Author Topic: STERN SCRAMBLE DIMENSIONS  (Read 15856 times)
toyfiend2004
  • Last login:May 12, 2007, 09:07:04 pm
  • Like... where do you put the quarters, dude?
« on: June 27, 2005, 07:10:26 pm »
I am looking for the dimensions of an ORIGINAL Stern Scramble.
rohan
  • Last login:December 30, 2011, 08:24:04 pm
  • I'm a winner.
Re: STERN SCRAMBLE DIMENSIONS
« Reply #1 on: June 27, 2005, 07:18:09 pm »
I've got a Stern Astro Invaders.
« Last Edit: June 27, 2005, 09:40:14 pm by rohan »
It doesn't matter if you win or lose....it's how you play the videogame.
dogg0
  • Last login:December 14, 2014, 01:18:29 pm
  • ALL? no ALL!!!
« Reply #2 on: June 28, 2005, 09:52:39 am »
I have one, and can measure it tonight, if you dont find out in by then ;D
thou shalt not supress flatulence
-the bassmaster general
Nannuu
  • Last login:May 23, 2022, 11:55:21 pm
  • Anytime now, I'll start my cabinet
    • Will and Liliana's Projects and Family Photos
« Reply #3 on: June 28, 2005, 09:58:26 am »
I have a Scramble control panel if you want it.  Just pay the shipping.
Next I'll be on fries, and that's when the big money starts rolling in.
Avery
  • Last login:May 03, 2013, 12:52:02 am
  • Have fun! Make stuff.
Avery
Kremmit
  • - AHOTW -
  • Who the heck is that?
« Reply #5 on: June 29, 2005, 12:41:12 am »
If you're near Northern CA, I've got a beat up Scramble cab I need to lose.
crsdawg
  • Last login:September 13, 2019, 06:10:05 am
  • I plan to live forever, or die trying.
« Reply #6 on: June 29, 2005, 02:33:50 am »
here's a pic of your cabs. i know, it's washed out. i had to adjust the brightness since it was pretty dark when i took it.
keep in mind the checkmate will be empty.
sorry i was unable to get back to you the other day, i've been swamped lately.
oh yeah, here's the rough dimensions:
scramble-
H- 71
W- 24 1/2
D- 32
checkmate-
H- 64
W- 24 1/4
D- 27 1/4
fixedpigs
  • Last login:August 19, 2025, 01:29:35 pm
  • warning: drew can't handle my avatar...
« Reply #7 on: January 17, 2008, 02:28:18 pm »
hi...
can anyone with a scramble cabinet get some dimensions for me...?
i'd appreciate it... :cheers:
fixedpigs
« Reply #8 on: January 17, 2008, 08:40:23 pm »
to simplify my request...i made this little picture...
i think all that would really be needed for the general shape of the cab would be the side profile dimensions & the width of the back...
any help would be greatly appreciated...!
thanks... :cheers:
RetroACTIVE
  • Last login:January 28, 2024, 04:27:52 pm
  • Gramps
« Reply #9 on: January 17, 2008, 10:40:22 pm »
Here are the angles for the stern cab... I wanted to measure the entire thing for ya but could not find my tape measure!  :angry:  Anyway these measurements came from my old crappy "The End" stern cab which I myself am converting to a scramble.... I picked up new glass, control panel and marquee, they all fit perfectly so I believe all stern cabs are pretty much the same.  I've noticed that the scramble cab has the  lower rear cut on an angle while mine does not...
Hope this helps... If I can find my tape... I will finish it for you.
- Jim
edit - plans remvoved, use rev5
« Last Edit: January 24, 2008, 08:47:17 pm by RetroACTIVE »
Happy Gaming!
fixedpigs
« Reply #10 on: January 17, 2008, 10:44:31 pm »
awesome jim...thanks so much...!
i've got a tape measure right here on my desk that i'm looking at... ;)
here's hoping that you'll find yours... :applaud:
RetroACTIVE
  • Gramps
« Reply #11 on: January 17, 2008, 10:48:12 pm »
No sweat! I've got so much crap all over the place... its probably sitting inside a coin box somewhere ;D  I'm somewhat ashamed of myself...
Happy Gaming!
RetroACTIVE
  • Gramps
« Reply #12 on: January 17, 2008, 11:30:11 pm »
FP,
Here is one more... I was able to do a tracing of the side and measure it on paper so its pretty darn accurate... Each of the dimensions are straight cuts so that you can apply the radii as a second op  ;D...
I will get the rest when I find my tape... ;)
« Last Edit: January 24, 2008, 08:47:36 pm by RetroACTIVE »
Happy Gaming!
RetroACTIVE
  • Gramps
« Reply #13 on: January 20, 2008, 10:12:50 pm »
Here are the finished plans.... I did not outline the coin box shelf ... everything should be within ~1/16", and  the original cabinet (like many) was put together using rabbet edged "tounged" panels with the sidewalls grooved... and those details are not shown in the plans... So if you want to re-construct using that method  8) you would have to add the rabbet edge to all panels (effectively making them bigger)... If you plan on just butting the inside panels up against the sidewalls...glue and screw.. then these plans will work just fine  ;D.
