Author Topic: Been away a long time, need advice on how to set up daphne in an arcade cabinet  (Read 3056 times)
redfivexw
  • Last login:March 11, 2025, 03:54:00 am
Hello everyone.
I must admit i have been away from this site for many years as i had moved over to original equipment.  I have been presented with an original, but empty Cliff Hanger arcade cabinet.  I was wondering if anyone knew the easiest way to set up a pc to load directly to daphne and then work with arcade controls? I dont really want any menu interface or multiple games, just this one game.  BITD i had worked with an Ipac encoder to a pc.  I believe i had used a front end called GameEX.  It has been over a decade so i dont know if anything has changed.  I am ok with running an lcd monitor on this one.  Any advice appreciated.
nitrogen_widget
  • Last login:November 19, 2025, 07:10:59 am
i've been using batocera for 8 bit computer emulation.
it has laser disc support also.
https://wiki.batocera.org/systems:daphne
redfivexw
Thanks. I will check it out
Zeosstud
  • Last login:December 01, 2025, 07:27:46 pm
I would consider the dolphin emulator and the Don Bluth Trilogy if you mostly care about Dragons Lair, Space Ace, Dragons Lair II.. Super easy to setup, couple different modes, best graphics.. Obviously if you are looking for other Laser Disc Games, bad advice.
