Author Topic: Using "sliders" to move a cabinet.  (Read 2046 times)
SirPoonga
  • Puck'em Up
  • Last login:Today at 12:42:03 am
  • The Bears Still Suck!
« on: June 27, 2005, 07:20:58 pm »
http://www.asseenontvdiscounts.com/sliding_robots.asp
I picked up some of these on clearence.  I put them under my asteroids cabinet.  Man, makes moving that around SOOOOO much easier.  If you don't want them under there permanently they are easy to put under.  Just slightly tilt your cabinet and push them under or pull them out.
If oyu do keep them under the cabinet that isn't a problem.  You have to put a significant horizontal force to move.  Just hitting the buttosn and such won't do it.  At least for me on my carpet.
Just an FYI for you folks.  It's something As Seen On TV that works :)
CJK
  • Last login:February 03, 2024, 03:30:12 am
  • All your ROM are belong to us!
Re: Using "sliders" to move a cabinet.
« Reply #1 on: June 27, 2005, 07:52:46 pm »
I'll second that -- those things are great. Home Depot sells them also, BTW. I moved a huge armoire (solid maple and about 400 lbs.) with them, and it was no trouble at all.
-- Chris
Underway: Joey's Arcade
D10
  • Last login:April 08, 2022, 12:44:44 pm
  • Pull my finger
« Reply #2 on: June 27, 2005, 08:09:42 pm »
I purchased a product very similar to that called moving men, and they are great. I now can leave my entertainment center loaded when I need to move it for any reason. Move it from carpet to wood floor back to carpet with now problems at all. I have some waiting for my cab when it is done...but with my ability to procrastinate that might be awhile :)
Rocky
« Reply #3 on: June 27, 2005, 09:41:39 pm »
I use those kind of "magic sliders" on all my machines that don't have wheels.
I got tired of trying to "walk" them every time I had to move one for something
SirPoonga
  • Puck'em Up
« Reply #4 on: June 28, 2005, 12:47:44 pm »
It's funny how simple the device is too.  Foam on one side for friction with what you put on it, smooth plastic on the otherside so it slides easily.  You'd think someone would have come up with that sooner.
I still think the casters on my emulation cabinet is more useful.  But for an old cabinet that doesn't have wheels it is nice.  What's nice about wheels is they work better on any surface.
But, since my dad had to help move two kids to and from college for the last 9 years he made a nice platform with large casters and a rope for pulling.  Just stack tubs or whatever on it and pull :)  But it came in useful for moving the asteroids machine.  He has big enough wheels on it that it rolls decent over grass.  That's how I got it into the apartment.  Unload cabinet from trailer in parking lot.  Roll across lawn to patio door.  Once inside put it on those sliders and moved it where I wanted it.  And I have textured carpet too.  I used the larger ones in the pack.  The smaller sliders might not have handled the textured carpet as well.
The combination of the two just made moving it a breeze.
missioncontrol
  • MC-Retro says Wot!
  • Trade Count: (+13)
« Reply #5 on: June 28, 2005, 12:55:51 pm »
I use them under the appliances in my rentals... It makes it easy to move them out of the way when I do a deep clean....
I thought that they'd make an arcade cabinet move around to much if they were under them...
it may be the difference of the vinyl flooring compared to carpet......
88mph
  • Last login:July 30, 2018, 12:17:48 pm
  • I need fuel!
« Reply #6 on: June 28, 2005, 01:07:39 pm »
Hey there,
I really like the super sliders as well--but there are a few caveats to consider when using them.. When I use them, I usually put them on the four corners and try to stick an extra one in the middle.  That way, if I'm moving a cab and one falls off, I don't get a big gouge in the floor.
Another thing to consider is what I like to call the 'sandpaper effect'.  If you use the super sliders on a machine that's on a nice floor, you can end up with little sanded areas where the sliders were sitting.  This happens when dirt gets trapped under the sliders, and the machine gets moved around a little bit.  I guess this is more of an issue with pinball machines though..
Anyway, they work great for moving machines around on the concrete in my garage!  :)
-88mph
AlanS17
    • AlanS17
« Reply #7 on: June 28, 2005, 01:47:43 pm »
I've seen those before. Tried them, but they didn't work so well for me. Not enough friction on the top surface. They kept coming out of place.
Rocky
« Reply #8 on: June 28, 2005, 02:51:19 pm »
Mine have adhesive so they stick to the leg levelers. They've never fallen off.
SirPoonga
  • Puck'em Up
« Reply #9 on: June 28, 2005, 03:07:43 pm »
The produce I linked to is the same brand, but I got the octagon shped ones.  The top side is foam so what ever sit on top of it sinks in, does not have problems with furniture staying on them.
CJK
« Reply #10 on: June 28, 2005, 06:05:06 pm »
[OT]
Whenever I see this thread in the main forum display, I can't help but laugh. We used to call the little sackful of hamburgers you get at White Castle "sliders" -- for what should be obvious reasons.
[/OT]
Back to our regularly scheduled discussion, already in progress...
-- Chris
AlanS17
    • AlanS17
« Reply #11 on: June 28, 2005, 06:06:29 pm »
<--- never been to a White Castle  ???
CJK
« Reply #12 on: June 28, 2005, 06:25:19 pm »
« Last Edit: June 28, 2005, 06:27:09 pm by CJK »
pointdablame
  • Last login:August 04, 2025, 06:16:22 pm
« Reply #13 on: June 28, 2005, 07:53:32 pm »
mmmm White castle.....
* pointdablame drools
first off your and idiot
D10
  • Pull my finger
« Reply #14 on: June 28, 2005, 11:55:20 pm »
Great!
i had to read this post again. 11 at night and now I am wanting a White Castle.  Well maybe more like 6-8 of them.
* goes to the fridge to forage...
DrewKaree
  • HAH! Nice one!
    • A lifelong project
« Reply #15 on: June 29, 2005, 12:20:29 am »
Take a McD's hamburger, cut it in half.  You now have 2 White Castle sliders.
Cheap and greasier than most, if you're going, you gotta get a sack 'o sliders
SirPoonga
  • Puck'em Up
« Reply #16 on: June 29, 2005, 12:58:45 am »
pointdablame
« Reply #17 on: June 29, 2005, 01:16:22 am »
No way. Nothing on this planet can compare with some White Castle burgers.  There are no other burgers that are teh same.....
DrewKaree
  • HAH! Nice one!
« Reply #18 on: June 29, 2005, 07:38:56 pm »
I meant in size only, nothing else.
If you really wanted to, you could stuff an entire slider in your mouth.  Bigmouths like Zakk or Bones could prolly fit 2 ;) ;D
