Author Topic: Other Home Build Projects  (Read 6685 times)
Fusion Disaster
  • Last login:November 20, 2006, 01:00:26 pm
« on: May 25, 2004, 06:28:43 pm »
I'm suck a geek. I love flashy home built inventions that made visitors to your home stop in amazement of you crafty abilities. I've built the Arcade Machine (thanks to you all on here), now I'm looking for more projects to start on.
I saw a site the other day that detailed the construction of a guys home built monorail. Was large enough to carry two adults in it on a 4" wide rail suspended 12 feet above the ground, and wrapped all the way around the guys house. (I'll try to find the link and post it here).
Another idea for homemade projects was liquer dispensing machine some college kids put together. Check it out: http://www.barmonkey.net/ This is way sweet and I'm totally going to build one of these for myself to integrate into my bar.
Do you know of any other projects?
NoBonus
  • Last login:January 07, 2007, 06:48:58 pm
  • "Now that's a fine example of California's Gold"
Re:Other Home Build Projects
« Reply #1 on: May 25, 2004, 07:21:08 pm »
oN the Bob & Tom radio show they described a butt kicking machine with a boot attached to a board attached to a waterwheel with a water pump to make the thing go.  If you have money to burn you could always put up massive solar panels and sell power back to the grid...  that would be impressive.
Fusion Disaster
« Reply #2 on: May 25, 2004, 07:27:25 pm »
Here is the link to the homemade mono rail. That's some dedication: http://www.monorails.org/tMspages/Niles.html
NoBonus
« Reply #3 on: May 25, 2004, 07:34:25 pm »
You could always build a go-kart.
Fusion Disaster
« Reply #4 on: May 25, 2004, 07:39:50 pm »
Yeah that's on my list to build. In 2 years when my son will be 5, I'll build him one to cruise the block with.
NoBonus
« Reply #5 on: May 25, 2004, 07:42:57 pm »
The monorail is crazy.  Sure seems like an expensive venture for something so, well, small scale.  You should at least be able to take a "big" person in the monorail and two people would be better.
NoBonus
« Reply #6 on: May 25, 2004, 07:49:42 pm »
How about building a playground for your little one? or a fort? or clubhouse of somesort?  You could make a mound of dirt with cement and wood tunnels in it like at many bigger playgrounds.
Or you could make a robot (if you have the cash).
Or you could make a home gym or a saunna <sp>.
What would be cool to do is to make a mini, non-powered version of "The Revolution".  THis is a ride at some theme parks where there is a big boat that swings back and forth; of course, you might not want yours to swing too far.
NoBonus
« Reply #7 on: May 25, 2004, 07:51:06 pm »
Or how about a bike-car... or a bike-car that uses mechanical giant crab legs instead of wheels.  That would be totally sweet.  Then all you would need to do is make it look like a giant crab and you're famous!
Fusion Disaster
« Reply #8 on: May 25, 2004, 07:55:48 pm »
Thanks for the suggestions. However I'm not necessarily looking for a new project. I've already going to be making the automatic drink mixing machine, and I need to make a home kegorator. On top of that I'm contemplating the idea of making a home made pinball machine.
For now I'm looking for examples of cool geeky projects people have devoted their time to.
Here's another example.
This guy devoted his time to building a home made segway, and if that wasn't enough he decided the segway was to redundant (with it's second wheel), so he made a self balancing unicycle. Here's the link to his site: http://www.tlb.org/scooter.html
TalkingOctopus
    • My Arcade
« Reply #9 on: May 25, 2004, 07:59:39 pm »
http://www.byopvr.com/ - Build your own PVR.
Generic Eric
« Reply #10 on: May 25, 2004, 08:45:22 pm »
Build a panic room.
Build one of those smoothie margarita machines <--- Perfect addition to a kegarator.
crashwg
« Reply #11 on: May 26, 2004, 04:47:20 am »
put a pc in your car for mp3/video/gps/whatever...
http://www.mp3car.com
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
NoBonus
« Reply #12 on: May 26, 2004, 11:29:29 am »
I actually have a home-built Keg-o-rator. It is a minifridge and it holds a five gallon keg.  Once you find the home brew shop in your town or online and get all the needed parts, this is a quick and very easy project.  Here are a few tips to remember once you get into this project:
-Buy extra hosing. Hoses rot, get nasty, and generally go bad in about a year or so.  Hose is cheap, so don't wash it, just replace it.  Buy extra when you make your initial purcahse, it will save you the hassle of trying to match it and buy more later.
