Author Topic: Spinner - is this the wrong kind of hard drive?  (Read 693 times)
megashock5
  • Last login:May 19, 2015, 06:51:16 am
« on: January 21, 2005, 08:40:37 am »
I finally found an old hard drive to take apart, but it's not looking like the ones in the various instructions I've seen here.
Here are a couple of pics, is this one a lost cause?
thanks!
Thenasty
  • Trade Count: (+17)
  • Last login:Yesterday at 12:46:10 pm
Re: Spinner - is this the wrong kind of hard drive?
« Reply #1 on: January 21, 2005, 08:48:16 am »
you have to take a look at the center of the bearing part on both sides. If it got hole (threaded in top side, bottom is a hole) then it doable.
The top will always be threaded cause thats where the screw came off, but the bottom part is the important one, if it got a hole, its hard to make a hole dead center without destroying it. That bottom hole is where the encoder wheel get glued in.
Its hard to drill a hole, not like a woman where you can drill a hole easily with a little effort and you can even drill it in the dark
Free VGA Breakout Cable