Let me know if you all have any questions... or need clarification... I'll try my best.  Some numbers are a real pain to get without dismantling the thing....
Have fun!
« Last Edit: January 24, 2008, 08:47:48 pm by RetroACTIVE »
Happy Gaming!
fixedpigs
« Reply #14 on: January 20, 2008, 10:27:41 pm »
omg...
i just wanted some measurements...this goes above & beyond...!
 :notworthy:
my plan is to make a 3d model using sketchup...then to eventually make the cabinet later on in a year or so...
i love the angle of how the monitor meets the speaker panel... :cheers:
thanks again...!
RetroACTIVE
  • Gramps
« Reply #15 on: January 20, 2008, 10:38:03 pm »
Glad to help!  :D
Happy Gaming!
fixedpigs
« Reply #16 on: January 20, 2008, 11:51:01 pm »
hi jim...
could you measure the kick panel height again...?
it doesn't add up with your measurement of 36 7/8" & 38 1/4"(for the side panel measurement)...
thanks again... :cheers:
RetroACTIVE
  • Gramps
« Reply #17 on: January 21, 2008, 12:11:17 pm »
hi jim...
Yup... I'll double check the numbers tonight... also need to add distance to glass bezel/control panel ledger...  :cheers:
BTW... what doesn't add up? surely I'm missing something... ::)
This is what I get:
kick panel(36 7/8") + offset from top edge(1 5/16")  + offset from bottom(3/8")  = 38 1/4"
I will re-trace to be sure.
Happy Gaming!
fixedpigs
« Reply #18 on: January 21, 2008, 12:22:35 pm »
the measurements for the kick panel make it too long for the cabinet...
it looks like it should be closer to 33 1/8"...
and the height of the kick panel portion of the side panel should be closer to 34 1/2"...
the back of the cabinet adds up with all of the rear panels...so that's why i'm looking at the kick panel part being off(too tall)...
RetroACTIVE
  • Gramps
« Reply #19 on: January 21, 2008, 12:26:43 pm »
WOW! That looks great!... I was just poking around with sketchup, didn't even know it existed!
Ahh... I see what your saying... I'll re-trace tonight!
Nice having the 3D model.
BTW:  I did a complete set of Defender plans if you feel ambitions ;D
http://forum.arcadecontrols.com/index.php?topic=65938.0
« Last Edit: January 21, 2008, 12:31:27 pm by RetroACTIVE »
Happy Gaming!
RetroACTIVE
  • Gramps
« Reply #20 on: January 21, 2008, 05:45:31 pm »
Here are the latest .... The numbers are not really off... there were a few minor tweaks... it seems that your off by about 5 inches....???
I'll keep looking for the bad num3rs  ???
« Last Edit: January 24, 2008, 08:48:07 pm by RetroACTIVE »
Happy Gaming!
fixedpigs
« Reply #21 on: January 21, 2008, 06:12:05 pm »
aaaaahhhhhhhhhhhhhhhhh...
got it...
it was the one angle that was off... :banghead:
continuing onward...!
fixedpigs
« Reply #22 on: January 21, 2008, 09:59:03 pm »
here's what i came up with(sketchup files attached in the zip file)...
the only thing that raises an eyebrow is the distance from the strapping & cp ledger to the edge of the side panel...if it was closer in my model...then the glass wouldn't line up with the notch in the speaker panel...
any thoughts...?
SavannahLion
« Reply #23 on: January 21, 2008, 11:45:04 pm »
Wow! Someone else interested in the Stern Scramble cab? I'm not particular to the cab itself, but I just love that artwork.
Too bad those cab offers are three freaking years old.
RetroACTIVE
  • Gramps
« Reply #24 on: January 22, 2008, 08:56:42 am »
any thoughts...?
Not sure... I'll check again.... but it may be the speaker board length is a little off too... also it looks like you have edge routed on the ledger board (for the glass) too short... it should almost all be cut off to leave a 3/16" rabbet along the front toward the player... (not that this would make a diff here)
Lookin' real nice!
Yes the artwork is awesome... its my understanding that Brian http://www.oleszakcreative.com/  has the basics for the stencil kit already started... he needs a cab scan to get the alignment and accuracy done... I've been bugging a guy on klov to scan his cab...  :) so Brian can finish the stencils... then I can restore my Stern to Scramble!
Happy Gaming!
fixedpigs
« Reply #25 on: January 22, 2008, 10:20:03 am »
*fixed...
did you look at the sketchup file at all...?
RetroACTIVE
  • Gramps
« Reply #26 on: January 22, 2008, 10:32:45 am »
I most certainly did!  I can't believe how that came out... where the heck were you when I was doing my Defender anyway!  I myself have played with auto-cad and actually did a 3D design (I had a great tutor at the time) but man did it drive me crazy!  I'm a software not a mechanical engineer!
I'm playing with sketchup now... its definitely more my caliber...  I think all plans should be done this way... 2D "cuts" drawing and 3D "model/assembly" drawing.  If I had access to more cabs I would document the hell out of them, cause so many are old and stinky.
