Author Topic: Can I run other games on this cab?  (Read 2634 times)
gamestore66
  • Last login:June 19, 2020, 12:11:20 pm
« on: June 19, 2020, 12:09:42 pm »
I bought this cabinet modified/converted to pc. It has a computer and Arduino Uno connected to it. I don't know the model name or number of the cab, I couldn't see any name or number on it. The pc in the cab runs windows XP and I want to install a different games like LFS or NFS.  Can I run and play different games on this cab? Is the console compatible with other games?
  • Last login:Yesterday at 11:03:36 pm
Re: Can I run other games on this cab?
« Reply #1 on: June 19, 2020, 06:58:14 pm »
It's just a pc man... can you play other games on a pc?   :afro:
You need to give us some more info for more detailed advice.
baritonomarchetto
  • Last login:December 04, 2025, 02:41:34 am
« Reply #2 on: June 20, 2020, 01:23:17 am »
You should check what the PC specs are first, then, as Howard said, it is only a matter of installing a new game on a PC.
Being that you have an LCD it should be easy to replace the whole PC eventually.
The arduino uno is likely flashed to act as a joystick or combined peripheral.
See how the PC recognize it.
« Last Edit: June 20, 2020, 01:24:53 am by baritonomarchetto »
« Reply #3 on: June 20, 2020, 02:49:53 am »
Yeah that's the thing, without you checking we don't have any idea how that wheel is working hardware-wise.  I'm also curious if it has force-feedback.
vandale
  • Last login:September 11, 2024, 07:07:45 am
  • Id 10 and t error
« Reply #4 on: June 20, 2020, 06:33:09 pm »
Im guessing its pots and shifter via the Arduino. Centering via spring.
nipsmg
  • Last login:December 02, 2025, 01:18:04 pm
  • ROONEY!! ERRGH!!
    • Arcadia
« Reply #5 on: June 22, 2020, 07:51:16 am »
Possibly, but that's a sega wheel.  Was this an M2 cab?  If so there might be force feedback hardware, and he could just build a pwm2m2.
Edit: that's model 3 -- no idea about a hardware interface for that.
« Last Edit: June 22, 2020, 10:45:26 am by nipsmg »
