Author Topic: Anyone put a button on the front for pinball plunger?  (Read 2714 times)
megashock5
  • Last login:May 19, 2015, 06:51:16 am
« on: January 19, 2005, 11:00:50 am »
I haven't even messed with Visual Pinball yet, so I don't know what the default controls are. But I was wondering about putting a button on the front of the CP about where the plunger would be on a pinball table.
I guess the question is, since it seems most people don't do this, what button works as the plunger? And how hard would it be to add this button (i.e. if it used a button that already is used, would I need to run wires from one input on the encoder to two different buttons)?
thanks in advance!
BobbyG66
  • Last login:November 13, 2016, 11:52:09 am
  • Current project: Dodgeball
Re: Anyone put a button on the front for pinball plunger?
« Reply #1 on: January 19, 2005, 11:41:41 am »
I plan on mounting a button in the front where the plunger would go.
I have seen it a few times. Someone actually used a real plunger and connected it to a switch.
In VP the ENTER key acts as the plunger. I think you can remap the key in VP also.
Half of the people you meet are below average.
megashock5
« Reply #2 on: January 19, 2005, 01:04:09 pm »
Thanks for the info!
Doc-
  • Last login:April 09, 2007, 01:04:51 am
  • Carpe Arcadium!
    • Doc's Modular MAME
« Reply #3 on: January 19, 2005, 04:57:19 pm »
Yes,
  I did it on my modular cabinet (see link in signature).  I have two buttons on each side, one for flipper and one for right/left nudge.  I also have the button front right for the plunger.  I have them wired to the regular buttons, and then just program appropriately in Visual pinball to match.
  It works remarkably well with Visual Pinball.  In fact I've been going through a visual pinball phase lately and had a great time with it.  If you do a google search, you can find lists of the best pinball machines - which are pretty well done in Visual Pinball and a blast to play.
Cheers!
Doc-
erikthecat
  • Last login:September 21, 2008, 06:53:57 am
  • I 've Built My Own Arcade Cabinet & Controls!!
    • BYO Williams Defender Trubute
« Reply #4 on: January 19, 2005, 05:58:12 pm »
i got a pinball plunger where a pinball plunger should be:)
it doesn't look too out of place, with the flipper buttons on the side.
all stuck on the alternate larger cp.
ball launch is wired so that when the plunger returns to normal, the ball launches. pushing the plunger in nudges the machine up.
yep! i'm mad:)
GaRy:)
Regards,
GaRy:o)
please visit...
www.SplatThatCat.com/arcade/
www.SplatThatCat.com/artwork/
Classic arcade game playing,
in style, in your own home:o)
GameOver
  • That's right. I'm Abe Froman.
  • Last login:February 11, 2013, 06:54:31 pm
  • Got a quarter?
    • Check out my cab!
« Reply #5 on: January 19, 2005, 08:16:30 pm »
I mapped the plunger to my P1 joystick.  Not a perfect solution, but better than a button IMO.  You pull back on the joystick, then let it go!  It sorta gives a plunger effect, better than a button anyway!
Chris
    • Chris's MAME Cabinet
« Reply #6 on: January 19, 2005, 08:25:52 pm »
I have a real plunger I'm planning to add.  I'm going to wire up the Normally Closed contacts of a microswitch instead of the Normally Open, so the longer the plunger is pulled out the stronger the shot will be.
I like the idea of bumping the plunger for nudge... I may have to steal that one.
--Chris
--Chris
coachcarstens
  • Last login:November 19, 2007, 10:42:59 pm
« Reply #7 on: January 19, 2005, 09:19:02 pm »
I also put a button where the plunger would go.  I thought that was a very common thing actually.
Chris
lcddream
  • Last login:December 04, 2024, 03:59:31 pm
  • Say goodbye to gravity...
megashock5
« Reply #9 on: January 20, 2005, 09:32:36 am »
Gameover,
Your joystick solution sounds intriguing. The way you described it sounds like the ball launches when the stick returns to normal. How would that be wired?
Hurray Banana
  • Last login:October 18, 2016, 02:11:08 pm
  • My unique teaching style
« Reply #10 on: January 20, 2005, 10:25:15 am »
I've got a plunger and an extra player 1 start button sat side by side on the front of my CP.
It works pretty well but it would be cool to have a real plunger.
Has anyone tried creating a real tilt switch mechanism for implementing tilt, using something like a metal plumb weight hanging through a ring?
Cheers Eric
TZ Pinball, PowerDrift upright, 4 vertical Mame cab and 8 way 2 player Mame cab
oldsage
  • Last login:December 19, 2005, 09:11:47 pm
  • Does SHMIGRUB ring any bells??
« Reply #11 on: January 20, 2005, 10:28:33 am »
I had a cool sig once... But it had to go because of *someone*... You know who you are!
Thenasty
  • Trade Count: (+17)
  • Last login:Yesterday at 12:02:52 pm
« Reply #12 on: January 20, 2005, 10:30:16 am »
Gameover,
Hehe, your joyticks are already wired (unless your planning not to have any joystcik at all). Just assign MAME to use that joystick value.
Free VGA Breakout Cable
Thenasty
« Reply #13 on: January 20, 2005, 10:38:55 am »
when this discussion was being in the open years ago (God was it been that long), they were talking about applying this gadget. I bought one and never got around to trying it out.
Hurray Banana
« Reply #14 on: January 20, 2005, 10:52:48 am »
I was actually thinking of something like this, a mechanical switch. I wonder if you'd need a circuit to time contact duration?
If this is horse crap say so.
Cheers Eric
Thenasty
« Reply #15 on: January 20, 2005, 11:13:23 am »
you can buy what they use in a real pinball machine.
http://www.happcontrols.com/amusement/pinball/95032800.htm
megashock5
« Reply #16 on: January 20, 2005, 11:49:34 am »
Gameover,
Yeah, I realize the joystick will already be wired. 4 inputs: up, down, right, left (+ combinations). The description that GameOver gave sounded like the ball was released when the stick returned to center, not when one of the stick's switches was activated. That was what my question was about.
Hurray Banana
« Reply #17 on: January 20, 2005, 11:59:51 am »
@$10 I might have a go at scratch building one. I think I can figure out the parts I'm gonna bodge together using their sketch
Cheers Eric
Thenasty
« Reply #18 on: January 20, 2005, 01:12:17 pm »
Gameover,
In some pinball games, the ball releases when you release the switch (joystick method). Some releases when the switch is pushed (closed).
Chris
« Reply #19 on: January 20, 2005, 02:12:22 pm »
That is how Visual Pinball works.  The longer the button is held, the stronger the plunger shot, and the bal is released when the button is released.
--Chris
megashock5
« Reply #20 on: January 20, 2005, 02:46:24 pm »
Chris/Nasty,
Very cool, that's what I was wondering about.
So I assume that mapping the plunger to a joystick is done in the VP software? And if so, I'm also assuming you could map it to the player 2 stick since the plunger is usually on the right side? (Planning on putting on the machine, but I've never used it)
thanks again for all the great input guys!
« Last Edit: January 20, 2005, 05:10:36 pm by megashock5 »
GameOver
  • Got a quarter?
    • Check out my cab!
« Reply #21 on: January 23, 2005, 08:04:58 pm »
Exactamundo.  Map the plunger to whichever joystick (I'm left handed, so I mapped it to P1, just seemed right for me) in VPinball config.  The longer you pull back on the joystick, the more power in your shot just as Chris described.  The ball doesn't go until you release the joystick.  It works really well.
