Author Topic: Ipac Ultimate I/O and Goldleaf Buttons  (Read 2273 times)
mister-pizza
  • Last login:March 01, 2021, 04:56:05 pm
« on: July 20, 2020, 10:39:39 am »
Sorry, I've got another quick question before I order some parts. If I want to use Goldleaf buttons, and select the harness type for 2.8mm switch connectors, will all of these buttons be wired for Goldleaf buttons?
The reason I ask is for player start and coin buttons, and whether I need to order all Goldleaf buttons to be compatible with that wiring harness.
Also, what are 1A/1B/2A/2B used for? Could I use these for pinball flippers?
Drnick
  • Plodding Through Life
Re: Ipac Ultimate I/O and Goldleaf Buttons
« Reply #1 on: July 20, 2020, 12:40:40 pm »
Just checked my one as I do not have coin/start wired in yet, looking at the connections I have left I do have some larger spade connections. So it looks like the Coin/start are wired with the larger spade :)
mister-pizza
« Reply #2 on: July 20, 2020, 03:56:31 pm »
Thanks for the information! :cheers: So I should get a set of four classic pushbuttons? And can I use those 1A/1B/1B/2B for extra buttons?
Drnick
« Reply #3 on: July 23, 2020, 12:50:58 pm »
The 1A/B and 2A/B can pretty much be assigned to anything, normally used for Admin buttons like escape, They don't have a specific function or default mame setup :) They will want to be connected to goldleafs though as use the smaller spade connector.
mister-pizza
« Reply #4 on: July 23, 2020, 09:33:17 pm »
Good to know, thanks!
