joy, all you should need to do is put a 1/16" thick spacer (like a washer) between the e-clip and the actuator.
