Author Topic: My Pacman profile cabinet (finished!......99%)  (Read 98383 times)
c64rulez
  • Last login:July 09, 2011, 05:08:36 pm
  • It's live and kicking
Re: My Pacman profile cabinet + Free unique FrontEnd
« Reply #240 on: December 16, 2005, 01:54:17 am »
All right
So I decided its time for my cabbie to head home (building was done outside in the open, under a rooftop)
BUT, it's 10 meters of nothing but grainy terrain between the cab and the house.
I rolled it on two boards, replacing them each time, and this is some heavy ---smurfette---.
Midway (or namco), the sky were about to pour down, and I was HORRIFIED.
Luckily the event ended harmlessly.
Kremmit
  • - AHOTW -
  • Who the heck is that?
« Reply #241 on: December 16, 2005, 02:12:09 am »
Hey, you and I have the same sofa.  Mine's black though...
(Really, I do have that sofa in black.)
c64rulez
« Reply #242 on: December 16, 2005, 02:22:06 am »
Check again, I think there's a void where youre sofa used to stand
missioncontrol
  • MC-Retro says Wot!
  • Trade Count: (+13)
« Reply #243 on: December 16, 2005, 06:46:36 am »
quote (Drew Karee):
You have been assimilated
We ain't seen no purdy pics.
c64rulez
« Reply #244 on: December 16, 2005, 07:19:15 am »
Yeah sure
Try that when the server yells at you to go f#$k yourself
c64rulez
« Reply #245 on: December 16, 2005, 07:32:06 am »
Test drive @ home
Just the tv, pc (with keyboard) and the speakers for a quick test-in-the-box.
All is working fine. TV picture needs some tuning, but besides that I'm cool.
All pc stuff (motherboard, power supply, hd) will be mounted on that mid-shelf.
Down under is a boston acoustics sub.
c64rulez
« Reply #246 on: December 16, 2005, 09:39:00 am »
Regarding the FrontEND I'm currently writing, it's actually an MS ACCESS application, so do your own math as for the compatibility issue.
However, IT WILL BE FREE, and YES it will also be a JUKEBOX and will run SLIDES
TurboC--
  • Last login:December 21, 2023, 12:23:05 am
  • No one can defeat the quad laser!
« Reply #247 on: December 16, 2005, 02:24:53 pm »
Why do people put bare components in their MAME machine?  Seems like a lot of work and risk to the components, to mount them freely in the cab, rather than just put the whole case in there.  Is it just to make it lighter?  To reduce the number of fans needed to cool things?  Just cause people think it's "cool"?
c64rulez
« Reply #248 on: December 16, 2005, 02:28:45 pm »
I simply did not have a box
Everything you see there is garbage collection (800Mhz PIII, 384MEG, 20GB)
Has nothing to do with "cool"
Its not a good answer, but...
missioncontrol
« Reply #249 on: December 16, 2005, 02:56:08 pm »
c64rulez
« Reply #250 on: December 16, 2005, 03:07:15 pm »
missed you man
How come you dont have 5 purple stars ?
I think that the supreme council should promote you to "Global Slacker" or something
Besides, isnt the cab a box for the pc ?
missioncontrol
« Reply #251 on: December 16, 2005, 03:23:45 pm »
missed you man
in purgatory I have a badge and a cookie
I'm working my way into earning a hammer too
c64rulez
« Reply #252 on: December 16, 2005, 03:54:47 pm »
I see you got a haircut
lovely
c64rulez
« Reply #253 on: December 16, 2005, 04:25:40 pm »
Couldnt help putting all the buttons in just for the pose.
Very simple cp configuration, the 4 way joy sits in a pre-routed cradle and is flush with the surface (3mm plexi not shown here).
For the other two - standard under the hood mounting.
I am a little disappointed with the buttons, as they are convex on top. At the time I ordered I had no idea there were two kinds.
I assumed only concave existed, but...
missioncontrol
« Reply #254 on: December 16, 2005, 05:19:37 pm »
are you not going to have a trackball?
markrvp
  • NFL Expert
« Reply #255 on: December 16, 2005, 05:22:20 pm »
I am a little disappointed with the buttons, as they are convex on top. At the time I ordered I had no idea there were two kinds.  I assumed only concave existed, but...
