Author Topic: The mastery of AdvanceMenu/CD  (Read 1470 times)
delta88
  • Last login:May 20, 2025, 08:21:05 am
  • This place is still here?
« on: May 05, 2005, 06:45:58 pm »
I recently have mastered the art of setting up advance menu/CD to a point. The only thing I stil can't change is the startup screen, the one that says advance mame.. I like it.. I just need it sideways for a vertical display..
thx d88
btw, I can help answer any advance CD menu questions except that one ;)
Thenasty
  • Trade Count: (+17)
  • Last login:Yesterday at 11:38:03 am
Re: The mastery of AdvanceMenu/CD
« Reply #1 on: May 05, 2005, 06:55:12 pm »
thats the background image. Easy, just edit it and rotate it. BINGO...
« Last Edit: May 05, 2005, 06:57:04 pm by Thenasty »
Free VGA Breakout Cable
delta88
« Reply #2 on: May 05, 2005, 07:11:08 pm »
I'm talking about the very fist one you see.. I changed the 3 .png files in the img.app folder and then made my own advmenu.rc file which resides in the arcade folder to over ride the img.app settings... so really there are 4 backdrops and I can only change 3.. is there a way to cane the one that says "loading" at the very very start.
Thenasty
« Reply #3 on: May 06, 2005, 09:04:04 am »
Just downloded and look. The other 3 png are there exept what you mentioned.  I would say that if this was a WINDOWS 9x, or even XP or 2000, I bet its just the logo.sys logow.sys etc.. file. But if it Linux, i would not know what that would be. I don't think that PNG file is embeded into ADVMAME, ADVMENU itself. So it has to be the OS BOOT process.
gravity242
  • Last login:March 08, 2025, 10:29:47 pm
    • Super Pacman Restoration
« Reply #4 on: May 10, 2005, 05:12:04 pm »
I think that one is part of the Linux boot process.  I know for a fact it's not embedded into the advance mame/menu programs.  In addition to app.img there is a smaller file named initrd.img which handles some of the startup.  Try looking there. :)
Too bad you can't just grab a tree by the very tiptop and bend it clear over the ground and then let her fly, because I bet you'd be amazed at all the stuff that comes flying out.  - Jack Handey
elvis
  • Last login:January 13, 2025, 08:48:40 am
  • penguin poker
    • StickFreaks
« Reply #5 on: May 10, 2005, 05:29:05 pm »
There is a way to edit that image.  It's part of the Linux FBDev graphical boot overlay tools.
You need GIMP and a plugin to edit the image.  I'm just about to head out the door now, but when I get to work I'll find the relevant links and HOWTOs and post them up.
elvis
  • penguin poker
    • StickFreaks
« Reply #6 on: May 11, 2005, 06:38:41 am »
OK, as far as I am aware, the AdvanceCD uses bootsplash:
http://www.bootsplash.org/
Most of the hard work is done already (patching kernels and whatnot).  You should just need to re-attach a new bootsplash image as per the docs on that site.