-Insulate your dispenser tower. You know, the chrome thing that sticks up and has the tap attached to it.  I used some flexible plasticy foam stuff and it works great.  Remember, there is a hole on the top of your frige leading into the tower.  Insulating the tower will do two things. 1. Save energy/cash and 2. keep the beer in the hose that is inside the tower cool (other wise that first sip could be nasty).
-Buy and check a thermometer for your fridge.  Cold beer is great.  I keep mine at about 35 degrees, but 32 degrees or lower could cause some major problems.
-The CO2 unit on your keg-o-rator can "force carbonate" your beer.  You will need to learn to do this AND you will need to learn how to set your CO2 level properly.  You can ask me about this, the pro at your homebrew shop, or read about it.  But you want to avoid 2 things 1) Overcarbonating your beer (Most people are not fond of 4-5 inches of head on their beer) and 2) blowing gaskets. You only want to use the minimum amount of CO2 pressure on your keg. ANd if the keg is already carbonated when you get it (and generally they are to some extent), you will not want to turn on the CO2 at all until the pressure in the keg reduces.  You can just open the tap and beer will come out on it's own.
-keep a good beer in your keg-o-rator.  I realize Natural Ice is only $20 a 5 gallon keg, but no one really wants to drink that swill.  Especially over a long period of time. Spend the extra dough and get your favorite.
-keeping a coin bank atop the keg-o-rator to collect a beer fund is the best possible thing you could do, especially if a lot of people (non-family) are drinking from it.
If you need anymore pointers on keg-o-rators, let me know.  They are fun, but must be respected.
NoBonus
Generic Eric
« Reply #13 on: May 26, 2004, 12:06:34 pm »
NoBonus
There are a couple of guys that I know that went halfs (they are neighbors) on a kegorator.  It was good for awhile, but they ended up getting tired of paying for the keg all the time.  They did have a jar on top, but the *regulars* didn't pitch in.  cheap ---daisies--- anyhow.
I don't think they get a new keg all that often anymore.
Still a cool idea - just gotta be careful on the people you associate with or you will be taken advantage of.
menace
« Reply #14 on: May 26, 2004, 12:09:27 pm »
I built a 10" newtonian telescope on a dobsonian mount based on directions found on the internet--works well and was fun to build.
http://members.cox.net/mrspickett/index1.html
NoBonus
« Reply #15 on: May 26, 2004, 12:11:14 pm »
I don't think it matters who you associate with, people see a free ice cold glass of beer and lose all ethics and sense of responsibility.  Only those who are guests or generous will contribute.  Those who drink the most beer generally will never contribute a dime.
NoBonus
Dartful Dodger
  • Newer isn't always better.
« Reply #16 on: May 26, 2004, 02:08:54 pm »
Build a panic room.
Great idea!
a panic room/fortress of solitude, that's what every home needs. A perfect place to hide your cabinet from your nieces and nephews.
DarkKobold
  • Last login:June 18, 2013, 11:31:23 pm
« Reply #17 on: May 26, 2004, 03:58:57 pm »
C'mon people, no one mentions the best Home project - a Home Theater -
www.hometheaterforum.com
www.avsforum.com
Examples to drool at
http://gallery.avsforum.com/showphoto.php?photo=7784&password=&sort=1&cat=501&page=1
« Last Edit: May 26, 2004, 04:26:51 pm by DarkKobold »
My games: Tapper, Asteroids, Cocktail-MAME, Tron, ROTJ, Tempest, Star Wars (not working)
My wants: Warlords Cocktail
drunkatuw
  • Last login:April 24, 2025, 02:25:30 pm
    • Drunk at UW.com
« Reply #18 on: May 26, 2004, 03:59:27 pm »
I built a kegerator during college, and after the first keg, I don't think me and my roommates had to buy another keg.  Every thursday night was "deep fry night."  Where we pulled out the fry-daddy and fried chicken nuggets, french fries, pizza rolls, etc. and of course drank lots of beer and we always managed to get enough money to buy the next keg.
We found that just putting a bucket on top of the fridge with a big sign that said "DONATIONS" we tended to get a lot more money.  Everytime they fill up their glass they see the sign and feel bad.
Now that I'm out of college, I still always keep the kegerator full of beer.  I have to agree with NoBonus, don't go super cheap.  I wouldn't go any less than a bud/miller lite.  I don't go thru kegs in two weeks like we did in school, but every 4-6 weeks I need a new one.  There's nothing like always having cold beer on tap and never having to worry about running out of cans or bottles.
