March 03, 2026, 08:58:11 pm
Creating a bootable CD is tricky. I can't remember how its done anymore. Probably the easiest thing to do would be to take Fraggals's ISO image, delete the out of date files and add the new ones using UltraISO or WinISO.
Activates safe quit mode. If enabled, to stop the emulation, you need to confirm on a simple menu.misc_safequit yes | noOptions: no Disabled. yes Enabled (default).If the file `event.dat' (specified with the `misc_eventfile' option) is found the exit menu is shown only if one or more coins are inserted or if you are playing.
first off your and idiot
your best bet would be to make a torrent for it to share the bandwith problem.
