Author Topic: The hacking of a 49 way.... the cable  (Read 1248 times)
Lilwolf
« on: June 17, 2004, 02:44:37 pm »
I FINALLY found a good cable to work with a sinister 49 way controller!
I got Daves 49way controller (works GREAT!) but I couldn't find any way to neatly hack it.  I couldn't find any cable ends that fit.
Well.. I finally took it in the basement and started looking at all the outdated crap... and I found it!
Find an old pre-atx power supply and cut off the power -> the motherboard.  Both sides (there where two) fit PERFECT!
Right number of pins!
Perfect size!
and the wire works great with Daves board.
Anyway, I now have a VERY nice and clean looking cable job... without crimping a thing!
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
Re:The hacking of a 49 way.... the cable
« Reply #1 on: June 17, 2004, 02:51:19 pm »
Any pics?  Or are you just teasing us...
G@M3FR3@K
  • Last login:December 31, 2015, 12:20:28 am
« Reply #2 on: June 18, 2004, 12:11:08 am »
Those are called an "AT" Power-Supply.  They have a pair of 6-pin conectors.
Lilwolf
« Reply #3 on: June 18, 2004, 08:26:28 am »
Sorry, I don't think I can take pictures.
It was BEAUTIFUL hack..
but I ended up using electrical tape and screwing it down on the underside of the control panel... because I just wanted to mount it quick...   And I didn't have any optioins at the time :)
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #4 on: June 20, 2004, 04:12:19 am »
Thanks for the heads up! :)  I keep seeing my two 49-way (one sinistar, one happs) sitting on the work table just begging to be used. :'(  I know I have an old AT power box somewhere around here...
Robin
Knowledge is Power
Lilwolf
« Reply #5 on: June 21, 2004, 09:44:09 am »
I played with mine a bit last night.
I have to add a switch on top of my control panel to switch between straight scale and flat scale.  Sinister isn't as good with flat scale (it doesn't catch all 3 speed directions... only 2 in flat scale).  (the digitial -> analog back to digital doesn't work right... but with the scaled it does)
btw, I was a little annoyed that the sinister round top wasn't 1 1/2"... I drilled the whole and found it was JUST over 1 1/2"... so I had to route it back a little... it's not to clean cut right now...
but I have to make a new control panel anyway... So I'm just testing it now..