Fusion Disaster
« Reply #19 on: May 26, 2004, 04:06:14 pm »
Yeah I've got a full bar in my basement, "Pirate Themed" >:) So the kegorator is a perfect fit, I'm not quite sure why I haven't built this yet, especially considering we drink LOTS of beer. I'll definately get this hooked up this summer.
Thanks for the advice
NoBonus
« Reply #20 on: May 26, 2004, 05:04:28 pm »
I did the math a few years ago and determined the keg-o-rator would pay for itself (keg beer is cheaper than individual serving beers in bottles and cans) in about 20 refills.  Oh, and if you are doing Guiness, you will need the special Guiness tap to get that good foamy head.
NoBonus
jagnogg
  • Last login:November 03, 2006, 01:43:21 pm
  • I'm not wearing any pants.
« Reply #21 on: May 26, 2004, 10:04:21 pm »
I'm am building a custom skee-ball machine. I bought an old broken down skee ball machine (with no electronic components) and I'm going to put a PC inside of it with the monitor in the score area. I'll use an I-Pac to register the point values of 10 through 100. I'm going to write a custom program that includes the "normal" skee ball scoring system but I'll also create new games with different scoring systems. It will have plenty of cool sound effects and graphics as well.
NoBonus
« Reply #22 on: May 27, 2004, 01:37:51 am »
Seems like there must be a better way to redo a skee ball machine...  a PC and I-Pac seem like overkill.
jagnogg
« Reply #23 on: May 27, 2004, 09:36:31 am »
It's a 90 mhz pentium with a 15 inch monitor that would be useless otherwise. The I-Pac will be used for registering scores as the ball goes through the hole, and for a small control panel that will allow you to choose the game and enter your initials for high scores, etc.
I'm open to other suggestions if you know of an easier way.
-J
hooded_paladin
  • Last login:November 06, 2013, 08:59:01 pm
  • Finch! hahaha
« Reply #24 on: May 27, 2004, 10:34:35 am »
That's what, 4-8 inputs?  Why not a cheap gamepad hack?
There is SO a spoon.
DarkKobold
« Reply #25 on: May 27, 2004, 10:34:38 am »
I think it is a clever way to redo skeeball. What language are you going to write it in?
NoBonus
« Reply #26 on: May 27, 2004, 11:10:03 am »
That's what I was thinking.  A gamepad hack is easy (not as easy as an encoder, but not that hard) and dirt cheap.  However, are you going to write a program to keep score and stuff?  If so, I would like to try it out when you are finished.  I could then make a skee-ball machine from scratch... or a ton of other games....
NoBOnus
jagnogg
« Reply #27 on: May 27, 2004, 11:38:43 am »
It will have 6 inputs for scores - 10, 20, 30, 40, 50 and two 100 point holes, and maybe 4 buttons for interacting with the GUI, and one for the insert coin slot. So yeah, I guess a gamepad hack would have made sense. Although I haven't used a soldering iron since 7th grade shop class...
I'm also going to try and install an anti-cheating device. If I can find a switch that is activated by an electric eye, I'm going to install it so the beam goes across the path of the ball on the ramp. It should be hidden from view because it'll be under the rubber bumber rails that run along the sides of the ramp. Anyway, if the eye beam switch doesn't trip but a score registers then you know somebody just dropped the ball into the hole. This will result in a loud blaring siren and "CHEATER!!!!" across the screen. I'm planning ahead for when my son tries to cheat. Hey Dad! I got 1000 on skee ball!!! :) Since high scores will be kept, this is important.
Does anyone know you can get a switch like this? I haven't taken the time to google for one yet...
jagnogg
« Reply #28 on: May 27, 2004, 12:03:18 pm »
I haven't decided on a language yet. I'm most proficient in TCL/TK, but I also know Java. I have performance concerns with both of those, however, since the PC is so old. I want to have sounds and graphics that are instantly responsive. If somebody rolls a 10 they shouldn't have to wait 3 seconds to hear "DOH!" Would writing it in Visual Basic be better? I've never used VB before, but I'd be a good learning experience.
As for the scoring system - I've been trying to come up with different games. I'll have the normal skee ball scoring, of course, but I want to add others. For example, if you're familiar with darts, I want to make a two player cricket type game where the first person to get 3 of each point value wins. Another easy dart scoring game would be a countdown game like 301 or 501. I'm open to suggestions here too. Maybe a target practice type game where you try to hit the hole that is suggested?
