Author Topic: anyone ever tried this Analog Stick to PC gameport ?  (Read 950 times)
Thenasty
  • Trade Count: (+17)
  • Last login:Today at 11:08:36 am
« on: March 20, 2004, 12:36:34 pm »
http://www.happcontrols.com/industrial/joysticks/95017200.htm
I was just looking at this and I wanted to see if anyone dish out $200.00 to try it. Could you give me/us how you like it and if it works great .
Free VGA Breakout Cable
SirPeale
  • Green Mountain Man
Re:anyone ever tried this Analog Stick to PC gameport ?
« Reply #1 on: March 20, 2004, 02:32:35 pm »
Hm...I've got two of them.  I'll have to give it a shot sometime.
spidermonkey
  • Bombjack junkie
« Reply #2 on: March 20, 2004, 08:10:24 pm »
http://www.amusementsplus.com/joysticks/95017200.htm
I have this one. I ordered it with the 100k pots and the 10 pin serial cable. I've tried to use it several times but can't get MAME to recognize it. Kinda pi$$ed because it wasn't cheap.
Edit: fixed URL again.
« Last Edit: March 21, 2004, 10:37:45 am by Peale »
"Sinistar has bad breath"
froggerman
  • Last login:March 01, 2015, 03:23:14 am
  • You want how many buttons?!
« Reply #3 on: March 20, 2004, 09:24:31 pm »
http://www.happcontrols.com/index.html?http://www.amusementsplus.com/amusement/amusement.htm!
If you ordered it with 100K pots you could hook it up to a DB-15 connector and plug it into your PC's gameport. It should be recognized then.
paigeoliver
  • Awesome face!
« Reply #4 on: March 20, 2004, 09:38:48 pm »
And if you need the connector just buy a cheapo analog PC joystick, you can just transfer the wiring.
spidermonkey
  • Bombjack junkie
« Reply #5 on: March 21, 2004, 01:48:22 am »
Dammit, every time I try to paste a particular page from the Happ online catalog it ends up showing the title page when the link is clicked. Why is this ?  Since I can't seem to paste the model I have its the Happ analog stick with standard handle. I also screwed up when I described the type of cable it has as it does have the 15 pin gameport cable and not a serial cable.  I bought it to play Foodfight,Sinistar and a few others. It seems to work when I test it with the game controls calibration test in Windows but its not being recognized in MAME for some reason. :-\  Every other cheapo analog stick I've ever tried worked fine in MAME so I don't know why this stick won't.
SirPeale
« Reply #6 on: March 21, 2004, 10:40:00 am »
You linked to the wrong item.  I fixed the URL for you, based on what you said in your last post.  You should right-click on the item, and select 'Copy Shortcut' (for IE users) and use that link.  The link that is in the titlebar doesn't change, because of the frameset.
spidermonkey
  • Bombjack junkie
« Reply #7 on: March 21, 2004, 07:02:23 pm »
http://www.amusementsplus.com/joysticks/50274000.htm
Thanks for the info Peale. I hit copy/shortcut after right clicking on the pic so I think this link should display the correct page. If not then the stick is part # 50-2741-00 and that is the stick that I can't seem to get MAME to recognize for whatever reason. Ah well, I don't want to over shadow the original post because someone else started this post with a different question so he should be getting more attention regarding his question. Thanks for the help though. :)
