Author Topic: How many buttons will I need to play all the Trackball games in Mame??  (Read 5404 times)
ratabase1
  • Last login:August 24, 2020, 09:51:51 pm
I need to know if anybody knows the maximum number of buttons I will need on my control panel, in order to play all the Trackball games in Mame?  I am especially interested in the golden tee games.  Thanks.
NoBonus
  • Last login:January 07, 2007, 06:48:58 pm
  • "Now that's a fine example of California's Gold"
That's a really good question I would also like to know the answer for.
Thenasty
  • Trade Count: (+17)
  • Last login:Yesterday at 11:00:10 pm
3 in each side
Free VGA Breakout Cable
NoBonus
What about MAME games? Are there any trackball games that require more than one button?
NoOne=NBA=
Missle Command uses 3.
jcrouse
    • CPViewer
Am I missing something or didn't the post directly above yours say "3 each side". I'm not sure this is correct but you seemed to completely ignore the response.
Having a bad day here (sorry),
John
NoBonus
I thought that was referring to Golden Tee Golf solely.
jcrouse
    • CPViewer
As usual, I'm wrong and apologize. I've had a beer now and all is right with the world again.
Sorry,
John
SirPeale
  • Green Mountain Man
What if David Foley decides to trademark arcade buttons.  That would be bad.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
I never played it, but doesn't old school Star Trek have four buttons?  Not sure if that's playable with 3 on each side.  Somebody who played it?
FWIW, I went with 3 on each side.
Robin
Knowledge is Power
NoBonus
Re: How many buttons will I need to play all the Trackball games in Mame??
« Reply #10 on: March 14, 2005, 06:15:56 pm »
NoOne=NBA=
« Reply #11 on: March 14, 2005, 06:57:19 pm »
It's probably PLAYABLE with 3 buttons/side, but one of the controls (likely warp, or photons) would be really slow to get to, and the trackball would be a poor substitute for a spinner.
This would be especially problematic on the higher levels where you need to spin around, then warp, then fire a photon to hit groupings at the start of the level.
Flinkly
« Reply #12 on: March 14, 2005, 10:32:04 pm »
i looked it up here...
http://www.jstookey.com/arcade/sortinfo/
and it gave me these with 4 buttons:
Discs of Tron (Environmental) (dotrone)
Major League (mjleague)
and it gave me these with 3 buttons:
Arcade Classics (prototype) (arcadecl)
Blades of Steel (version E) (bladstle)
Krazy Bowl (krzybowl)
Missile Command (set 1) (missile)
SDI - Strategic Defense Initiative (sdi)
also, why would you need buttons on both sides?
paigeoliver
  • Awesome face!
« Reply #13 on: March 14, 2005, 11:29:28 pm »
Discs of Tron is not a trackball game.
To actually play Major league you first need to run one of the few mame versions it doesn't crash out on, and then you will need two trackballs, a spring loaded bat joystick and a total of 7 buttons, one side has 3 and the other side has 4.
So the real answer is 3, unless you have two trackballs and a spring loaded bat joystick.
jdjuggler
  • Last login:May 08, 2022, 10:54:37 pm
  • Hurray! I don't have pockets for quarters anyway!
« Reply #14 on: March 16, 2005, 09:14:00 am »
So, are most builders putting mouse buttons on the right or left side of the trackball?
It seems that the popular trackball games have the buttons to the left of the trackball (centipede, missile command).   Oddly, a bunch of CP's I've seen have the buttons on the right... Why?
And, what are those people that don't have mouse buttons at all doing?  I suppose they set up their games to use the P1 or P2 buttons, right?
But, then you wouldn't have the mouse buttons for windows support...  And, possible other non-mame Windows games that use the mouse buttons.  Any thoughts?
Thanks,
JD
NoOne=NBA=
« Reply #15 on: March 16, 2005, 09:37:03 am »
Because they've finally shaken off their "arcade authentic" phobias, and decided to put the controls where it works best for THEM.
I use my I-pac for game inputs.
For OS-Nav, I've got a wireless mouse receiver thrown into my cab.
When I NEED a mouse, all I have to do is get it close enough to the cabinet.
