November 21, 2009, 05:59:48 AM *
Welcome, Guest. Please login or register.
Login with username, password and session length
News:
   Home   Help Arcade Search Login Register
Main Woodworking Reviews Software Monitor/Video
Audio/Jukebox/MP3 Project Announcements Artwork Consoles Buy/Sell/Trade
Arcade Miscellaneous Everything Else Politics n Religion Forum Discussion Wiki Discussion
DOS/WinCab PowerMAME SK Jukebox UncleTs Jukebox Project Arcade
Linux Restorations Pinball MaLa Frontend
Recent posts | Arcade | Rules | Old Boards | Old Archives | Chatroom | Wiki | File Repository | RSS
Pages: [1]   Go Down
  Send this topic  |  Print
Author Topic: Dave's Mame Arcade - made in Leeds, UK... UPDATED 23/11  (Read 4164 times)
LeedsFan
Trade Count: (0)
Full Member
Offline Offline
View Profile
« on: October 22, 2004, 04:48:43 AM »
Righty 'o.... here is my very first project! It's a generic Electrocoin Xenon cabinet which was built in 1989 (according to all the test stickers inside).
« Last Edit: November 23, 2004, 10:32:43 AM by LeedsFan » Logged
Trade Count: (+1)
Full Member
Offline Offline
View Profile WWW
« Reply #1 on: October 22, 2004, 06:55:23 AM »
Not bad - keep the pics coming!
Logged
RayB
I'm not wearing pants! HA!
Trade Count: (+3)
Full Member
Offline Offline
avatar 2.0
View Profile WWW
« Reply #2 on: October 22, 2004, 07:41:21 PM »
Cool. Looks like you have room for 2 cup holders.
Logged
NO MORE!!
LeedsFan
Trade Count: (0)
Full Member
Offline Offline
View Profile
« Reply #3 on: October 23, 2004, 03:45:30 AM »
Do you mean in the gaps at the side of the speaker housings? Hey..... That's not a bad idea!  I'll certainly consider it. On this model cabinet those gaps are actually optional places for coin inputs. Once you lift out the glass you can get access to two small plates at the back, which can then be lifted out and replaced with a coin mech on each side. (You can see them if you look closely). My cab has the coin mechs in the door as you can see, which was my preference anyway.         Thanks for the tip anyway.... I'll check how much space there is in those gaps for cup holders today.
Logged
LeedsFan
Trade Count: (0)
Full Member
Offline Offline
View Profile
« Reply #4 on: October 23, 2004, 11:47:53 AM »
Here is an update on how things have progressed.  I made the control panel from 6mm thick MDF. Now I know that this is not very thick for the purpose of control panels, but I intended to mount this on top of the metal panel already there. Or should I say a framework of the original panel! I didn't want any thicker than 6mm as the surface of the panel would then be sitting above the T-molding at the sides. Here's a picture of how I did this.....
I basically made up a template panel by measuring where everything was going to be.... the spaces taken by the joysticks, buttons, trackball etc. I then placed this on top of the metal panel and jigsawed out holes for my finished panel to drop into. It doesn't look pretty, but it does the job well. Once finished I could then place the template on top of the final wooden panel to match up all the holes for the mounting screws.
Here's a picture of the underside of my final panel....
I made up some spacers for my T-Stick+ joysticks, as I like them to be set low down. I prefer my joysticks to be short and stubby.  Also, you can just make out the grooves that I cut into the panel for the trackball wheels to rotate in. I had to do this to get the trackball itself to lift high enough through the panel. I didn't want to use the mounting panel if I could help it as I wanted a totally flush surface for the artwork. Here's a pic of my Ultimarc trackball unit with the top half removed.....
I was a bit worried that all sorts of springs and fittings etc. would fly everywhere when I did this.  Shocked  But it was simple.... just unscrew the three retaining screws, lift off the top cover and pull out the ball. But you still need to watch the rollers and optical wheels as they will now easily fall out if the unit is turned upside down. To fit the trackball up I now needed a suitable spacer to get exactly the right height. With a bit of mix and matching I found some oversize nuts that were a perfect fit....
In this picture you can see how close the Oscar Model 3 spinner sits to the housing of the Ultimarc trackball. I think there's about 3 to 4mm in it max. But it was measured precisely, and I can't stress the importance of double checking all measurements before cutting and drilling any panels. Also, I kept the Player 1 and 2 start buttons in there original place. They actually help to clamp the wood and metal panels together without need for extra screws etc.
A picture of how it looks from the top....  all screws and bolt heads are recessed and will be filled in later.
Now for the painting. I ripped out all the old black T-Molding and sanded the edges down where necessary. The cabinet is in very good shape for 15 years old, but there were still one or two areas that needed a bit more attention which is to be expected.  I decided to spray paint the cabinet with aerosols..... which turned out to be a mistake! Whether it was the paint itself, or my spraying technique I'm not sure. But the results were crap!  Angry
Black is the worst colour to get right, as any imperfections will show more than any other colour. There were shady bits and uneven parts all over the place. I wasn't happy and ended up buying a tin of black satin paint from B&Q for less than a tenner and used a roller kit to apply it. The results were much, much better! Not perfect by any means, but good enough for me.....  Smiley
I also painted the control panel front and underside using a roller, but I did use aerosols for the speaker housing and coin doors which did come out nice....
