Author Topic: replacement ball for Ultimarc trackball  (Read 1779 times)
Felsir
  • Last login:July 09, 2025, 03:34:33 am
  • Creating cab artwork
    • Felsir's World
« on: March 10, 2004, 02:42:57 am »
I bought a trackball from Ultimarc and I'm quite happy with it. Now I'm in the process of theming my cab I found that a blue trackball would look nicer.
What can you recommend as replacement for the ball? Is a billiard ball the same size? Is there anything I should keep in mind? Thanks!
Tiger-Heli
    • Tiger-Heli
Re:replacement ball for Ultimarc trackball
« Reply #1 on: March 10, 2004, 09:07:45 am »
Assuming it's the 2-1/4" Ultimarc trackball (I think they all are, but just to be safe), then yes, a billiard ball will work.  or www.therealbobroberts.com sells blue replacement balls for $13.00 or translucent blue for $15.  or see about 10 threads down about the UV reactive acrylic juggling balls that could be used also.
Khenemet Heru
  • Last login:November 10, 2018, 06:27:09 pm
  • I want him in the games until he dies playing.
« Reply #2 on: March 18, 2004, 02:16:09 pm »
I bought one of those and ended up buying a 2 1/4" translucent red ball from happs - they are there, you just have to plunk around a while to find the part number to enter into the shopping cart...  I think it was $15...  nice color and translucency tho.
-Shadowhawk
No Boom today. Boom tomorrow. There's ALWAYS a Boom tomorrow. - Cdr. Susan Ivanova, Babylon 5
LoRDDeVO
  • Last login:January 06, 2023, 01:27:54 pm
  • 80's retrotechnoelectrogeek
« Reply #3 on: March 18, 2004, 02:36:09 pm »
Also you might want to take a look at Acrylic Juggling balls.  They come in alot more colors, for instance I have a 3" blue UV ball - AWESOME STUFF.  Alittle more expensive tho but worth it if you want to match your cab.
Google search for Acrylic juggling contact colored
you'll find a mess of them.
JamesS
  • Last login:May 09, 2014, 03:26:43 pm
  • Just getting Started, Bare with me...
« Reply #4 on: March 18, 2004, 03:03:56 pm »
Also, check out Bob Roberts.  He has the colors there and is usually cheaper overall than Happs.
