Author Topic: Urgent Help with Robotron Error!  (Read 2704 times)
Jedi Master Matt
  • Last login:February 22, 2009, 02:51:09 pm
« on: March 03, 2005, 10:14:04 pm »
Greetings,
I just upgraded my version of MAME to .92 and have encountered an error when trying to run Robotron and it's something I haven't seen before.  Hopefully one of you have an idea for a solution... I've deleted all my config and controller files in hope of solving it and it seems to be isolated to just Robotron.
Here's the error:
error: invalid value for paddle_device: mouse1
ignoring line
error: invalid value for dial_device: mouse 1
ignoring line
error: invalid value for trackball_device: mouse 1
ignoring line
decoder.4 not found
decoder.6 not found
error: required files are missing, the game cannot be run
So far in my testing, all the other mouse/spinner/trackball games are working just fine.   My cabinet also has MAME.86 installed and Robotron works just fine.
Thanks in advance for any assitance!
Jedi Master Matt
Re: Urgent Help with Robotron Error!
« Reply #1 on: March 03, 2005, 10:24:06 pm »
I've done a bit more testing and the problem is more widespread than I first thought... it's all of the Williams games (Joust, Stargate, etc.).
Jedi Master Matt
« Reply #2 on: March 03, 2005, 11:14:34 pm »
Ok.. I've made a bit more progress.   The issue with the mouse was related to me using an older .ini file.   Fixed it by making a new one.
The other issue is potentially bigger.   It's related to the decoder not being found.   My MAME set for these games didn't have this decoder in the roms.
From what I've read so far, .92 had  lot of rom changes and a lot of decoders being added.
Does anyone know what ROMS were changed with decoders?
dabone
  • Last login:July 15, 2025, 08:32:17 pm
  • Time to work...
« Reply #3 on: March 03, 2005, 11:58:29 pm »
All of the classic Williams game had proms added.
Either update your roms, or go back to the earlier version of mame.
Later,
dabone
Jedi Master Matt
« Reply #4 on: March 04, 2005, 08:21:13 am »
Dabone - that's what I suspected.
I pieced Defender, Stargate, and Joust back together.   Does anyone know what other classic Williams games were effected?
Thenasty
  • Trade Count: (+17)
  • Last login:Today at 01:27:16 am
« Reply #5 on: March 04, 2005, 08:35:08 am »
MAWS is a friend
Williams 6809 system
    driver by Michael Soderstrom, Marc LaFontaine, Aaron Giles
   Games supported:
      * Defender
      * Mayday
      * Colony 7
      * Stargate
      * Robotron
      * Joust
      * Bubbles
      * Splat!
      * Sinistar
      * PlayBall!
      * Blaster
      * Mystic Marathon
      * Turkey Shoot
      * Inferno
      * Joust 2
      * Lotto Fun
   video-decoder proms added for Defender,Stargate,Robotron,Joust,Sinistar,
   Bubbles, etc. by HIGHWAYMAN, all decoder proms are 512x8.
   defender original pcb's used a single prom(decoder1).
   newer defender pcb's used 2 proms(decoder2,decoder3) this was to allow
   video inversion for the coctail table, decoders 1 & 2 are the same code.
   white was first romset, then green/blue the only difference was the chips used,
   the final version was red, only red can run in a coctail table.
   (red also has *much* improved enemy AI and is harder to play)
   Colony7 uses a different chip for decoder2(cs10), but decoder3 is the same.
   early stargate pcb's used decoder4, and decoder5.
   newer stargate pcb's and the other games on that hardware used decoder4 and decoder6
   this was probably just to fix a minor bug in decoder5.
   Blaster uses decoder4 and decoder6 and 2 other proms.
   if i could find more proms i would clean this up into a table - maybe later.
Free VGA Breakout Cable
