Author Topic: Help me please power my arcade monitor: Im a NOOB :D  (Read 3770 times)
stellarola
  • Last login:June 24, 2020, 11:46:59 pm
  • .::For the love of the game::.
« on: September 02, 2004, 09:16:53 pm »
Hey people. First off, let me state, I'm a n00b to this scene. Im pretty good at wiring, but I dont really know what to wire. The arcade monitor I have is a WG 25k7191. I found the molex connection for the r,g,b,ground and sync. Im going to use the Ultimarc Videoamp for that part. My question is, HOW DO I POWER IT ON?!?!?
I have these items below:
http://www.geocities.com/poisonsix/DSCF0047.JPG
http://www.geocities.com/poisonsix/DSCF0048.JPG
http://www.geocities.com/poisonsix/DSCF0049.JPG
http://www.geocities.com/poisonsix/DSCF0050.JPG
http://www.geocities.com/poisonsix/DSCF0051.JPG
Using those items, how will I power on my monitor, please someone help a brother. Thankyou and good day.
-Ben
stellarola
Re:Help me please power my arcade monitor: Im a NOOB :D
« Reply #1 on: September 02, 2004, 11:51:05 pm »
Can someone point me in the right direction???
Thenasty
  • Trade Count: (+17)
  • Last login:November 24, 2025, 04:30:42 pm
« Reply #2 on: September 03, 2004, 12:01:12 am »
try here
http://rds.yahoo.com/S=2766679/K=WG+25k7191/v=2/SID=e/TID=F375_118/l=WS1/R=1/H=0/IPC=us/SHE=0/*-http://www.jstookey.com/arcade/WG_25k7191
I don't know if the monitor needs an Isolation transformer or if its 120 or 220 volts. But if does not need an isolation transformer (like the newer ones), you just splice the cable from the monitor and put a regular plus so you can plug it in the outlet.
Wait for Ken Layton the expert with monitors, maybe hes got something for you.
Free VGA Breakout Cable
jerryjanis
  • Last login:February 02, 2023, 01:56:44 am
  • Skate or Die!!!
    • Jake's Joystick
« Reply #3 on: September 03, 2004, 01:36:57 am »
My arcade cabinet came with a WG 7191 and an isolation transformer, so I used it.  I not certain if it's necessary or not.  My cabinet also had a flaky power supply, so I don't use the power supply.  I simply run the 2 power wires from the monitor into the isolation transformer.  Then I attached 2 wires to the isolation transformer's outputs which run out to a wall plug.
I, too, purchased a video amplifier, but I never found a use for it.  The monitor looks great without it.
jerryjanis
  • Skate or Die!!!
    • Jake's Joystick
« Reply #4 on: September 03, 2004, 09:33:11 am »
Here are some pictures of how my isolation transformer is connected.  I added them to my web page, also:
PacManFan
  • Last login:December 06, 2005, 12:18:56 pm
    • Kymaera Home Page
« Reply #5 on: September 03, 2004, 09:48:33 am »
Where is your GROUND young man?  ;)
-PMF
All Hail Smezznar! The Giant purple centipede of Omnicron 5. Regail him with your odiferous offerings of onion powder!
jerryjanis
  • Skate or Die!!!
    • Jake's Joystick
« Reply #6 on: September 03, 2004, 10:28:38 am »
-PMF
Good question...  Is there such a thing?
pointdablame
« Reply #7 on: September 03, 2004, 11:19:56 am »
The monitor stellarolla has is mine, we traded for it.  Unfortunately, I'm doing a pretty crappy job explaining how to set it up.  His monitor has and needs an isolation transformer, which he has.  I sent him the monitor, iso, and arcade power supply, as well as the control pod the monitor has to tweak the picture.  I (think) I've helped him figure out how to connect the monitor to display video, but he needs a break down of how to power it up.
Stellarolla, I'm gonna try to get you some pics of my monitor later, hopefully that will help you see what I (badly) tried to explain.
So help him out guys, give him a step by step of powering up the monitor.  I know there was a really nice site I read that helped me set this up the first time, but I haven't had to touch a monitor since, so that knowledge is a bit weak right now heh  ;D
first off your and idiot
stellarola
« Reply #8 on: September 03, 2004, 02:27:19 pm »
Is this where i want to connect the wires to?
Blue arrow = white wire to whire wire on chassis??
Yellow arrow = black wire to black wire on chassis??
stellarola
« Reply #9 on: September 03, 2004, 02:28:15 pm »
The other picture, now showing some of the bottom.  ;)
stellarola
« Reply #10 on: September 03, 2004, 11:19:57 pm »
Hey guys. I ended up stripping those wires I pictured above to see if it would power up. It did! Yay...... Now all I need now is an ArcadeVGA card and I should be set.
General Zod
  • Last login:June 23, 2005, 03:58:28 pm
  • Banned
« Reply #11 on: September 04, 2004, 09:33:05 am »
Looks like you may have already figured out how to power your monitor, but I thought I'd share how I did it , just to give you a few more ideas to play with ...
Basically the same design as mentioned earlier, but I've also added a fuse, a switch ... and made sure everything was grounded. I also found a small piece of plywood for mounting the pieces.
Just an idea ...  ;)
Michael