I like original machines... as long as they don't stink and look good.   However, I really like building a new ones (to the exact original specs), then get all of the trim pieces + electronics and basically have a carbon-copy nice shinny, not-so-smelly production quality arcade machine.  Now I may just do that with this one... I wasn't going to but... we shall see.
BTW:  I will most likely complete the plans... adding the coin box shelf and monitor shelf / bracket assembly... since these plans are coming out so nice... I hate to have them incomplete!
« Last Edit: January 22, 2008, 11:09:51 am by RetroACTIVE »
Happy Gaming!
RetroACTIVE
  • Gramps
« Reply #27 on: January 22, 2008, 07:50:17 pm »
any thoughts...?
I did another check... the numbers on the speaker panel were of by 1/16... but thats not it... The strapping is actually 19 1/2" long not 19"... so that changes things but not sure if it changes things for the better?
I added the position of the coin box shelf
« Last Edit: January 24, 2008, 08:42:06 pm by RetroACTIVE »
Happy Gaming!
fixedpigs
« Reply #28 on: January 23, 2008, 11:43:40 am »
is the circled part what it looks like in real life...?
maybe double check the two question marked distances...?
thanks...!
RetroACTIVE
  • Gramps
« Reply #29 on: January 23, 2008, 11:49:51 pm »
thanks...!
I wish it did... I double checked those distances and they are spot on...  :dunno I did however re-measure the top and marquee edge... those are a bit off from original... see slide 1...
edit - plans removed, use rev5
« Last Edit: January 24, 2008, 08:42:57 pm by RetroACTIVE »
Happy Gaming!
fixedpigs
« Reply #30 on: January 24, 2008, 12:11:35 am »
hmm...
just so we're looking at the same thing...is this what you're measuring...?
RetroACTIVE
  • Gramps
« Reply #31 on: January 24, 2008, 12:16:15 am »
OK.... What you have as 1 3/16"... I have as 1" and your 1" I have as 13/16".....
Happy Gaming!
fixedpigs
« Reply #32 on: January 24, 2008, 12:20:55 am »
ok...
i've adjusted accordingly...which results in this...-=\
(edit)
everything's 3/4" stock right...?
« Last Edit: January 24, 2008, 12:23:56 am by fixedpigs »
RetroACTIVE
  • Gramps
« Reply #33 on: January 24, 2008, 12:24:54 am »
That looks like 3/4"  ... the only other adjustment I can think of is the speaker shelf needs to be lifted up and moved forward...  I honestly don't get it... I must be way off somewhere else... I've traced this thing 3 times... I'm starting to feel like an idiot! :banghead:
(edit)
Yes 3/4" stock is correct.  not that "about 18mm" stuff you get now-a-days
« Last Edit: January 24, 2008, 12:27:26 am by RetroACTIVE »
Happy Gaming!
fixedpigs
« Reply #34 on: January 24, 2008, 01:17:30 am »
i don't know if your picture is supposed to match the angle or not...but that 115deg angle from the kick panel to the control panel is definitely not right...looks more like five degrees or so...
here's a sketchup file how your measurements add up...the circled parts in the attached picture are problem areas...
if you want...let's just focus on the side for now...getting that perfect...then we can move onto the next panel...
if you're up to it...
RetroACTIVE
  • Gramps
« Reply #35 on: January 24, 2008, 08:36:46 am »
Sorry to keep ping ponging you with this... (should have been right the 1'st time... its a rediculously simple cabinet for crying out loud!) the question is more that if "you" are up to it?
We'll get it right...
« Last Edit: January 24, 2008, 08:39:19 am by RetroACTIVE »
Happy Gaming!
fixedpigs
« Reply #36 on: January 24, 2008, 11:01:20 am »
i'm definitely up for it...
see that cross point about two thirds up on the cabinet...?
it's where the speaker panel and the monitor glass would meet...
it would probably be good to have that angle too...
RetroACTIVE
  • Gramps
« Reply #37 on: January 24, 2008, 11:40:10 am »
My pics are power point .... definitely not accurate... ;)
Happy Gaming!
RetroACTIVE
  • Gramps
« Reply #38 on: January 24, 2008, 08:39:55 pm »
OK... these HAVE to be correct :-\ ... I've re-traced the whole thing!  Seems to make more sense... most lengths are reasonable wholes or fractions with a couple of n/16" fractions... my guess is that once the 3d is done... those will round up or down to present better numbers.
I also added the angle of interest.   :cheers:
« Last Edit: January 24, 2008, 08:44:16 pm by RetroACTIVE »
Happy Gaming!
fixedpigs
« Reply #39 on: January 25, 2008, 10:56:40 am »
holy crap...now we're getting somewhere...
i changed your angles so they all make more sense(eg...115 instead of 116) and have come up with this...!
the only parts that don't 'seem' perfect are the two top-most angles...66.6 & 98.4...but all the measurements are good...!
i'll add the speaker panel and monitor strappings and see how that turns out...