You'll get used to the concave buttons very quickly.  I've got them installed on one of my panels and they are very nice, actually.
c64rulez
« Reply #256 on: December 16, 2005, 05:32:14 pm »
I have no other choice  ::)
TurboC--
« Reply #257 on: December 16, 2005, 05:37:27 pm »
I suppose we could ask you the same thing about putting a case inside a cabinet
- It is easier (assuming you already have a full case together like I do)
- It is safer for the components
Mounting a motherboard, hard disk, power supply, possibly floppy/cdrom directly to a wood cabinet, dealing with potential damage to the components from faulty mounting or inadequate grounding, not to mention having the necessary expansion cards stay in the motherboard (they no longer have the anchoring of the screw mounting bracket from the case).
c64rulez
« Reply #258 on: December 16, 2005, 05:41:56 pm »
Man, I've been juggling mboards and rams and stuff for quite some time now. I have hooked them where no man has gone before.
So whats a shelf in a cab comparing to that ?
It really is nothing
Now, if you wanna talk about out of the case stuff, I'd go for the monitor/tv thing. Now that's something thats probably better stay in.
missioncontrol
« Reply #259 on: December 16, 2005, 05:53:49 pm »
I for one use spare parts for my cabinets it's basically recycling old stuff and keeping it out of the landfills .
do I need to go out and buy the top of the line system to run mame? no, I'm just going to use an old 333mhz that's been lying around. I can use the case for something else. so for me it makes no sense to keep it in the case.
DrewKaree
  • HAH! Nice one!
    • A lifelong project
« Reply #260 on: December 16, 2005, 05:57:02 pm »
No more risk than how a dedicated cab is set up.  Also, compare the differences in cost if you had to replace a Pac PCB vs a MAME-capable videocard. (and if anyone says it's cheaper for one than the other, I refer you to Stingray's new attitude after re-reading his first post)
I'm gonna be doing it in my project.  If you check it out, you'll see that at first, it'll be the ONLY way to set it up, but if I decide to build the pedestal and whatnot, I ain't gonna be sticking all the stuff into a case and moving it.  Some standoffs, mebbe a piece of metal bent to hold cards in....in the grand scheme of projects like these, that's really not a lot of work.
c64rulez
« Reply #261 on: December 16, 2005, 10:33:31 pm »
Man, I've been staring at your dude falling down the stairs for the past 45 minutes. Please replace that. I'm hooked.
Not now anyway, for two reasons.
1. money
2. didnt play much ball games
and maybe (3)
you dont need to have all controls known (and unknown) to mankind (and aliens), as I saw before, to play your favorites.
TurboC--
« Reply #262 on: December 17, 2005, 12:20:50 am »
1. money
Same here.  Centipede and .. errr.. bowling games... Golden Tee?  I can't even run that on a vertical monitor.  And the damn things are EXPENSIVE.  Especially the little ones.  I was considering adding a small one to the Pac-man control panel, but the only one that would fit nicely was over $200.  Glad I didn't though, would never want to hack up an original Pac-man CPO...
c64rulez
« Reply #263 on: December 17, 2005, 08:19:11 am »
Although the mind police at EE are trying their best to divert me from the original course of action, I made some progress (very faint however, I must say).
My FRONTEND is coming along fine, first version will include all three functions I intended for it - PLAY, LOOK and LISTEN.
PLAY - roms from multiple emu's
LOOK - digital photos slide show
LISTEN - MP3 jukebox
This piece of software will be free for any BYOAC member (who will want it...)
Some pictures follow:
c64rulez
« Reply #264 on: December 17, 2005, 08:23:57 am »
I've also temporarily attached the cp+plexi in it's final position for two reasons:
1. See how it looks and feel
2. Once upon a time, in a galaxy far far away someone told me to go with a curved front for my cab. So this temp clamping gave me some insight regarding that front issue.
