Author Topic: Sitting a Sound Card in DOS...help  (Read 1622 times)
ahmer
  • Last login:March 16, 2014, 02:40:21 pm
  • Do as you like.
    • IC Markets Rebates and Discount
« on: February 21, 2005, 04:48:00 pm »
I attached a Creative Labs PCI 128 VIBRA sound card and also install its dos drivers reqired.
I am using arcadeos and dmame9.0.After running arcadeos there was a
starting sound,menu sound,Run game sound and also Exit ArcadeOs sound but there was no sound in game...any help...
Please check some of these DOS settings and tell me if i am missing something...
ROM: Spaceknight
  • Last login:September 04, 2008, 09:54:21 pm
  • I'm a girl gamer!
Re: Sitting a Sound Card in DOS...help
« Reply #1 on: February 21, 2005, 04:53:13 pm »
Change soundcard=1 and try again.
ahmer
  • Do as you like.
« Reply #2 on: February 21, 2005, 05:11:17 pm »
i already do this in both mame.cfg and arcadeos.cfg
Thenasty
  • Trade Count: (+17)
  • Last login:Today at 01:25:44 pm
« Reply #3 on: February 21, 2005, 07:57:24 pm »
I suggest elimiting AOS first. Just use Dmame and make sure the sounds works there, then worry about the other one.
Free VGA Breakout Cable
Chris
    • Chris's MAME Cabinet
« Reply #4 on: February 22, 2005, 04:00:56 pm »
The Creative Labs PCI cards are awful in DOS.  You might have better luck with a different card.
--Chris
Bloinkxp
  • Last login:August 30, 2020, 11:20:28 am
« Reply #5 on: February 22, 2005, 04:38:20 pm »
What kind of motherboard do you have?  Verify that the IRQ and DMA are free in the bios before you allocate them.  You might need to turn off Pnp OS and configure the IRQs yourself.
Good luck
Nothing witty here...move along.
Chris
« Reply #6 on: February 22, 2005, 05:28:24 pm »
The PCI 128 Vibra is emulating a "real" SoundBlaster in software, so all of the settings need to be "just right".
--Chris
--Chris
ahmer
  • Do as you like.
« Reply #7 on: February 22, 2005, 05:30:54 pm »
I am not agree with you here.
http://easymamecab.mameworld.net/html/snddosdr.htm
Bloinkxp,I will check out those in the Bios,while it was a GFXL mother board.
ahmer
  • Do as you like.
« Reply #8 on: February 22, 2005, 05:34:53 pm »
--Chris
i will check it again.
what about other Creative PCI cards.? i mean favourite,easy to setup in dos.
