Author Topic: Problem showing snaps under ArcadeOS and Vantage  (Read 1696 times)
Craig
  • Last login:September 29, 2014, 05:51:56 am
    • Creation on the Web
« on: March 02, 2005, 06:18:46 am »
Trying to run vantage under DOS. Comes up with a mass of error junk.
Arcadeos complains about a missing pcwrap or some crap. What is this? I finally got my Vibra 16c ISA sound card working and all I want to do is get this box with vantage running but it comes up with error junk. Running vantage under Winxp (without running a game) works. Comes up with the usual intro screen.
Using Windows DOS version 7 or something.
Please help.
« Last Edit: March 03, 2005, 01:00:47 am by Craig »
I love the life I lead. I wish I could afford it.
SirPeale
  • Green Mountain Man
Re: Vantage and Arcadeos hopeless under DOS
« Reply #1 on: March 02, 2005, 09:15:47 am »
Please post *specific* errors.
Craig
« Reply #2 on: March 02, 2005, 09:27:10 am »
Yah good point Peale, but I can't because it was in DOS only.
It's the usual error that comes up sometimes in Windows under DOS mame. Ahh this is annoying..
SirPeale
« Reply #3 on: March 02, 2005, 11:02:07 am »
I dunno about the AOS thing you're getting (can you be more specific on that at least?) but if you're getting the error mentioned in a bunch of other VAntAGE threads, you need to use cwsdpmi with the -x parameter, or something like that.  Do a search for vantage in the software forum.
lokki
  • Last login:May 05, 2025, 06:18:51 pm
« Reply #4 on: March 02, 2005, 01:00:13 pm »
I can't believe I'm replying to this. Give some info.
So what if the error is under DOS. Get a pen an pencil and write it down. Take digital picture. Do something.
Also search the forums to see if anyone has seen the error before.
Error junk or some crap do not help in troubleshooting your issue
Craig
« Reply #5 on: March 02, 2005, 10:46:17 pm »
Sorry, this is part of the error when running Vantage.
Code: [Select]
Exiting due to signal SIGSEGV
Page fault at exp=00054a51, error=0004
Fixed the Protected mode wrap.
Vantage comes up with that error when run alone, but now runs games.
ArcadeOS is fixed now too.
Btw, does anyone know how to get ArcadeOS to show snapshots when using Vantage with ArcadeOS?
I am running ArcadeOS 2.52 with Vantage 1.12.
Thanks.
« Last Edit: March 02, 2005, 10:48:01 pm by Craig »
SirPeale
« Reply #6 on: March 02, 2005, 11:03:25 pm »
The snaps can't be zipped, and have to be 8 bit, IIRC.
Craig
« Reply #7 on: March 02, 2005, 11:36:32 pm »
I did that and they still won't show.  :'(
lokki
Re: Problem showing snaps under ArcadeOS and Vantage
« Reply #8 on: March 03, 2005, 10:15:07 am »
Did you check out this thread.
http://forum.arcadecontrols.com/index.php/topic,28999.0.html
The problem seemed to be limited to some games (galaxian and a few others)
Hope this helps
Craig
« Reply #9 on: March 03, 2005, 05:36:44 pm »
Saw that thread. Mine works OK. It's just the snaps not showing.
Thenasty
  • Trade Count: (+17)
  • Last login:Today at 08:27:56 pm
« Reply #10 on: March 03, 2005, 07:21:47 pm »
snaps must be 256 colors for AOS
Free VGA Breakout Cable
Craig
« Reply #11 on: March 03, 2005, 07:46:14 pm »
Done that. I don't remember having a problem using snaps with MAME & ArcadeOS, but I seem to have a problem now using ArcadeOS and Vantage.
Craig
« Reply #12 on: March 03, 2005, 08:22:31 pm »
I fixed the problem.
I had to set the vantage.app file to point to c:\ instead of c:\vantage