Still pondering though
BTW, needless to say this is not the final position of the cab, still need to play some pool
« Last Edit: December 17, 2005, 08:29:00 am by c64rulez »
missioncontrol
« Reply #265 on: December 17, 2005, 09:41:30 am »
well this will keep you occupied for  while:
c64rulez
« Reply #266 on: December 17, 2005, 10:16:42 am »
Man, I've been waiting like 20 minutes for that kiddo to stay down
but that is one mean son-of-a-#$%! kiddo.
Please remove her from my thread
I'm dizzy
BTW, if your laundry machine engine is down, replace it with this one
« Last Edit: December 17, 2005, 10:21:25 am by c64rulez »
missioncontrol
« Reply #267 on: December 17, 2005, 01:36:50 pm »
posting in purgatory is going to postpone your progress.....
c64rulez
« Reply #268 on: December 17, 2005, 01:39:09 pm »
It just went down
I sense the webmaster there is actually a plumber.
It also crawls like an ant with one leg
Back to my unimportant stuff, test fitting the tv frame + 6mm plexi + buttons on the cp. Everything's perfect
« Last Edit: December 17, 2005, 01:50:18 pm by c64rulez »
missioncontrol
« Reply #269 on: December 17, 2005, 04:49:28 pm »
please keep use posted on the progress when you are able to come back in three days........
c64rulez
« Reply #270 on: December 18, 2005, 09:18:35 am »
I'm back sooner than I expected, but no progress. I suddenly felt a strong urge and saw "Bigger Longer & Uncut". Laughed my --I'm attempting to get by the auto-censor and should be beaten after I re-read the rules-- out.
I also immediately ran to check my ID and was relived to see I'm not from Canada.
Promise to post when progress will be made.
Harry Potter
  • Smite-bait
  • Last login:May 27, 2024, 03:33:28 am
  • Sober until banned. Can post but still can't read.
« Reply #271 on: December 18, 2005, 10:38:45 am »
Hey, just off topic (and to add some posts to my measly count), why don't you add yourself to the BYOAC people finder. (Look above or use this link: http://www.frappr.com/byoacmembermap )
It'd be good to have someone on there from someplace other than the US, Australia or Europe.
And good luck with the cab.
Now in a tasty new flavour.
c64rulez
« Reply #272 on: December 18, 2005, 10:59:11 am »
Thanks man. done that. I punched in the closest city to where I live.
Hope your plane's gonna lift off soon...
Harry Potter
  • Smite-bait
« Reply #273 on: December 18, 2005, 11:17:48 am »
Xiaou2
  • Last login:December 03, 2025, 07:12:23 pm
  • NOM NOM NOM
« Reply #274 on: December 19, 2005, 06:53:16 am »
 Saw the design and thought Id give it a try too.  Needs a little tweaking, but heres some roughs...
 Thoughts ?
c64rulez
« Reply #275 on: December 19, 2005, 07:04:31 am »
Man, I feel like crying. I truly am.
The designs people throw at me are just getting better and better, and I think my cab's gonna stay white and artless
« Last Edit: December 19, 2005, 07:07:08 am by c64rulez »
brophog
  • Last login:January 20, 2019, 03:49:41 am
« Reply #276 on: December 19, 2005, 08:41:36 am »
Don't do it locally then. There are plenty of online printing services that do fabulous work.
c64rulez
« Reply #277 on: December 19, 2005, 08:45:15 am »
will it go overseas unharmed ?
I know they can handle safe delivery of enriched uranium, but wtf do I care about it.
All I care for is my sideart to arrive unharmed
« Last Edit: December 19, 2005, 08:51:23 am by c64rulez »
c64rulez
Re: My Pacman profile cabinet (CP artwork comments)
« Reply #278 on: December 19, 2005, 11:16:57 am »
Hey guys, just posting my first idea for the cp artwork.
Please share your comments regarding the design. Thank you
BTW, as mentioned before, two happ supers (left & right)  and 4way in the center.
Xiaou2
  • NOM NOM NOM
« Reply #279 on: December 19, 2005, 02:11:29 pm »
 Glad you like them :)   Off to work now.. will send the file when I return.
 I use Photoshop 7.    The shading is almost automatic..  I just tweak the standard settings to enhance it.
 If you cant get it  printed.. you might be able to hire an airbrush guy to try as well.
