Author Topic: PII-300 - where will I run out of juice?  (Read 1749 times)
AdamLotz
  • Last login:January 11, 2004, 11:38:08 am
« on: January 06, 2003, 08:30:22 pm »
Hey guys -
I have a PII-300 that I'm running DOSMame on.  I want to say it has 128 megs of ram but not positive.
I built the cabinet as an alternative to buying the $2800 Ms. Pac / Galaga reunion.  Obviously it plays both of those games fine.  But even in the set of antiquted roms I had, there were a few games that seemed slow.
Where (or maybe what year of Rom) will this system end up being no good anymore?  I mean, what sorts of games can I expect to work fine, and which games will be unplayable?  And for Dos MAME, does RAM count as much as it apparently does under windows?
Thenasty
  • Trade Count: (+17)
  • Last login:Today at 09:36:10 am
Re:PII-300 - where will I run out of juice?
« Reply #1 on: January 06, 2003, 09:01:27 pm »
Use MAME 36 Final. You can run hundreds of games with this version with your P2-300.
Free VGA Breakout Cable
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #2 on: January 07, 2003, 02:08:50 am »
Yeah, part of using an old system for mame is using an old mame.  old mames ran better on old systems.
1Spoon
  • Last login:January 17, 2007, 03:07:47 pm
  • Cocktail projekt going on..
« Reply #3 on: January 07, 2003, 10:38:40 am »
Interesting point.
I have mame 0.60 with a full set of ROMs.
If I were to run MAME 36 Final,  would I be able to use the ROMs I have ? Or do I need an older set??
Geo
  • Last login:January 08, 2003, 03:32:23 am
« Reply #4 on: January 08, 2003, 03:38:11 am »
Adam,
I'm running a PII-450 with AdvanceMame 62.2 and most of the stuff I run is fine. The majority of NeoGeo games run at near full FPS without skipping. Usuallt I am running under DOS, but going to Windows (98SE) doesn't hurt too bad.
On the plus side, when I'm ready I can just swap in an Athlon XP 2000+ CPU/MB upgrade for about $150 and be screaming. I do have some usable mempry hanging around otherwise add another $100 or so.
BTW,
Are you the same AdamLotz that visits JU? If so, you will find this hobby much less $$$$! :D
George (Jeepin' Geo)
eightbit
  • My cab is never done...
« Reply #5 on: January 08, 2003, 02:28:26 pm »
Adam I bet if you upgrade to win98 you'll see a performance boost. Dos doesn't get you the performance boost it used to. Most hardware has been optimized for Windows and mame is being developed in Windows now.
Brax
  • Last login:January 06, 2009, 09:03:48 am
  • Bring on the power tools!
« Reply #6 on: January 09, 2003, 10:27:26 am »
My buddy runs a PII 300. He's maxed out his ram. You'd be amazed what he can pull off. I think you'd notice quite a difference with a ram upgrade and you can play a great number of games. His wanted a coputer upgrade but now with the ram (384 megs) he's prepared to keep it for some time yet.
If you build a frankenpanel, chances are I don't care for you as a person.