Brax
  • Last login:January 06, 2009, 09:03:48 am
  • Bring on the power tools!
« Reply #29 on: May 27, 2004, 12:13:59 pm »
How about your own cruise missile?
http://www.interestingprojects.com
At one time it looked promising but, surprise surprise, it looks like he was shut down.
Go Cart? Why not build his JET POWERED version! hehe
« Last Edit: May 27, 2004, 12:17:47 pm by Brax »
If you build a frankenpanel, chances are I don't care for you as a person.
GamingGreg
  • Last login:August 05, 2018, 06:04:30 pm
« Reply #30 on: May 27, 2004, 03:03:14 pm »
How about Build Your Own Time Machine.  It will only go forward.  If you want to go forward 3 minutes, you go in and set the egg timer for three minutes.  When the timer rings, you've just moved forward three minutes.   ;D
Thenasty
  • Trade Count: (+17)
  • Last login:September 16, 2025, 11:36:40 pm
« Reply #31 on: May 27, 2004, 05:15:34 pm »
Yea there was one in here BYOH "Build your Own Hole" funny stuff read about it. Now where is the link ? Ahh! here it is
http://www.cp-tel.net/pasqualy/hole/page1.html
« Last Edit: May 27, 2004, 05:17:22 pm by Thenasty »
Free VGA Breakout Cable
« Reply #32 on: May 28, 2004, 09:24:29 am »
What the...?  That guy is a total retard!  How on Earth does a total social gimp like this guy must be, not to mention ugly, wind up married?  How would he convince anyone to have sex with him?  Jesus! :o
(the really annoying part is that his property, abutting pine forest like that, would cost more than half a million dollars where I live)
Zathras
  • Last login:June 06, 2011, 01:06:02 am
  • Yeah.
« Reply #33 on: May 28, 2004, 09:46:28 am »
Cant believe this hasn't been posted yet but this guy built his own rollercoaster - complete with loop:
http://home.comcast.net/~chrisgeiger/tribute.html
and the official site:
http://www.geocities.com/midwestamusementparks/blueflash.htm
« Last Edit: May 28, 2004, 09:48:27 am by Zathras »
Space Warped by Someone
ani
  • Last login:June 17, 2004, 05:29:21 pm
« Reply #34 on: May 30, 2004, 06:08:32 pm »
I can't believe I just read all 8 pages of that.
You could also just buy his hole instead of building your own.
http://www.collinsandstamey.com/requestinfo.asp?id=446
IceCold
  • Last login:March 22, 2010, 05:11:22 pm
    • My MAME cabinet webpage
« Reply #35 on: May 31, 2004, 12:04:07 am »
Is it possible to build one of those?  That would be a dream come true(any time I go anywhere that has an icee machine I get one, whether it be speedway or walmart, etc.)  If anybody has any links on how to do this or to somebody's page that has done it, that would be sweet.  Thank you.
Edgedamage
  • Last login:October 06, 2018, 12:21:23 am
« Reply #36 on: May 31, 2004, 09:21:43 am »
Build your own jet engine from a old tubrocharger.
http://www.gasturbine.pwp.blueyonder.co.uk/page1.htm
Or go to the extreme.
http://www.jetped-boarders.co.uk/
Curls in the squat rack !?!?!
Generic Eric
« Reply #37 on: June 01, 2004, 03:09:39 am »
I think it *could* be done.  The other option, would be repurposeing the innards into the freezer section.  I don't see why it couldn't be done, but I don't know for *sure* that it could be done.  Just a dream really.
Wirehed
  • Last login:August 23, 2005, 06:05:30 pm
« Reply #38 on: June 03, 2004, 07:49:00 pm »
I built my own kegerator a few years ago and it's probably one of the best things I've ever done in my life. It was super easy to build, and the ~$350 I put into it I easily made back do to the fact that buying kegs from my favorite, local brewer costs almost half what bottles cost.
Hmmm... other fun projects... build a Trebuchet. :)
http://www.trebuchet.com/
Nothing scares the neighbors more than seeing giant siege weapons getting constructed from a backyard... :)
Generic Eric
« Reply #39 on: June 03, 2004, 09:30:51 pm »
Did someone mention the potato gun?
I don't remember where I saw it.  But someone sent a link for a bowling ball cannon.
Crazy stuff.  The site showed pictures of bowling balls lodged into trees.
