Author Topic: How to Wire a Power Strip Inside of an Arcade Cabinet?  (Read 1230 times)
fsmith2003
  • Last login:October 29, 2023, 12:01:26 pm
« on: March 09, 2023, 08:14:55 pm »
I have recently added an audio amp to my Dynamo jamma cab which has a Peter Chuou power supply (usp-11-150x) installed. Right now I have the power cable for the amp running out of the back of the arcade alongside the arcades power cable. SO I am plugging those both into a power strip which I then plug into the wall.
I would like to wire the amp into the power circuit of the existing jamma arcade so that I only have one cable coming out of the arcade that would need plugged in. I believe this could be done by adding an internal power strip inside the cab. I am not quite sure how this can be done though. Does anyone have any suggestions or pointers?
  • Last login:Today at 03:15:40 am
Re: How to Wire a Power Strip Inside of an Arcade Cabinet?
« Reply #1 on: March 09, 2023, 10:10:14 pm »
Check out the IEC power inlet section of the wiring entry in the wiki.
http://wiki.arcadecontrols.com/index.php/Wiring#IEC_Fused_Power_Inlet_with_a_Lighted_Switch
  • Last login:Yesterday at 06:38:20 am
« Reply #2 on: March 09, 2023, 11:12:38 pm »
What kind of amp is it?
If it is a 12v amp you have better options.
fsmith2003
« Reply #3 on: March 10, 2023, 09:37:40 am »
Yes it is just a 12v amp.  This one from Amazon is what I have.
https://www.amazon.com/dp/B077Z7DBRT?psc=1&ref=ppx_yo2ov_dt_b_product_details
