Author Topic: Mount the benson  (Read 1628 times)
Beeeph
  • Last login:October 18, 2006, 12:31:44 pm
Mount the benson
« on: December 10, 2004, 12:28:22 am »
I've done a little bit of homework and I'm just not finding what I need.
« Last Edit: December 10, 2004, 12:49:28 am by Beeeph »
SirPeale
  • Green Mountain Man
Re: Mount the Betson Trackball
« Reply #1 on: December 10, 2004, 09:57:48 am »
Your measurement that measures 5.75".  The one closest to the wiring harness is 'up.'
Plug it in to your computer to see.
fredster
  • It's all good!
Re: Mount the benson
« Reply #2 on: December 10, 2004, 10:15:16 am »
I think you would also be better off to use a mounting plate. It makes it so MUCH simpler.
dabone
  • Last login:July 15, 2025, 08:32:17 pm
  • Time to work...
« Reply #3 on: December 10, 2004, 03:05:26 pm »
Doesn't  that pic have the ball at a 45 degree angle?
Look at the arrows...
Later,
dabone
NIVO
« Reply #4 on: December 10, 2004, 06:00:27 pm »
did you mean to say "BETSON" by chance?  not questioning your typing skills by no means , but it could throw some folks off the trail.
clanggedin
  • Last login:July 02, 2012, 11:08:55 pm
  • O'DOYLE RULES!!!
« Reply #5 on: December 10, 2004, 10:10:43 pm »
That picture has the ball at an angle. I installed mine in 5/8 particle board using the mounting plate.
The plug for the trackball is situated at the BOTTOM right. Your trackball will be correctly mounted if you position it this way.
In your picture, the arrow pointing to 7 o'clock is the TOP arrow or the one you want pointing to your monitor.
SirPeale
« Reply #6 on: December 10, 2004, 10:47:22 pm »
I had 40 trackballs, and tested them all. Every one the wiring was on the *top.*
Beeeph
« Reply #7 on: December 11, 2004, 02:32:08 pm »
Thanks all!
This guy had a pretty easy way of doing it without the mounting plate:
http://www.willcoxonline.com/mame/controlpanel/controlpanel.htm
