Author Topic: Fraggal Boot CD  (Read 3184 times)
SirPeale
  • Green Mountain Man
Fraggal Boot CD
« on: April 16, 2005, 08:20:03 pm »
Thought I'd give it a whirl.
It's quite out of date now, so I thought I'd update it.  The files are easy enough, but the booting I couldn't figure out.  What's its story?
JoyMonkey
  • Voodoo Wiki Master . . .
  • Last login:June 16, 2025, 09:16:27 pm
  • Candy is Dandy but Liquor is Quicker
    • JoyMonkey.com
Re: Fraggal Boot CD
« Reply #1 on: April 16, 2005, 09:45:01 pm »
Creating a bootable CD is tricky. I can't remember how its done anymore. Probably the easiest thing to do would be to take Fraggals's ISO image, delete the out of date files and add the new ones using UltraISO or WinISO.
sc1103
  • Last login:December 11, 2020, 08:37:35 pm
Re: Fraggal Boot CD
« Reply #2 on: April 16, 2005, 09:56:45 pm »
Google turned this up...looked pretty good
http://www.nu2.nu/bootcd/
SirPeale
Re: Fraggal Boot CD
« Reply #3 on: April 17, 2005, 08:38:20 am »
Yup, used UltraISO.  Updated some tools.  Took the optimized versions off the disc, and replaced it with .95.  Going to give it a go, hopefully it's still bootable!
SirPeale
Re: Fraggal Boot CD
« Reply #4 on: April 17, 2005, 08:52:52 am »
Well...it worked.  Quite well, too.  Thanks for the tip on UltraISO.
Now I just have to find a place to put the image.
SirPeale
Re: Fraggal Boot CD
« Reply #5 on: April 17, 2005, 09:37:51 am »
Oh yeah, one question regarding AdvMame.
When I want to exit, you hit [ESC] of course.  But in AdvMame it gives you a choice, exit or continue.  Is there a way to make a default exit, instead of giving you the choice?
JoyMonkey
    • JoyMonkey.com
Re: Fraggal Boot CD
« Reply #6 on: April 17, 2005, 09:45:51 am »
You can disable safequit in the advmame.rc config file.
Activates safe quit mode. If enabled, to stop the emulation, you need to confirm on a simple menu.
misc_safequit yes | no
Options:
   no    Disabled.
   yes    Enabled (default).
If the file `event.dat' (specified with the `misc_eventfile' option) is found the exit menu is shown only if one or more coins are inserted or if you are playing.
More info:
http://advancemame.sourceforge.net/doc-advmame.html#8.15.7
JoyMonkey
    • JoyMonkey.com
Re: Fraggal Boot CD
« Reply #7 on: April 17, 2005, 09:50:06 am »
Oh, I'll host it for you if you need a place.
SirPeale
Re: Fraggal Boot CD
« Reply #8 on: April 17, 2005, 12:03:06 pm »
I've got space, I'm just worried about bandwidth issues.
pointdablame
Re: Fraggal Boot CD
« Reply #9 on: April 17, 2005, 11:04:33 pm »
your best bet would be to make a torrent for it to share the bandwith problem.
first off your and idiot
EndTwist
  • Last login:May 26, 2022, 05:04:49 pm
  • Arg.
Re: Fraggal Boot CD
« Reply #10 on: April 17, 2005, 11:05:42 pm »
I can help seed it if need be. :)
SirPeale
Re: Fraggal Boot CD
« Reply #11 on: April 18, 2005, 12:22:50 am »
macattack
  • Last login:August 03, 2018, 05:35:16 pm
  • Cabinet builder to the stars!
Fraggal Boot CD
« Reply #12 on: August 31, 2012, 09:18:41 pm »
Anyone still have a valid link to a Fraggal boot ISo? Or can provide. Mines dead ;(
Pm me for custom cnc needs...
SirPeale
Re: Fraggal Boot CD
« Reply #13 on: October 05, 2012, 10:00:46 am »
I found a torrent, but it's years old.  I probably have it archived somewhere, but I do not know where.
If someone can up it, I'll host for a while.
macattack
Fraggal Boot CD
« Reply #14 on: October 06, 2012, 01:28:43 pm »
After much digging I found an old copy I had. Shout if anyone needs it
Re: Fraggal Boot CD
« Reply #15 on: October 06, 2012, 01:58:31 pm »
How outdated is this project?  Is there any interest in getting it going with a 64 build?  Seems that all the programing is already out there and it should be a matter of putting it all together.
xefned
  • Last login:June 07, 2021, 01:28:30 pm
  • Unearthing ancient threads is my special skill.
    • Matthew's projects
Re: Fraggal Boot CD
« Reply #16 on: October 06, 2012, 04:45:37 pm »
Putting it all together sounds like a big task, but count me interested if you do!
Modernizing it to work as a bootable USB flash drive might be a cool feature; a virtual retro arcade on your keychain.  :o
Searching for Zwackery, not because it's rare, because it's fun.
macattack
Fraggal Boot CD
« Reply #17 on: October 06, 2012, 04:47:41 pm »
Agreed always liked the simplicity of this build and the dos aspect ;) finding sound cards which could run dos became a nightmare.
