Author Topic: cheapest marquee holder?  (Read 4632 times)
megashock5
  • Last login:May 19, 2015, 06:51:16 am
« on: January 11, 2005, 11:19:00 am »
What has everyone found to be the cheapest option for the marquee holder? I know Happ sells one, but I was wondering if anyone found anything else that worked that was cheaper or available at common stores.
thanks!
SirPeale
  • Green Mountain Man
Re: cheapest marquee holder?
« Reply #1 on: January 11, 2005, 11:21:32 am »
Corner protectors.  Sold in your local hardware store.
Buddabing
« Reply #2 on: January 11, 2005, 11:30:47 am »
thanks!
Staples or nails. :)
Please read the wiki!
quarterback
« Reply #3 on: January 11, 2005, 11:37:45 am »
-- Chad Tower
megashock5
« Reply #4 on: January 11, 2005, 12:35:16 pm »
Peale,
What do they look like? Are they strips like the marquee holders? Any certain area of a hardware store I should look?
thanks!
Beeeph
  • Last login:October 18, 2006, 12:31:44 pm
« Reply #5 on: January 11, 2005, 02:18:11 pm »
strips of aluminum angle work great too.  Put a nice coat of black semi gloss paint on em and they look great.   They can be found in the hardware section at your local home depot/lowes for about $3 a strip (4ft).
Jabba
  • D-Hutt
  • Last login:November 16, 2020, 02:17:20 pm
  • I find your lack of faith...disturbing...
« Reply #6 on: January 11, 2005, 02:28:46 pm »
Drywall corners work well. You can also consider using the L angle they use for drop ceilings that screw against the wall. Paint them as directed above...
Vids:  Home built MAME machine, Crystal Castles. Arkanoid
Pins:   Williams Aztec (working). Stern Nugent (not working...yet), Williams Phoenix (major not working, missing parts.... )
Always on the lookout for buying 90's game with Ramps that need work...
paigeoliver
  • Awesome face!
« Reply #7 on: January 11, 2005, 02:49:59 pm »
I use the drop ceiling rails painted black. You get like 10 foot of the stuff for like $2.
megashock5
« Reply #8 on: January 11, 2005, 03:04:39 pm »
Drop ceiling rails? Never thought of that. Are they an L-shape?
How would you attach them? Just positioned on top of the wood and in front of the marquee, then screw them into the wood?
thanks for the suggestions!
RayB
  • I'm not wearing pants! HA!
  • Last login:July 10, 2025, 01:33:58 am
  • There's my post
    • RayB.com
« Reply #9 on: January 11, 2005, 03:06:16 pm »
Did you search the board? This has been discussed many times.
There are metal L rails, plastic/vinyl L rails, window edge channels, etc....
NO MORE!!
Beeeph
« Reply #10 on: January 11, 2005, 04:54:55 pm »
Relax RayB, in your attempt to make people more act more diligently, you only end up sounding like an angry-at-the-world video game nerd because there's one solution presented in this discussion that wont be found in similar discussions...
it's a damn good thing megashock5 asked this question for the millionth time, otherwise I would've never thought of using chewing gum as the ultimate innexpensive way to mount my marquee.
« Last Edit: January 11, 2005, 04:56:33 pm by Beeeph »
megashock5
« Reply #11 on: January 11, 2005, 05:12:34 pm »
Never asked a question that's been asked before, Beeeph? Ray?
Yeah, I should have searched. I forgot about that feature. Sorry. I am glad that *most* of the people I've come across here are helpful and cordial.
I bow to the greatness or your message board protocol.
I tried the search and found 3-4 posts that addressed the question (most were about the Happs holders). Enough to get good information, but I appear to be far from the "millionth."
Thanks to those of you who actually gave helpful input. Please know that it's appreciated.
« Last Edit: January 11, 2005, 05:18:18 pm by megashock5 »
Beeeph
« Reply #12 on: January 11, 2005, 05:40:21 pm »
I'm just messin with you megashock5.
« Last Edit: January 11, 2005, 05:42:51 pm by Beeeph »
megashock5
« Reply #13 on: January 11, 2005, 06:03:20 pm »
Just messin' back, man. It's all good :)
I really do love this place though. I started coming here when I was still on the fence about whether do actually do this or not. The people on here were so great that it convinced me to take the plunge.
RayB
  • There's my post
    • RayB.com
NO MORE!!
Nannuu
  • Last login:May 23, 2022, 11:55:21 pm
  • Anytime now, I'll start my cabinet
    • Will and Liliana's Projects and Family Photos
« Reply #15 on: January 12, 2005, 01:33:10 am »
I say go for the drop ceiling rails also.  They are L shaped and you put them on just like you said.  The L shape is used around the walls.  It is $1.69 for 12 feet at my local Home Depot.
Next I'll be on fries, and that's when the big money starts rolling in.
stevejt
  • Last login:January 01, 2022, 01:21:32 pm
  • stevejt.com
    • My site
« Reply #16 on: January 12, 2005, 08:18:58 am »
They also make wooden molding that is "L" shaped.  I beleive it is called "outside corner" molding.  That might be easier to trim if you aren't happy with the drop ceiling edge.  But the drop ceiling edge does come in black.  They also make a metal sheetrock edge that is shaped like like a "J".  It comes in black and would match the drop ceiling edge. (Both folded edge sheetmetal).  It might be easiest for you to use the "J" for the bottom,(with a small spacer to hold the marquee foward), and the "L" to hold in the top.  All depends on your cab, and your creative skills.
