Author Topic: Button Configuration Dilema  (Read 2716 times)
mtd
  • Last login:December 13, 2003, 04:15:46 pm
    • MurderousTreacherousDogs
« on: October 03, 2002, 04:34:50 pm »
I am looking for a list of all the VERTICAL games that require a 4-way joystick, and no buttons; a 4-way joystick, and 1 button; a 4-way joystick and 2 buttons; a trackball and no buttons; a trackball and one button; etc.
Is there a utility that does this already?  It would seriously help my decision making in constructing the control panels for my cocktail project.  My current thoughts are to construct 2 panels that have a 4-way joystick and 2 buttons and then 1 trackball panel, and 1 spinner panel.  I am just curious what Vertical games I'd lose if I went to 1 button instead of two.
Carsten Carlos
  • Last login:June 28, 2014, 05:06:25 am
  • Projects: Centipede extended, Asteroids
    • Carlos' Centipede-extended
Re:Button Configuration Dilema
« Reply #1 on: October 03, 2002, 05:28:53 pm »
Look there under downloads!
http://hem.passagen.se/robert.palmqvist/index.html
Helped me, too. Unfortunately not all given values are right, but it sure does help a lot.
mtd
« Reply #2 on: October 04, 2002, 09:34:26 am »
Thanks for the link.  This is the closest to anything that I have found.  I just can't believe that what we really need isn't out there already.  Also, you are correct it is not 100% accurate nor complete.
Tiger-Heli
    • Tiger-Heli
« Reply #3 on: October 04, 2002, 11:29:29 am »
It should be complete, it builds directly from the MAME code itself, accurate is another story. >:(
  • Last login:Today at 12:04:24 am
« Reply #4 on: October 04, 2002, 11:46:32 am »
you can make a gamelist using lazarus with those filters, which shoudl aid you... give me a while and I'll post the needed search strings if you are interested
bcard74
  • Last login:August 24, 2007, 11:46:24 pm
« Reply #5 on: October 04, 2002, 12:18:19 pm »
I can't get this stupid thing to run to save my life.  Yes, I RTFM, don't worry.  Using XP .. Any hints?  Thanks.
Carsten Carlos
« Reply #6 on: October 04, 2002, 02:04:06 pm »
Well, as far as I remember I have choosen File/Import/Mame executable and it worked, but I'm not that sure as it was quit some time ago. Takes some time to parsing through, but then you should get a complete list of all games.
At least it works under WinXP here!  ;)
Chris
    • Chris's MAME Cabinet
« Reply #7 on: October 04, 2002, 02:07:16 pm »
It's definately not complete... Asteroids and Track & Field are missing, to list the two that I checked for specifically....
--Chris
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #8 on: October 04, 2002, 02:07:49 pm »
you realize that info comes from mame, and mame isn;t 100% accurate because the devs put hacks in.  Example, dotron, says trackball.  A good hack so one can use the trackball like an updown spinner BUT it gets listed in anything you output in mame so it is misleading.
I can do what you want, just because I dumped -listinfo into a database:)  hehe.