The original speakers were removed and I used a pair of Cambridge Soundworks 2.1 speakers that I had left lying around from when I'd upgraded my home system to 5.1 surround. They fit nicely in the gaps of the old speakers as though they were specially made for it....
I then isolated the switching power supply from the cabinet. I was a bit worried about this as I'd no previous experience at all of arcade cabinet wiring. But after some very helpful advice from this very board (Thanks guys!  Cheesy) it seemed I was worrying about nothing. A simple block connecter was unplugged and the job was done! I decided to leave the switchablle power unit installed though, as I can still play Jamma boards if I want to at a later date.....
EDIT: 28/10/04 I slightly altered the way I isolated the switching power supply today. By simply unplugging the block connector I was also disconnecting an earth wire as well as the live wires. Now.... this earth wire may have only been for the AC power supply, but I couldn't be 100% sure as it was difficlut to trace the wire back in the loom. So I played it safe and reconnected the block connector, and instead disconnected the live brown and blue wires direct at the switchable power supply (and taped them up properly!). This leaves the earth wire intact just in case something else is earthed through it. I feel this is VERY important so I put this EDIT note in.  Wink
And here's where I'm up to now with my lovely 2.25" transluscent ball I got from The Real Bob Roberts. This will be illuminated when the cab is finished.....
More updates later!
« Last Edit: October 28, 2004, 08:13:01 AM by LeedsFan » Logged
Cave
Trade Count: (0)
Full Member
Offline Offline
View Profile
« Reply #5 on: October 24, 2004, 04:37:28 PM »
Damn those hidden messages  Smiley
Logged
Gunstar Hero
Trade Count: (0)
Full Member
Offline Offline
Back in action!
View Profile
« Reply #6 on: October 25, 2004, 03:31:11 AM »
LOL. That hidden message pic owns.
And man, yet another cool looking cab! You guys got some different looking machines over there for sure.
Logged
"The one who dies with the most games wins."
Lord Hiryu
Trade Count: (0)
Full Member
Offline Offline
View Profile WWW
« Reply #7 on: October 25, 2004, 10:36:20 AM »
Hi Dave.
Nice work.
But I think that you will not be able to move the joysticks well,
Logged
Que tiempos aquellos, en el que las vidas se llamaban tanques !
LeedsFan
Trade Count: (0)
Full Member
Offline Offline
View Profile
« Reply #8 on: October 25, 2004, 11:33:16 AM »
I did think about the joystick movement. They do work OK in all directions. (Well.... I get an audible click in all directions from the microswitches).   I'm using T-Stick Plus joysticks from Ultimarc. Are you using the same?  They look similar.
I can still make the shaft hole bigger before going "Gold" so to speak.
Oh.... and my marquee is being junked. That's what came with the machine and I don't care for it. I'm getting all new artwork from MameMarquees.com.
That's a very nice machin.e you have there. Just another example of woodworking that is far from my technical reach.  Sad    Like the artwork..... reminds me of a Beatles record sleeve.    Smiley
Logged
LeedsFan
Trade Count: (0)
Full Member
Offline Offline
View Profile
« Reply #9 on: November 23, 2004, 10:45:45 AM »
Exactly one calendar month since the last update..... and I'm very nearly there!
« Last Edit: November 23, 2004, 10:57:22 AM by LeedsFan » Logged
brained
Trade Count: (+1)
Full Member
Offline Offline
Raised by Atari
View Profile WWW
« Reply #10 on: November 23, 2004, 10:58:06 AM »
It came out really nice, GOOD JOB!!  police
BTW, what's that I see under the control panel???
Logged
LeedsFan
Trade Count: (0)
Full Member
Offline Offline
View Profile
« Reply #11 on: November 23, 2004, 11:06:47 AM »
Thanks Brained.... but I don't know what you mean "under" the control panel?
Logged
Gunstar Hero
Trade Count: (0)
Full Member
Offline Offline
Back in action!
View Profile
« Reply #12 on: November 23, 2004, 12:24:49 PM »
Wow, looks awesome.
The blue molding really brings out the angles on that cab!
Awww... Where'd the "NEW GAME" marquee go??  Tongue
Logged
anthonylitz
Trade Count: (0)
Full Member
Offline Offline
Can you milk a llama?
View Profile
« Reply #13 on: November 24, 2004, 12:00:25 PM »
Sure looks pretty.  Looks very clean!
Anthony
Logged
Knievel
Trade Count: (+3)
Full Member
Offline Offline
Who's up for a game of Stunt Cycle??
View Profile WWW
« Reply #14 on: January 25, 2005, 09:03:19 PM »
Nice cab Dave, I really like the shape...and the built-in cupholders.
That speaker panel is begging to have something in the middle of it, maybe an LCD display for instructions?
Some lighted buttons would look slick too Wink
Logged
Pages: [1]   Go Up
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.10 | SMF © 2006-2009, Simple Machines LLC | Sitemap Valid XHTML 1.0! Valid CSS!
Page created in 0.186 seconds with 29 queries.
