Author Topic: Physically installing PC into cabinet  (Read 2579 times)
LeedsFan
« on: November 18, 2004, 06:26:54 am »
I've had a good search but can't find an answer to this specific question.....
My cab PC case is too big to fit inside. Therefore I'm planning on stripping the case of MB, poswer supply, CD drive and HD and placing them in seperately.  I've measured everything up and all will fit no problems.
However, a friend of mine said there could be trouble earthing the MB and other components. I was going to remove the MB and screw it to a wood panel in the cab using PCB feet (just like  the ones supplied by Ultimarc for their J-Pacs etc.)   The CD drive I was going to attach by using velcro.  Same thing with the HD but keeping the HD in it's case frame as it generates a lot of heat and could goo up the adhesive on the velcro if attached directly. I think I can make a hole in the back  of the cabinet for the power supply so i can plug the power lead straight intto the back just like the cab power lead does
Any thoughts on this?
danny_galaga
  • Last login:January 26, 2026, 05:45:42 am
    • dans cocktail lounge
Re:Physically installing PC into cabinet
« Reply #1 on: November 18, 2004, 06:56:20 am »
i don't know that you need to earth the motherboard. i didn't on my cab...
« Reply #2 on: November 18, 2004, 07:03:07 am »
I did exactly the same...
But for my hard drive I bolted it into a drive bay housing thing (the kind you get to fit 3.5" drives into large drive bays).  Then I just screwed it to the wood.  I don't have any other drives.
I attached the whole lot to a removable board, for maintenance reasons :)
wj2k3
  • Last login:August 22, 2006, 12:23:48 am
  • Not!
« Reply #3 on: November 18, 2004, 11:29:32 am »
I would worry about the velcro letting go after awhile.
I drilled two-holes through the board on each side of where I wanted to mount my drive and used some zip-strips to snug it down.
whammoed
  • Last login:Today at 02:34:51 pm
  • Crack don't smoke itself
    • NiceMite
« Reply #4 on: November 18, 2004, 11:41:37 am »
aluminum angle and flat bar makes good brackets and such:
holdennut
  • Last login:January 16, 2015, 04:53:06 am
  • Aussie lowboy cab finished!
    • Australian Cocktail Pac-Man Project
« Reply #5 on: November 18, 2004, 08:39:26 pm »
There is no need to earth your motherboard. Just mount it to the MDF with those PCB feet and it'll work fine.
ften
  • Last login:March 06, 2022, 10:20:43 pm
  • Beep Beep
    • Fathertom.net
« Reply #6 on: November 18, 2004, 11:21:18 pm »
I've used velcro to hold a hard drive directly on the side of a case before, really didn't have any issues with it falling off or gooing up. Although I was also using a 2.5 inch drive and some industrial strength velcro.
-FTen
Setabs
  • Last login:March 07, 2015, 03:03:23 pm
  • 100% MAME compatible.
    • Another Useless Webpage
« Reply #7 on: November 19, 2004, 12:42:23 am »
I belive the motherboard is grounded from the power supply.  Which in turn is grounded to the outlet in you house. Which is grounded to the ground somewhere around the circuit breaker( or i could be horribly wrong.)  NEwayz think about it does a metal part of your case actually touch the ground?
danny_galaga
« Reply #8 on: November 19, 2004, 05:12:11 am »
yes, for the very reason you just explained!! through the earth wire it does actually connect to the ground.
but im still not sure that the motherboard itself is grounded (but there i could be wrong) as it is only low voltage.
LeedsFan
« Reply #9 on: November 19, 2004, 09:30:24 am »
It won't be a problem for me. The MB will be installed vertically on the back of a panel inside the cab. But the drives will be sat on the top of another panel just inches away over the 90 degree corner. The velcro will just hold them in position flat to the board. They won't be hanging from a side panel or anything like that.
mahuti
« Reply #10 on: November 19, 2004, 09:31:03 am »
Putting a motherboard on PCB feet and attaching it to wood is fine.
end of story.
Stingray
« Reply #11 on: November 19, 2004, 01:56:57 pm »
Mine had a ground strap between the motherboard & the power supply housing, so I added one when installed said items into my cab. Don't know that it was absolutely necessary, but I also don't think it could hurt.
-S
