Author Topic: Standard drill bit size for buttons?  (Read 2735 times)
j123vt_99
  • Last login:August 24, 2006, 09:41:12 am
« on: February 24, 2005, 09:10:50 am »
is there a standard size drill bit that you guys use to drill holes for buttons? Are all push buttons the same size?
Pictures of my Missile Command  http://www.nimsu.com/mc/mc.html
terryd
  • Last login:October 27, 2005, 03:14:58 pm
  • To each his own... Unless I want it first!
Re: Standard drill bit size for buttons?
« Reply #1 on: February 24, 2005, 09:14:20 am »
You will need to make the holes 1 1/8".  You can use whatever kind of bit you want.  Some use spade bits, others use hole saws, and others even use forstner bits...  Dpending on the material you're trying to drill through, one may be better than the others.  I used a hole saw for mine.  I drilled through lexan and MDF at the same time...
j123vt_99
« Reply #2 on: February 24, 2005, 09:20:43 am »
Lilwolf
« Reply #3 on: February 24, 2005, 09:32:05 am »
Yes...
Thenasty
  • Trade Count: (+17)
  • Last login:September 16, 2025, 11:36:40 pm
« Reply #4 on: February 24, 2005, 09:33:11 am »
is there a standard drill bit that will do 1 1/8"? I assume so
Holy crap, thats one heck of a drill bit..
Do you have a drill that support that size ? If you don't, its cheaper to get a hole saw
« Last Edit: February 24, 2005, 09:36:53 am by Thenasty »
Free VGA Breakout Cable
shawnzilla
  • Last login:May 05, 2022, 12:01:55 pm
« Reply #5 on: February 24, 2005, 09:47:49 am »
Correct me if I'm wrong, but don't leaf-switch buttons require a larger hole than microswitch?
Thenasty
« Reply #6 on: February 24, 2005, 10:03:11 am »
no, same size hole.
« Last Edit: February 24, 2005, 10:09:01 am by Thenasty »
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #7 on: February 24, 2005, 10:10:02 am »
j123vt_99 : Wood or metal?
NO MORE!!
Shape D.
  • Last login:July 05, 2012, 06:17:57 pm
  • >Look at me, I'm a Newbie<
« Reply #8 on: February 24, 2005, 10:13:05 am »
no, same size hole.
  :-X  Shape D holds back improper joke.  :angel:
Hey Baby, Have you ever met a Newbie with 38 pages of previous posts before? Do you Want to?
Thenasty
j123vt_99
« Reply #10 on: February 24, 2005, 10:22:52 am »
undetermined yet :)... won't be building for a few months
Lilwolf
« Reply #11 on: February 24, 2005, 10:35:33 am »
should be one of the first things you consider.
I don't recommend them unless your working with an existing cabinet that has them.. Even then, I would see if there would be a way to get a wood panel to work.  Just MUCH easier to work with... Only downside is some controllers don't work well with them.
j123vt_99
« Reply #12 on: February 24, 2005, 11:03:52 am »
Shape D.
« Reply #13 on: February 24, 2005, 11:25:32 am »
j123vt_99
« Reply #14 on: February 24, 2005, 11:41:53 am »
brained
  • Last login:September 10, 2025, 10:35:06 am
  • Raised by Atari
    • Nux
« Reply #15 on: February 24, 2005, 12:37:57 pm »
With metal Cp's you need to put a lot of work, make it from wood and avoid the hassle
my cp is metal, and boy!! a really tough job
Lilwolf
« Reply #16 on: February 24, 2005, 01:37:50 pm »
You can always go for cardboard also
Pete Harcoff
  • Last login:May 29, 2005, 07:47:46 pm
« Reply #17 on: February 24, 2005, 03:19:09 pm »
Knievel
    • Knievel Kustoms
« Reply #18 on: February 24, 2005, 06:57:38 pm »
I know for a fact that the Wico translucent Leafs need a 1 3/16" hole.
I had to go buy another bit for the damn things.
tommy
« Reply #19 on: February 24, 2005, 07:16:27 pm »
Btw ive got some 13/16 buttons
Wienerdog
  • Last login:December 08, 2020, 06:28:51 am
  • If it's worth doing, it's worth overdoing
« Reply #20 on: February 28, 2005, 07:51:09 pm »
13/16... I've never seen buttons under an inch... ;)
This opinion was created from 100% post consumed information.
tommy
« Reply #21 on: February 28, 2005, 09:37:00 pm »
they are from arlington horse racing the win , place , show buttons
Wienerdog
« Reply #22 on: February 28, 2005, 11:48:00 pm »
Holy smokes, I've got the Wico translucents and just drilled holes now.  I used a 1 1/8" Forstner bit.  Some of the buttons were snug, and some were fine but that seemed like the right bit to use.  You could get away with using a 1 3/16" bit and it might even give you better transparency, but the 1 1/8" will work.
FractalWalk
  • Newbie
  • Last login:September 20, 2010, 06:12:37 pm
  • Life is time spent fighting entropy.
« Reply #23 on: March 01, 2005, 12:26:07 am »
I got WICO translucents and used a 1-1/8 spade bit.
saint ganked my avatar.
Sephroth57
  • Poo Monkey
  • Last login:June 07, 2020, 11:17:00 am
    • Check it out!!!
« Reply #24 on: March 01, 2005, 10:20:33 am »
this is what you want BTW a Hole Saw, not a huge ass drill bit
i used a 1 3/16 and it worked fine for my happs competition buttons
"Owens is the ringleader in the ass hat circus"  D K
sodapopinski
  • Last login:February 12, 2011, 11:13:41 am
  • if I only had normal friends
« Reply #25 on: March 01, 2005, 11:26:21 am »
a spade bit will work fine too
Shape D.
« Reply #26 on: March 01, 2005, 12:11:49 pm »
A holes a hole.  ;)
bowza
  • Last login:July 08, 2005, 03:04:35 pm
« Reply #27 on: March 01, 2005, 04:02:29 pm »
Any tips for cutting perspex holes?
Cheers
Bowza
Havok
« Reply #28 on: March 01, 2005, 04:34:47 pm »