Steve
megashock5
« Reply #17 on: January 12, 2005, 08:28:02 am »
Nannuu, Steve,
Thanks a lot for the info. The black drop ceiling edge sounds like a great solution. I will see if I can find it at my local Home Depot.
thanks again!
DrewKaree
  • HAH! Nice one!
    • A lifelong project
« Reply #18 on: January 12, 2005, 11:56:07 am »
Steve
I'm not following that logic at all.  If you have the "L" for the top, why wouldn't you use the "L" for the bottom as well?  Or use the "J" for the top and bottom?  Why use two separate materials and add a requirement that you fine tune it instead of using identical pieces?
rnoonan
  • Last login:September 22, 2005, 03:39:56 pm
« Reply #19 on: January 12, 2005, 04:20:29 pm »
For my marquee I used photo banner paper between two sheets of plexiglass.  To mount it I had used a piece of wood on each side with a channel cut about 3/4 of the way down (like you'd do for T-molding).  Then I cut a square notch into the bottom 1/4 of the plexiglass.  So 3/4 of the marquee sits in the channel and it's supported by the notch.  You can slide it in and out very easily.
For the top and bottom black framing... no laughing now... I used black electrical tape.  Sounds pretty dumb, but it looks better than you'd think.
stevejt
  • stevejt.com
    • My site
« Reply #20 on: January 14, 2005, 06:18:35 pm »
Trying to make it simple,(perhaps trying too hard).  The J channel would be screwed in from the front, with the screws being hidden by the marquee.  The L on top would have screws visible only from the top of the machine.  I was also thinking about the angle under the marquee not being 90 degrees which might require an attempt at bending the L.  If the top wasnt 90 degrees, again it would only be visible from the top.
Do either of those make any sense to anyone but me?
Steve
DrewKaree
  • HAH! Nice one!
« Reply #21 on: January 14, 2005, 10:19:32 pm »
I'm still not gettin' ya, but that's ok.....I've got ideas like that too.  "Dude, why doesn't anyone else GET this?!?!?  Are they all psychotic?!?"
I believe you prolly explained yourself pretty well, but I'm thinking it's one of those things I'll need to see in action to finally pick up what yer puttin' down.
versapak
  • Somewhere between a block of wood and a monkey
  • Last login:October 08, 2024, 04:40:31 am
  • I am t3h GAY!!!
« Reply #22 on: January 15, 2005, 01:36:22 am »
The reason you couldn't have 2 J shaped holders, is because the screws that hold the J shape on would be behind the marquee, so you would not be able to get the marquee into them once they were both mounted.
If you have a J shape on the bottom, then you get the cleaner look of the J, as you would not have any of the metal visible on what is the speaker mount on most cabs, but then you can have the L on top, so you can actually access the screws to remove it.
stevejt
  • stevejt.com
    • My site
« Reply #23 on: January 15, 2005, 09:23:27 am »
I'm so happy somebody understands me!!!!!!!!!
Steve
KrawDaddy
  • Last login:February 19, 2007, 06:37:04 pm
  • I am a LOSER
« Reply #24 on: January 15, 2005, 11:53:21 am »
All I ask is that my routers obey me as though they would the word of GOD!
fogman
  • Last login:June 09, 2007, 03:56:32 pm
  • A Tale of Nocturnal Terror!!!
« Reply #25 on: January 20, 2005, 01:28:16 pm »
I used lattice topping to hold my marquee.  You can buy this for about $5 for 8' from Home Depot.  Its a long, about 1" deep stick with about 1/4 x 3/4" groove down the center.  Its normally used to top the plastic lattice you use under your deck or something, so its in the decking department.  I just drilled small holes through the bottom portion, use long, thin nails to attach it to the frame.  The sandwich of lucite, marquee, plexiglas silde right down into it.
Drop me a line if you want to know any details.
megashock5
« Reply #26 on: January 20, 2005, 02:50:01 pm »
For anyone who has an Anderson's nearby - just this morning I found something that should be about perfect.
It was in building materials in the same aisle as ceiling tiles (could be for drop ceilings or just a corner protector), but it was a light metal like aluminum and in an L shape. $2.29 for 8 feet or so, and it was already black.
Planning on going back with my wife's station wagon to get it.
versapak
  • I am t3h GAY!!!
« Reply #27 on: January 20, 2005, 02:56:59 pm »
I went to every Home Depot and Lowes in the are, and all of them only had white drop ceiling frames. :(
Anderson's seems to be an only in Ohio sort of thing.
RayB
  • There's my post
    • RayB.com
« Reply #28 on: January 20, 2005, 04:04:14 pm »
... black satin finish or semi-gloss paint will fix that.
NO MORE!!
versapak
  • I am t3h GAY!!!
« Reply #29 on: January 20, 2005, 04:38:46 pm »
Yeah...
Haven't even been able to get my cab painted yet, much less worry about wanting to paint little pieces that I know other people are getting black to start with. :)
heheh
mozzer
  • Last login:March 02, 2019, 10:38:25 pm
  • How Soon Is Now?
« Reply #30 on: January 22, 2005, 04:57:25 pm »
Mine is just held in by t-molding....
thrdbace
  • Last login:January 30, 2005, 07:21:02 pm
« Reply #31 on: January 22, 2005, 07:00:21 pm »
I used a "corner protector" from home depot....just ask for it in the windows/wallpaper area - its a strip of clear plastic that is adhesive, that sticks to the corners of walls to protect them.
i stuck one on the top, and one on the bottom of my marquee....the strip was $2
